  3. Orcad Project -> more PCB schematics possible?
  • Subscribers 168
  • Views 6404
Cadleo
Cadleo over 13 years ago
Hi
I am working on a bigger project where I need to produce several PCB boards. I created a new project within I build the schematics. Now I would like to produce one Board after the other. Unfortunatelly I don't get the DRC and netlist function working?
Is it possible to design more psb Boards within one project? Or do I need to split them to there own project.
I am also getting this strange error message all the time.
anonymous@ftp.awi.de/.../problemmorepcb.JPG
 Thanks for help!
Martin
  • Khurana
    Khurana over 13 years ago
    Yes, you can have more than one board within one project.  Additional boards would be 'schematic' - currently you have only SCHEMATIC1.  Create a new schematic by right clicking on dsn file name (I think) and select New Schematic...this will be a new folder.  Pages can be added to this new schematic as usual.  To switch between schematics, right click on the schematic (folder) > select Make Root
  • Cadleo
     Hey Thanks!
    That's the information I needed. I always created several pages (PCBs) in the Schematic1 folder and was wondering about all the DRC and Netlisting errors. 1 Schematicfolder = 1 PCB Board - it's just as easy as this.
    Greetings Martin
  • AsetQs
    AsetQs over 11 years ago
    Hi
    When we have multiple schematics for multiple boards, can we create intersheet references for each board? When I create intersheet reference through Tools->Annotate , it creates intersheet references for only the root schematic. Can you let me know, how we can add intersheet references for each schematic in a multiple schematic configuration?
    Vaki
  • VelmuruganM
    VelmuruganM over 11 years ago
     Hi Vaki,
    Select the schematic which you want to annotate in a multiple schematic configuration.
    Then goto Tools-->Annotate...
    In the annotate diaglog box,under Packaging tab,select the scope as "Update Selection" instead of "Update Entire Design".
    This will updare only the scehmatic which you selected.
    Velu
  • AsetQs
    Hi Velu,
    Though, In my multiple schematic configuration. Tools-->Annotate... In the annotate diaglog box,under Packaging tab, the scope with "Update Selection" and  "Update Entire Design" is disabled when I select the add intersheet reference .
    Vaki
