  3. Specctra .DO file calling another .DO file
  • Subscribers 163
  • Views 15279
tjtan81
tjtan81 over 14 years ago
Hi all,
Would like to ask if anyone have the idea to write the command to call a .DO file from a .DO file?
eg: I have one .DO file for a rule for 10signals[A.do]; while another .DO file for another 5 signals[B.do].
Then I will make a master .DO file to call this A.do then B.do. Any idea on which command/syntax to use? Thanks.
Best regards...
  • tjtan81
    Hi mcatramb91, oldmouldy,
    Thanks for the reply.
    By the way, did you guys doing it by using MakeDO software or really write the command/syntax everytime you create the .DO file?
    Best regards,
    TeeJay
  • tjtan81
    Best regards,
    TeeJay
