  3. CIS Database Problem
  • Views 16489
nimoster
nimoster over 14 years ago
Hi Guys
I have my MySQL database running for CIS now and I can access parts in the database and also place them in a schematic using the CIS Explorer. But when I try to link a placed part in the schematic to a database part (Edit -> Link Database Part...) I get the following error message:
ERROR(ORCIS-6250): ODBC Error Code: -1
Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Load Capacitance , Physical_Package , Schematic_Part , PCB_Footprint , Manufactu' at line 1
ODBC Error Description: State:37000,Native:1064,Origin:[MySQL][ODBC 3.51 Driver][mysqld-5.0.51a-24+lenny5-log]
I don't have a clue where to start to fix this. Does anybody have an idea what's the problem? Btw, I use Capture CIS 16.5 and the MySQL Connector/ODBC v3.51.27.
Thanks in advance,
Martin
  • Kuenga606
    Kuenga606 over 14 years ago
    If you have latest 16.5 hotfix installed, following Tcl command sets an option to display the SQL query in the session log window, that is created by CIS.
    SetOptionString DisplayCisQuery TRUE
    Capture needs to be restarted after setting the option.
    The SQL query can be entered into mySQL and check where the error is present.
    If mySQL requires different qualifier for table and field name, following INI option sets the qualifier for Table and Field name
    [Part Management]
    Table Qualifier='
    Field Qualifier='
  • nimoster
    Many thanks! That was the hint I needed... with the option I was able to track down the table Capture had a problem with....  D'oh! Whitspaces and dashes are no good in table headers ;-) I got rid of them, now everything is working fine, yay!
    Thanks again,
    Martin
  • DaveCowl
    DaveCowl over 11 years ago
    Thanks for the hint. It seems that OrCAD is escaping the \ in the Part_Type too much. Basically it is using \\\ to represent the \ instead of \\ which is correct.
    Any thoughts on how to get it to behave? Basically I am connected correctly now but I don't see any parts that have sub-types.... :(
