  3. how to update the net name faster in conceptHDL
  • Subscribers 163
  • Views 16778
AndyZhang
AndyZhang over 14 years ago
I used concept HDL to draw the schematic, and it has over 100 pages. I want to delete the suffix "/base" of all signal names.
if there anyone have a good way?
  • Jerry GenPart
    Jerry GenPart over 14 years ago
    You could try using the Global Property Change option under the Tools menu.
    Jerry
  • AndyZhang
    Could you give me more details about your solution, I have trid to use the Global Property Change command, but it cannot remove the same suffix(/base) of different net name.
    For example, the net name CH000/base, CH001/base and CH002/base on different pages, how can you remove the suffix at same time?
    Now I just use the Find command to change them in Notepad page after page.
  • Jerry GenPart
    Ah yes – I do see the problem Andy.
    So, you may indeed need t use the Notepad method you’re using (page-by-page), or you can use a simple script to edit the pageN.csa files and remove the \base suffix. Then remove the pageN.csb (the binary) files, and read the ASCII files into DEHDL. Then, save them (do a Save Hierarchy) to re-write the pageN.csb files.
    Jerry
  • AndyZhang
    Hello Jerry,
    thanks for your reply, but I don't know how to write the script file, could you please help me?
