  3. Artwork Generation Warning
  • Views 14028
wakeup
wakeup over 13 years ago
 Today I experienced a problem while using PCB Design.
When I click on Create Artwork it says that it had been exported successfully, but there are many warnings in logfile like:
 WARNING: line segment outside plot window (not included in artwork)  12.7020 10.8946  to  12.9230 10.8946
 WARNING: line segment outside plot window (not included in artwork)  12.7020 10.8965  to  12.9230 10.8965
 I used a tool to see the gerber files, but even though PCB Designer says it is successfull, the viewer shows that there is an error with gerber files.
 I believe this causes because of these warnings. How can I solve this problem?
Thank you.
  • Rik Lee
    Rik Lee over 13 years ago
    I suspect that there are line/elements defined in the film that exceed the extents of the photoplot outline as described in Cadence Online Support solution
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11640746;searchHash=d957ea4e67142a7baf0111915e99b134
  • Rik Lee
