  3. Changing Text Size and Font
  • Views 33095
wakeup
wakeup over 14 years ago
 I know it is very strange that I could not find the place to change font and text size for a simple text. I know from Design Parameters, I can change the sizes, but only the first one on the list is applied to the texts. How can I change these two paramters?
 Thank you,
  • steve
    steve over 14 years ago
    To change a text szie use Edit - Change, pick the text block size you wish to use in the Options fold out menu on the right hand side, then select the text you want to change. You cannot change fonts in PCB Editor.
  • wakeup
    Thank you for your response. I was clicking on Change, but could not find the options to change it. Now with your help, I found the place.
