  3. Packager error SPCODD-7
  • Subscribers 163
  • Views 15446
Autarchex
Autarchex over 14 years ago
I heavily modified an existing board design in Allegro Design Entry HDL, including moving components between heirarchy blocks (despite warnings that Allegro does not handle that well...)   When I go to do an Export Physical, with only "package design" checked, and set to 'repackage', I get ERROR(SPCODD-7) which I have pasted below.  Like most Cadence error messages this doesn't really seem to tell me much, and I cannot find a lookup table of error messages on the website.  The component it is complaining about is a TI TPS54160 buck converter and is not a multi-section part, yet it seems to want multiple sections for packaging.  Anyone else run into this?
#1   ERROR(SPCODD-7): Following Primitive instance of size requires 2 section~s for packaging.  Only 1 sections available in package of type '18222500_A-182~2-2500'.  Check the size of all pins on this primitive.
Primitive Instance: @MAGPIE_LIB.ROOT(SCH_1):PAGE1_I22@MAGPIE_LIB.PEN_I~NTERFACE(SCH_1):PAGE1_I2@MAGPIE_LIB.PEN_SUPPLY_VPP(SCH_1):PAGE1_I1@IC_POWER.TP~S54160(CHIPS) (MODULE: PEN_SUPPLY_VPP; PART: TPS54160)
Physical Path: @magpie_lib.root(sch_1):page3_i22@magpie_lib.pen_interf~ace(sch_1):page1_i2@magpie_lib.pen_supply_vpp(sch_1):page1_i1@ic_power.tps5416~0(chips)
  • Jerry GenPart
    Jerry GenPart over 14 years ago
    Has this design been upreved from the 16.3 to the 16.5 release? If so, please read this excellent Cadence Online Support Solution that will provide you the resolution –
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11751374
    Jerry
  • Autarchex
    Yes, it was upreved from 16.3 to 16.5, and then heavily edited.  I followed the instructions for the second option, using the environment variable.  It did not appear to make any difference;  I still receive several hundred SPCODD-7 errors when I package the design.  At this point I am considering writing a Perl script to strip out the unwanted and uneditable $SEC attributes from all of the components, but I am wary of directly editing the underlying files.
  • Autarchex
    My apologies, I apparently had not fully patched my installation.  Once I patched it to the most current revision, I tried this again and it worked!  Thanks!
  • Jerry GenPart
    Thanks for the feedback – glad it’s working!
    Jerry
