  3. Design rule to support mass production
  • Subscribers 162
  • Views 14288
C Shiva
C Shiva over 14 years ago
Hi All,
 What's the PCB design rule to support mass production? What's the min. trace width/seperation and other constraints for it?
 Any input, suggestion and reference documents will be appreciated.
Shiva.
  • Urmil
    Urmil over 14 years ago
     Allegro PCB Editor has Constraint Manager to indicate these constraints and the Design Rules Check verify that all these constraints are followed.
     Please use the Constraint Manager Tutorial available through the following link:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/algroCM_tut/algroCM_tut16.5/algroCM_tut.pdf
    - Urmil
  • C Shiva
    Thank you Urmil.
    Unfortunately my access on sourcelink is expired. Could you please attach the pdf file here.
    Thanks again,
    Shiva.
