  3. Open a Capture 16.3 .dsn in Capture 9.2
  • Views 16766
mikecheetah
mikecheetah over 14 years ago
Does anyone know of a way to open a .dsn file (version 16.3) in capture 9.2?  My understanding is the file format changed in 16.3.
  • kabalee
    kabalee over 14 years ago
     hi ,
     file export-->EDIF window open after that give location to save and configuration file should be same name and same path.
    after that make folder open orcad 9.2 and then file -->import-->EDIF file location and library location
    it will help u
  • mikecheetah
    I do not have Orcad 16.3, so I cannot export the file to be read by 9.2.  I only have 9.2, and I am trying to open a 16.3 dsn file.
  • mikecheetah
    Thank you for the reply!
  • mbeffa
    mbeffa over 12 years ago
    You might be kidding. This works in theory and in theory, theory and practice are the same.
    In practice they are not, so it does not work.
    How about I send you a design in 16.3 and if you convert it to 9.2 I buy you lunch?
