  3. Allegro Design Entry HDL Component Browser Issue
  • Subscribers 163
  • Views 15259
CCR77
CCR77 over 14 years ago
        I am new to Allegro Design Entry HDL and am having a problem with my component browser.  I can see the symbols, however none of the footprints can be found in the PSMPATH.  I can place components just fine and I know the footprints exist.  Where is the PSMPATH specified? Undoubtedly its pointed to the wrong directory.  All and any help would be greatly appreciated.
Clint
  • steve
    steve over 14 years ago
    Project Manager Setup button, Tools tab, PCB Editor Setup, then define padpath and psmpath (which are located under Paths - Library). You can access the same menu from inside PCB Editor - Setup - User Preferences. Once set it writes this to $HOME\pcbenv folder a file called env.
  • CCR77
    Hi Steve,
               Thanks for the help! My component browser is working correctly now!
    -Clint
