  3. DESIGN REUSE IN LAYOUT
  • Views 16856
girish
girish over 14 years ago
Dear all ,
Good day !
I have one routed board file which consists of Processor, DDR , POWER , & expansion connector like SOM.
We used to insert this SOM PCB to a carrier card expansion connector where all standard connector used for peripherals, its like two board approach for a system .
The new requirement is I need to have a single board approach for the System at the same time I want to reuse my old SOM layout file as a component /module/ routed block in my carrier card design to save the time & effort .Is there any option in allegro to reuse already routed board file as module in new design without altering its properties .
Simple approach is take the old layout file & expand the Board outline & add carrier card components ! but I want go for modular approach it will be very useful
Please provide your valuable suggestions if anybody implemented similar concept its new to me !
Best Regards
Girish Kumar
  • oldmouldy
    oldmouldy over 14 years ago
    On the Existing board, enter Placement Edit mode, select "everything", probably deselect the board outline if it gets selected, Place>Replicate Create, follow the prompts and an MDD file will be written. Create the "new" board, get the parts for the "module" on the canvas, enter Placement Edit mode, window select the parts, right-click>Place>Replicate Apply, select the MMD file created previously, confirm the matching of parts and place the module.
  • girish
    Thanks a lot  I will check the possibility .
    Girish Kumar
  • girish
    girish over 13 years ago
    I am not having  Placement edit mode  option enabled in  Orcad PCB Designer Standard !
    Please help me If I upgrade to Orcad professional  above method can be implemented ? or do  I need to switch to Allegro paltform
    Many Thanks
    Girish Kumar
  • steve
    steve over 13 years ago
    Placement Edit mode is avaliable in Orcad Professional and above (Allegro PCB Designer). It's not there in the Orcad Standard license level.
  • girish
    Thanks Steve.
    Need to upgrade !
    Girish Kumar
