  3. pin delay settings in V16.2
  • Subscribers 162
  • Views 16812
purikku22
purikku22 over 14 years ago
 hi all,
i have a design wherein we set the pin delay of BGA by using the pin property. But during serpentine wiring, the pin delay we add are not calculated automatically. What should i do enable the pin delay length we added?
 thank you.
  • Urmil
    Urmil over 14 years ago
    Dear customer,
    I am happy to supply you an answer to your quesiton by referencing knowledge content available on the Cadence Online Support (http://support.cadence.com) web site.  Access to this site is available to all Cadence customers currently on maintenance.   If you have any questions regarding access, please call 1-888-CDS-4911.
    Here is the Cadence Online Support information I believe will answer your question:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11483282
    Urmil
    Cadence Customer Support
  • mcatramb91
    mcatramb91 over 14 years ago
    A couple things come to mind:
    1) Did you enable the Package Pin Delay DRC Checks.  Under the Setup Menu select Constraints > Modes and under the Electrical Options you will need to check the box under the Pin Delay section to include all Propagation Delays and Diff Pair Phase in the calcuations.
    2) To take advantage of thes checks you will also need one of the higher tier tools to support this constraint otherwise they will be ignored.  In Allegro 16.5 you will need to enable the High Speed option during startup.  In Allegro 16.2 you will need to use the Allegro PCB Design XL license.
    Constraint manager will also show the headers for the Pin Delay as Yellow indicated that the rule is not enabled.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • purikku22
     Thanks Urmil and Mike!
    I will try your solutions. I have a feeling that Mike answer is the problem. The last time I checked my design, I am using only a Performance Option. I will try it in the XL license that we have.
    Cheers! Have a great day
    Best regards,
    Eric
