  3. Models missing from PSPICE - OrCAD 16.2
  • Replies 9
  • Subscribers 166
  • Views 11568
pkat
pkat over 13 years ago
Hello
I have a problem. I can't simulate a very simple circuit because the models are missing. I am very new to OrCAD (version 16.2) so I was doing the tutorial on creating a schematic of full adder and simulating it as per the OrCAD's tutorial. As per the instructions I should be able to simulate but I can't because of the problem I earlier stated.
 In the Simulation Setting -> Configuration Files -> Library the library path field has the following in it "C:\OrCAD\OrCAD_16.2\tools\PSpice\UserLib";"C:\OrCAD\OrCAD_16.2\tools\PSpice\Library"
I suspect more information needs to be filled but I am surprised that the tutorial example didn't address it. I get the feeling that some .MODEL command is missing from the netlist. Please let me know exactly how to resolve it. Here are the netlist (based on the tutorial) & the errors. Thank you very much
**** 06/26/12 09:48:32 ******* PSpice 16.2.0 (Oct 2008) ******* ID# 0 ********
 ** Profile: "FULLADD-SWEEP1"  [ C:\ORCAD_DATA\TutorialFiles\FullAdd-PSpiceFiles\FULLADD\SWEEP1.sim ]
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "SWEEP1.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.STMLIB "C:/OrCAD/OrCAD_16.2/doc/flowtut/tutorial_example/complete/fulladd-PSpiceFiles/FULLADD/TRAN/input.stl"
* From [PSPICE NETLIST] section of C:\OrCAD\OrCAD_16.2\tools\PSpice\PSpice.ini file:
*Analysis directives:
.TRAN  0 100us 0
.OPTIONS LIBRARY
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\FULLADD.net"
**** INCLUDING FULLADD.net ****
* source FULLADD
.EXTERNAL OUTPUT CARRY_OUT
U_DSTM1         STIM(1,0) $G_DPWR $G_DGND N00289 IO_STM STIMULUS=X
X_HALFADD_A1_U1A         N00159 HALFADD_A1_N00277 HALFADD_A1_N00426 $G_DPWR
+  $G_DGND 7408 PARAMS:
+ IO_LEVEL=0 MNTYMXDLY=0
X_HALFADD_A1_U1B         N00100 HALFADD_A1_N00237 HALFADD_A1_N00382 $G_DPWR
X_HALFADD_A1_U1C         N00159 N00100 N00130 $G_DPWR $G_DGND 7408 PARAMS:
X_HALFADD_A1_U2A         N00159 HALFADD_A1_N00237 $G_DPWR $G_DGND 7404 PARAMS:
X_HALFADD_A1_U2B         N00100 HALFADD_A1_N00277 $G_DPWR $G_DGND 7404 PARAMS:
X_HALFADD_A1_U3A         HALFADD_A1_N00382 HALFADD_A1_N00426 N00108 $G_DPWR
+  $G_DGND 7432 PARAMS:
X_HALFADD_A2_U1A         N00315 HALFADD_A2_N00277 HALFADD_A2_N00426 $G_DPWR
X_HALFADD_A2_U1B         N00289 HALFADD_A2_N00237 HALFADD_A2_N00382 $G_DPWR
X_HALFADD_A2_U1C         N00315 N00289 N00240 $G_DPWR $G_DGND 7408 PARAMS:
X_HALFADD_A2_U2A         N00315 HALFADD_A2_N00237 $G_DPWR $G_DGND 7404 PARAMS:
X_HALFADD_A2_U2B         N00289 HALFADD_A2_N00277 $G_DPWR $G_DGND 7404 PARAMS:
X_HALFADD_A2_U3A         HALFADD_A2_N00382 HALFADD_A2_N00426 N00159 $G_DPWR
U_DSTM2         STIM(1,0) $G_DPWR $G_DGND N00315 IO_STM STIMULUS=Y
Q_Q1         N01695 N01661 0 Q2N2222/27C
X_U1A         N00130 N00240 CARRY_OUT $G_DPWR $G_DGND 7432 PARAMS:
R_R1         N00108 N01661  10k TC=0,0
V_V1         N01754 0 5Vdc
R_R2         N01695 N01754  1k TC=0,0
U_DSTM3         STIM(1,0) $G_DPWR $G_DGND N00100 IO_STM STIMULUS=Carry
**** RESUMING SWEEP1.cir ****
.END
ERROR -- Model Q2N2222/27C used by Q_Q1 is undefined
ERROR -- Model IO_STM used by U_DSTM1 is undefined
ERROR -- Model IO_STM used by U_DSTM2 is undefined
ERROR -- Model IO_STM used by U_DSTM3 is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A1_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A1_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A1_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HALFADD_A1_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HALFADD_A1_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HALFADD_A1_U3A is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A2_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A2_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HALFADD_A2_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HALFADD_A2_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HALFADD_A2_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HALFADD_A2_U3A is undefined
ERROR -- Subcircuit 7432 used by X_U1A is undefined
  • Chrissy1979
    Chrissy1979 over 12 years ago
    I managed to figure out what the problem was. In my version of PSpice 16.6, nom.lib, doesn't exist! This is because it nom appears without the file extension .lib. I added the folder from it's location cadence/spb_16.6/tools/pspice/library/nom
    I then clicked on "add to global".
    I hope this helps someone else out there.
  • Chrissy1979
