  3. bottom side surface mount pins not exporting properly in...
  • Views 13049
bottom side surface mount pins not exporting properly in DXF
padmaster
padmaster over 13 years ago
It appears that the bottom side surface mount pins are exporting to the pin_top layer in the DXF file. I have been using my .cnv file for several years. Started using 16.5 several months ago and I keep up with all the hotfixes. Not sure when this started happening. Anyone else run into this?
  • Boma
    Boma over 13 years ago
    This has been fixed in 16.5 ISR24 which is available.
    Boma
  • padmaster
    Well, I guess I haven't kept up with the hotfixes fast enough....Thanks
