  3. How to remove layers from existing stack-up?
  • Subscribers 162
  • Views 19219
CCR77
CCR77 over 13 years ago
        I am trying to create several templates 2, 4, 6, 8, 10 and 12 layers boards.  The orriginal board I started out with had an eight layer stack-up.   The template is entirely clear and I blew away the netlist by importing a blank schematic so all is good, however when I try to remove a layer from the stack-up Allegro reports " You cannot remove a layer containing etch."  I dont understand this as there is no etch.  Can any one tell me how to remove a layer? or explain the reason for this error report?  Any and all help would be greatly appreciated.
Clint
  • jch teyssier
    jch teyssier over 13 years ago
     Hi Clint,
    some things that can prevent of removing an etch layer:
    - Used in a artwork definition
    - Layer specific KEEP-out's present (exemple: a route keepout)
    - Database padstack with definition on this layer.
    -... several others, you have to find it
     Do you run dbdoctor on your brd?
    Jean-Charles
