  3. Cadence 16.5
  • Views 13935
Cadence 16.5
hrienderhoff
hrienderhoff over 14 years ago
I have just recently gone from 15.7 to 16.5.
I'm trying to simply change a line width.
It used to be as simple as edit change but that has seemed to change.
Can you tell me an easy way to change an existing line width?
Hans
  • steve
    steve over 14 years ago
    This is the same. Check the Options fold out menu. You should also try hover over the item you want and RMB (right mouse button) Change width.... but this will depend on the application mode you are in. Bottom right of the screen General Edit, Etch Edit, Placement Edit etc.
