  3. Net list error on part names
  • Views 14278
Remis
Remis over 13 years ago
#1 WARNING(ORCAP-36006): Part Name "CAP CERAMIC_CKG57NX7R2A106M_470NF" is renamed to "CAP CERAMIC_CKG57NX7R2A106M_470".
How to solve this error?
  • steve
    steve over 13 years ago
    It's only a warning so shouldn't be an issue. You could though change the net limit from 31 to 255. Press to the setup button inside the netlist form and set the Device/Net/Pin/Name Char limit from 31 to something larger (255 is the max)...
  • Remis
    If changing to number that is higher then 31 geting error:
    #1   ERROR(SPMHNI-176): Device library error detected.
    ERROR(SPMHNI-189): Problems with the name of device 'RES_V_RES_0603_DISCRETE_2,2_(RES_0603_GD)': 'Name is too long.'.
    ERROR(SPMHNI-170): Device 'RES_V_RES_0603_DISCRETE_2,2_(RE' has library errors. Unable to transfer to Allegro.
    one more question: how to remove that device  name from all pats, i dont want that i will be displayed in my PCB design, instead of that would be good to se only my schematics numeber like "R1", "R2" etc.
  • steve
    If you change it in Capture you also need to change it in Allegro (Setup - Design Parameters - Design tab, set the Long Name Size to match.
    Don't think you can limit what is device name is there. I think it's a default property. Someone else might know.....
  • Remis
    I dont believe that someone in the world needs that part name in their PCB design, part number would make some sence, but this...
