  3. Signal integrity verification at 10GHz
  • Replies 14
  • Views 18842
Pavel47
Pavel47 over 13 years ago
Is Allegro PCB SI (or some other tool from 16.5) capable to check signal integrity of a complex board at 10GHz ?
Or one should export the board file to HyperLynx and check SI with the last one ?
Thanks in advance.
Pavel.
  • Pavel47
    Tutorial - Ok. Sorry, I was inattentive.
  • Dennis Nagle
    Dennis Nagle over 13 years ago
     Yes, you will request the IBIS model from Altera.
  • Pavel47
    I've just got to know, that Altium (which also has SI option) can't simulate VIAs.
    Is it the case also for Allegro SI ?
    One more question - Molex provide for their connectors only S-parameter models.
    Can one use them for SI simulation ?
    Thanks in advance.
    Pavel.
  • Dennis Nagle
     Yes, PCB SI can handle vias. It can also generate S-paramters and make use of them as modelsin simulations.
    -Dennis
  • Pavel47
    Hi Dennis,
    Ok. good news !
    Here I didn't clearly understand what you mean. Which data (info)PCB SI will use to generate S-parameters for a particular connector. S-parameters come from measurements... Or i missed something ?
    Regards.
    Pavel.
