  3. Representing a toroidal coil on Capture
  • Subscribers 163
  • Views 15179
Albirea
Albirea over 14 years ago
i'm quite a beginner using Capture, but i need to model a toroidal ferrite core coil to simulate it and compare the theoretical performances to the experimental measures i got from a hand-made coil.
I found this application note and tried to reproduce the schematic:
http://www.orcad.com/documents/community.an/pspice/tn20.aspx
Unfortunately, for the "egeom" part, i thought it was a part like "Const" from the "ABM.olb" library, but when i run the simulation i obtain an error:
V_XBF1_CONST1         XBF1_GEOM 0 DC {N}*{N}*(0.417+3.41*{LEN}*LOG10({OD}/
ERROR -- Expecting keyword STIMULUS, saw *{N}*.
(XBF being the bobin part, N the number of turns, Len/OD/ID respectively the length, output and input diameters of the bead)
Could you help me finding out what part this "egeom" could be please?
It is for a school project in Italy, and i would really appreciate a hand on this.
Thanks with advance :)
  • oldmouldy
    oldmouldy over 14 years ago
    Try the "ABM" part from teh ABM.OLB, set the EXPR1 property to the required formula.
    Whatever you have in your circuit has resulted in some invalid combination of a Voltage source - line begins with "V" - and a sub-circuit - it looks like the statement should begin with "X" - this won't be appreciated by PSpice. Your correct implementation should result in a netlist line that begins "E..." for a voltage conreolled voltage source with expression values referenced from parameters (in this case).
  • Alok Tripathi
    Alok Tripathi over 14 years ago
    I think problem is with expression used with ABM device. You need to put complete expression in braces. It should be something like:
    {N*N*(0.417+3.41*log10(OD/ID))}
