  3. Teardrop on Orcad Suite
  • Views 15413
mkbs
mkbs over 13 years ago
There will be, in your opinion (rumours...etc), the possibility of having even the teardrop on Orcad PCB Suite?
Teardrop is very useful, for example, in the vias, to avoid close drill tollerance.
Mirko
  • steve
    steve over 13 years ago
    It's there already. You need to have OrCAD PCB Designer Professional (It's not avaliable in the OrCAD PCB Designer Standard). You need to be on 16.5 and hotfix 8 (I Think) or later. To do it use Route - Gloss - Fillet Parameters to define / setup and Route - Gloss - Add Fillet to add it. Then select either items or window.
  • mkbs
    Hi Steve,
    many thanks for your fast reply.
    I'm trying the Orcad Suite Lite, for evaluate a possible Ecad switch, but this feature is not present there.
    Mirko
  • steve
    It's not avaliable in Lite or Standard. Talk to Cadence or a Cadence VAR and get a proper evaluation license.
