  3. Issue with netlisting to PCB Editor
  • Views 14429
richellis2001
richellis2001 over 13 years ago
Hi all,
 I am trying to generate a netlist from my schematic to generate the layout for PCB Editor but keep encountering an error which I'm struggling to understand.
 After generating the netlist, the following error log is generated:
Loading... c:\sourcesafe working folder\development environment\orcad\triple outlet prompt - 1833\interface\allegro/pstchip.dat
Loading... c:\sourcesafe working folder\development environment\orcad\triple outlet prompt - 1833\interface\allegro/pstxprt.dat
Loading... c:\sourcesafe working folder\development environment\orcad\triple outlet prompt - 1833\interface\allegro/pstxnet.dat
ERROR(SPCODD-433):
            Error at line 1603 in file c:\sourcesafe working folder\development environment\orcad\triple outlet prompt - 1833\interface\allegro/pstxnet.dat. Error in syntax.
 Looking t the pstxnet.dat file, specifically at line 1603 where the error is reported, all I see is:
 <snip>
NODE_NAME    CN1 1
 '@6_1833_030_01.SCHEMATIC1(SCH_1):INS8876075@MIRAN.30WAY_CONN.NORMAL(CHIPS)':
 '16':;
NODE_NAME    CN1 30
 '$PIN29':;
NODE_NAME    U1 9
 '@6_1833_030_01.SCHEMATIC1(SCH_1):INS12606885@6_1833_030_01.74LS595_0.NORMAL(CHIPS)':
 'QH'':;
END.
Line 1603 is the blank line after the END. statement. Not sure what the netlist is falling over on?
Any ideas?
  • Boma
    Boma over 13 years ago
    The first thing that jumps out at me is the spaces in the directory names of the path.  This has always caused problems for us.  I would get in the habbit of using an underscore with both filenames and directory names.
    Boma
  • Boma
    Boma
