  3. Permanently remove all components from a .brd?
  • Subscribers 162
  • Views 16033
CCR77
CCR77 over 13 years ago
        I have recieved a file in which we would like to remove all components from the .brd with the exception of two connectors.  Typically I have imported a blank shematic into the .brd and it removes all components from the file.  This particular .brd is throwing an error when I import the blank logic.  The error message is as follows:
ERROR(SPMHNI-342):  Design flow is constraint manager enabled, require pstcmdb.dat and pstcmbc.dat files.
 I dont have these files.... Is there a way to get around this?  Any help would be greatly appreciated.
Clint
  • CCR77
    I have found the solution......
    At the command console (in Allegro) type:
           skill<enter>,
    (then type or copy and paste)
           axlDBControl('cmgrEnabledFlow nil)<enter>,
    You should see a "t" returned which tells you that the command was
    successful.
    Type: exit <enter>, to exit skill
    Save the board.
     This worked with no issues.
    -Clint
