  3. Creating Design Entry Parts
  • Replies 7
  • Subscribers 166
  • Views 14446
TooBorg
TooBorg over 13 years ago
Hi @all!
Last time i asked about a script for creating a large footprint (2992 pins) - and the excel sheet worked well. Ok, i had to re-write parts of it to fit it to my needs, but it was a nice thing to start with and it helped me a lot!
Now i have another problem: I do need that large part in a library for using it in design entry in a schematic. Ok, i imported all of the pins with the spreadsheet-import. That works but i do get one big block with all 2992 pins. Is there a way to create more "blocks" for one part? The function to create multiple parts per package won't work because the pins are not the same.
Example with 12 pins: I would want to create one part, painted by three blocks with different pin counts. Pins 1-6 are digital pins - i would want to create a block for those pins. And a seperate block for pins 7-10 (analoge pins), and a third one for 11 and 12 - the power pins. I hope you understand what i mean...
When i start creating a symbol there is a box on the screen (dotted line) with will be the outline of the new part. All of the pins i would add, would be somewhere on this box. But i can't create more than that one box...
  • steve
    steve over 13 years ago
    Unfortunately you need the Librarian XL license to export DE HDL - DE CIS. You can create Split parts in DE CIS though. Create a library file, then click on the library and RMB - Create New Part from Spreadsheet, fill the spreadsheet in to suit. The different sections specify which pins go in which section. The No of sections defines the number of parts.
    Here's a video showing the basic idea. It creates the part three different ways but you should get the general idea.  http://www.youtube.com/watch?v=JBrpZbYMN4c&feature=plcp
  • TooBorg
    As always that was the exact solution to my problem! Thanks a lot!
