  3. OrCad Layout Error Code Listing
  • Views 16626
dschaefer
dschaefer over 13 years ago
Does anyone know where I can find the OrCad Layout error code listing?
It used to be on Sourcelink but has been removed.
  • FormerMember
    FormerMember over 13 years ago
    *bump*   I could use that listing as well.
  • dschaefer
     Ron,
     I was able to obtain the file. I can't attach the file here but will attempt to paste it's contents:
    0001361 ASCXLEX Bad units
    0001430 ASCXMAIN Data Heap
    0001852 ASCXPACK Unable to allocate packNameTable
    0001853 ASCXPACK Unable to allocate stringPtr
    0005860 STRXMAIN Failed to allocate SymNameTab in StrX
    0005861 STRXMAIN Failed to allocate CompNameTab in StrX
    0005862 STRXMAIN Failed to allocate Comp HeapSlice in StrX
    0005863 STRXMAIN Failed to allocate Sym HeapSlice in StrX
    0005864 STRXLIB Failed to allocate Comp HeapSlice in ParseIFL
    0005865 STRXLIB Failed to allocate Sym HeapSlice in ParseIFL
    0005882 STRXMAIN Expected ComPushDir (TCH_LIB)
    0006260 STRBFILE Failed to allocate SymNameTab in StrX
    0006261 STRBFILE Failed to allocate CompNameTab in StrX
    0006263 STRBFILE Failed to allocate Sym HeapSlice in StrX
    0006264 STRBFILE Failed to allocate Comp HeapSlice in ParseIFL
    0006265 STRBFILE Failed to allocate Sym HeapSlice in ParseIFL
    0006267 STRBFILE Failed to allocate Comp HeapSlice in StrX
    0007101 NPPSPOOL Obs color heap
    0007104 NPPSPOOL "(short) colorView.kind" out of range (0, TEXT_OTHER-1)
    0007104 NPPINIT "(short) colorView.kind" out of range (0, TEXT_OTHER-1)
    0007105 NPPSPOOL Shape not supported in drawOnePad
    0007106 NPPSPOOL Obs colors for one layer
    0007107 NPPSPOOL "(short) colorView.kind" out of range (0, OBS_OTHER-1)
    0007107 NPPINIT "(short) colorView.kind" out of range (0, OBS_OTHER-1)
    0007108 NPPSPOOL Text colors for one level
    0007109 NPPSPOOL Text color heap
    0007112 NPPHATCH Failed to allocate hatchHeap
    0007113 NPPHATCH Failed assumption obsPtr->hatchKind
    0007116 NPPHATCH Failed to allocate poly data in HatchObs
    0007117 NPPHATCH Failed to allocate poly data in HatchObs
    0007118 NPPHATCH Failed assumption obsPtr->hatchKind
    0007119 NPPHATCH Failed to increase polyList in HatchObs
    0007120 NPPHAT2 Failed to increase polyList in HatchObs
    0007121 NPPHAT2 Failed assumption polyPtr->hatchKind
    0007122 NPPHAT2 Failed assumption polyPtr->hatchKind
    0007123 NPPHAT2 Failed to allocate hatchHeap
    0007124 NPPHAT2 Failed to allocate polyList in HatchObs
    0007125 NPPHAT2 Failed to allocate poly data in HatchObs
    0007131 NPPMAIN Failed assumption InBatch == NO
    0007140 NPPRAST2 Failed assumption dy > 0
    0007142 NPPAPP1 Unknown shape
    0007144 NPPAPP1 Unknown kind
    0007151 NPPGER Allocating appHashTable
    0007153 NPPGER Allocating one DRAW RECORD
    0007154 NPPGER Allocating one FLASH RECORD
    0007154 NPPGER Allocating one DRAW RECORD
    0007154 NPPSIMAP Allocating one DRAW RECORD
    0007156 NPPGER Failed assumption DbView.boardXMin >= 0
    0007157 NPPGER Failed assumption DbView.boardYMin >= 0
    0007158 NPPGER Unknown shape
    0007159 NPPGER Failed assumption prevPtr
    0007170 NPPPLOT Failed assumption DbView.boardYMin >= 0
    0007171 NPPPLOT Allocating appHashTable
    0007173 NPPPLOT Allocating one DRAW RECORD
    0007174 NPPPLOT Allocating one FLASH RECORD
    0007175 NPPPLOT yScanList HeapAssign failure in nppplot
    0007176 NPPPLOT yScan HeapAssign failure nppplot
    0007178 NPPPLOT Failed to allocate YscanTab in nppplot
    0007179 NPPPLOT Failed to allocate YscanTab in nppplot
    0007180 NPPPLOT Failed to allocate Vec HeapSlice in nppplot
    0007182 NPPPLOT Failed to allocate Vec HeapSlice in PltMain
    0007184 NPPPLOT conTableHeap HeapAssign failure in nppplot
    0007185 NPPPLOT Failed to allocate conTablePtr in nppplot
    0007188 NPPPLOT Failed to allocate penObject
    0007189 NPPPLOT Failed assumption DbView.boardXMin >= 0
    0007191 NPPINIT Obs color heap
    0007191 NPPINIT "MaxDevice" out of range (1, MAX_DEVICE)
    0007196 NPPINIT Obs colors for one layer
    0007198 NPPINIT Text colors for one layer
    0007234 NPPDLG Failed assumption altIdx != 0
    0007237 NPPDLG Failed assumption altIdx != 0
    0007238 NPPDLG Failed assumption altIdx != 0
    0007400 NPPRAST2 Failed to allocate file_buff HeapSlice in PltRast2
    0007431 NPPRAST1 "(unsigned int)NewVector.y1" out of range (1, YscanAlloc * 2)
    0007432 NPPRAST1 Failed to allocate YscanTab linklist HeapSlice in npprast1
    0007433 NPPRAST1 "(unsigned int)y1" out of range (1, YscanAlloc * 2)
    0007451 NPPHP Expected ! plotBuffHandle
    0007452 NPPHP Allocating pltBuffHandle
    0007453 NPPHP Locking pltBuffHandle
    0007454 NPPHP Expected ! imageHandle
    0007455 NPPHP Allocating imageHandle
    0007456 NPPHP Locking imageHandle
    0007480 NPPLEX Failed assumption sourceFile
    0007510 NPPHPGL Allocating appHashTable
    0007511 NPPHPGL Too many appertures required
    0007512 NPPHPGL Allocating one DRAW RECORD
    0007513 NPPHPGL Allocating one FLASH RECORD
    0007515 NPPHPGL Failed to allocate penObject in PltMain
    0007517 NPPHPGL Failed assumption dpb->format == HPGL_FORMAT
    0007518 NPPHPGL Failed assumption DbView.boardXMin >= 0
    0007519 NPPHPGL Failed assumption DbView.boardYMin >= 0
    0007533 NPPCOMP local heap
    0007535 NPPCOMP Allocating buffer
    0007633 ORCBACK Failed assumption gatePin == NULL
    0007718 NPPHATCH Failed to allocate polyList in HatchObs
    0008758 MTBMAIN Failed to assign heap1 in mtbmain
    0008759 MTBMAIN Failed to assign heap2 in mtbmain
    0008760 MTBMAIN Failed to allocate LocTable in mtbmain
    0008761 MTBMAIN Failed to allocate LocTable in mtbmain
    0008762 MTBMAIN Failed to allocate Loc HeapSlice in mtbmain
    0008763 MTBMAIN Failed to allocate Loc HeapSlice in mtbmain
    0008788 MTBMAIN Failed to assign heap3 in mtbmain
    0009112 NPPRPT Allocating Drill Sort Table
    0010130 FNETMAIN Data Heap
    0010200 FNETLEX Failed assumption sourceFile
    0011111 PROTXCON "viaCode" out of range (1, DbView.viaMax)
    0011111 PROTXCMP "thruId" out of range (1, DbView.viaMax)
    0011111 PROTBNET "viaIndex" out of range (1, DbView.viaMax)
    0011111 PROTBCON "viaIndex" out of range (1, DbView.viaMax)
    0015200 ORCADLEX Failed assumption sourceFile
    0015230 ORCADMAN Data Heap
    0016201 WINHAT2 Failed to allocate hatchHeap
    0016202 WINHAT2 Failed to allocate polyList in HatchObs
    0016205 WINHAT2 Failed to increase polyList in HatchObs
    0016221 WINHAT2 Failed assumption polyPtr->hatchKind
    0016223 WINHAT2 Failed to allocate poly data in HatchObs
    0016237 WINHAT2 Bad drawing mode in drawHatchLine
    0016271 WINHAT2 Failed assumption polyPtr->hatchKind
    0016422 WINMNL Failed to allocate PackMap
    0016432 WINMNL Failed to allocate CompTable entry
    0016442 WINMNL Failed to allocate NetTable entry
    0016701 WINMENU2 Unknown command menu
    0016702 WINMENU2 Failed assumption AppendMenu (popupMenu, MF_SEPARATOR, 0, (LPSTR) NULL)
    0016704 WINMENU2 Failed assumption popupMenu
    0016706 WINMENU2 Failed assumption item != NULL
    0016708 WINMENU2 Failed assumption popupMenu
    0016735 WINMENU2 "lstrLen (acc)" out of range (0, 7)
    0016735 WINMENU2 "lstrLen (string)" out of range (1, 39)
    0016789 WINMENU2 Failed assumption popupMenu
    0016790 WINMENU2 Failed assumption popupItemCount < MAX_POPUP_ITEMS
    0016791 WINMENU2 Unrecognized hotkey
    0016792 WINMENU2 Failed assumption AppendMenu (popupMenu, MF_STRING, (UINT) id, (LPSTR) popupItem[popupItemCount].string)
    0016793 WINMENU2 Failed assumption AppendMenu (popupMenu, MF_OWNERDRAW, (UINT) id, (LPTSTR)id)
    0016795 WINMENU2 Failed assumption popupMenu
    0016796 WINMENU2 Failed assumption popupItemCount < MAX_POPUP_ITEMS
    0016797 WINMENU2 Failed assumption AppendMenu (popupMenu, MF_OWNERDRAW, (UINT)id, (LPTSTR)id)
    0016798 WINMENU2 Failed assumption popupMenu
    0016799 WINMENU2 Failed assumption popupItemCount < MAX_POPUP_ITEMS
    0016906 MZMAZE Failed assumption (SfView.xMax + 1) * (long) SfView.routeLayers < EXP_SIZE
    0017324 DBOBS Failed assumption obsPtr->crns < OBS_CRN_LIMIT
    0019035 MZCHECK2 Failed assumption object > 0
    0021105 DBIO Invalid filemode in DbOpenfile
    0021110 DBIO Failed assumption !inputFile
    0021111 DBIO Failed assumption !outputFile
    0021131 DBIO Failed assumption inputFile
    0021135 DBIO Failed assumption inputFile
    0021136 DBIO Failed assumption fseek (inputFile, offset, SEEK_SET) == 0
    0021140 DBIO Failed assumption inputFile
    0021143 DBIO Failed assumption outputFile
    0021148 DBIO mode must be 'r' or 'w'
    0021181 DBIO Failed assumption inputFile
    0021182 DBIO Failed assumption outputFile
    0021190 DBIO "ptr->sym.header.pads" out of range (0, SYM_PAD_LIMIT)
    0021190 DBIO "ptr->v70Sym.header.pads" out of range (0, SYM_PAD_LIMIT)
    0021191 DBIO "ptr->pack.header.pads" out of range (0, SYM_PAD_LIMIT)
    0021195 DBIO Failed assumption len <= NAME_STR_LIMIT + 1
    0021196 DBIO "len" out of range (1, LSTR_LIMIT + 1)
    0021197 DBIO Default kind in DbWrite
    0021255 DBDEFALT Default union kind in DbDefault
    0021272 DBDEFALT Unknown union kind in DbSizeOf
    0021302 DBLEV Failed assumption theDb
    0021303 DBLEV Failed assumption theDb
    0021304 DBLEV Failed assumption theDb
    0021306 DBLEV Failed assumption theDb
    0021307 DBLEV Failed assumption theDb
    0021308 DBLEV Failed assumption theDb
    0021309 DBLEV Failed assumption theDb
    0021312 DBLEV "theDb->header.levMax" out of range (1, LEV_ETCH_LIMIT)
    0021340 DBLEV "layer" out of range (0, LEV_ETCH_LIMIT)
    0021341 DBLEV "layer" out of range (0, LEV_ETCH_LIMIT)
    0021342 DBLEV "layer" out of range (0, LEV_ETCH_LIMIT)
    0021343 DBLEV "oldLayer" out of range (0, LEV_ETCH_LIMIT)
    0021344 DBLEV "newLayer" out of range (0, LEV_ETCH_LIMIT)
    0021345 DBLEV "oldLayer" out of range (0, LEV_ETCH_LIMIT)
    0021346 DBLEV "newLayer" out of range (1, theDb->header.levMax+1)
    0021375 DBLEV "layer" out of range (1, theDb->header.levMax)
    0021378 DBLEV Failed assumption theDb
    0021379 DBLEV "layer" out of range (0, theDb->header.levMax)
    0021382 DBLEV Failed assumption theDb
    0021386 DBLEV Failed assumption theDb
    0021387 DBLEV Failed assumption theDb
    0021391 DBLEV Expected lstrLen (defaultNames[layer*3 + 1]) <= 4
    0021392 DBLEV Failed assumption theDb
    0021400 DBCOMP Failed assumption theDb->comp.blockLimit == 0
    0021410 DBCOMP Failed assumption BLOCK_SIZE * (long) sizeof(COMP_VIEW) <= EXP_SIZE
    0021412 DBCOMP Too many components during CompCreate
    0021413 DBCOMP Not enough blocks to meet COMP_LIMIT
    0021414 DBCOMP Failed to allocate blockTable[blockLimit++] in CompCreate
    0021420 DBCOMP "index" out of range (1, theDb->header.compMax)
    0021422 DBCOMP Failed assumption blockPtr
    0021424 DBCOMP "index" out of range (1, theDb->header.compMax)
    0021426 DBCOMP Failed assumption blockPtr
    0021427 DBCOMP "index" out of range (1, theDb->header.compMax)
    0021434 DBCOMP "compPtr->symIndex" out of range (0, theDb->header.symMax)
    0021435 DBCOMP "compPtr->cluster" out of range (0, COMP_LIMIT)
    0021436 DBCOMP Failed assumption compRenumberHeap != 0
    0021450 DBCOMP "compIndex" out of range (1, theDb->header.compMax)
    0021467 DBCOMP "i" out of range (1, theDb->header.compMax)
    0021469 DBCOMP "j" out of range (1, theDb->header.compMax)
    0021482 DBCOMP Allocating renumbering heap
    0021483 DBCOMP Allocating renumbering table
    0021489 DBCOMP "compId" out of range (1, theDb->header.compMax)
    0021493 DBCOMP Failed assumption compId >= 0
    0021494 DBCOMP "symId" out of range (1, theDb->header.symMax)
    0021501 DBOBS3 Failed assumption theDb
    0021502 DBOBS3 Failed assumption theDb
    0021503 DBOBS3 Failed assumption theDb
    0021504 DBOBS3 Failed assumption theDb
    0021537 DBOBS3 "src->crns" out of range (0, OBS_CRN_LIMIT)
    0021581 DBOBS3 Failed assumption view->symId == 0
    0021583 DBOBS3 "view->symId" out of range (1, theDb->header.symMax)
    0021587 DBOBS3 Failed assumption compView.symIndex == view->symId
    0021601 DBTEXT Failed assumption theDb
    0021602 DBTEXT Failed assumption theDb
    0021603 DBTEXT Failed assumption theDb
    0021604 DBTEXT Failed assumption theDb
    0021605 DBTEXT Failed assumption theDb
    0021606 DBTEXT Failed assumption theDb
    0021607 DBTEXT Failed assumption theDb
    0021608 DBTEXT Failed assumption theDb
    0021609 DBTEXT Failed assumption theDb
    0021610 DBTEXT Failed to allocate theDb->text.txtTable in TextInit
    0021611 DBTEXT Failed to allocate theDb->text.symFirst in TextInit
    0021612 DBTEXT Failed to allocate theDb->text.symFirst in TextInit
    0021638 DBTEXT Failed assumption theDb->text.txtTable
    0021639 DBTEXT Failed assumption theDb->text.txtTable
    0021643 DBTEXT "symId" out of range (1, theDb->header.symMax)
    0021644 DBTEXT Too many Text pieces
    0021645 DBTEXT "compId" out of range (1, theDb->header.compMax)
    0021646 DBTEXT "txtId" out of range (1, theDb->header.txtMax)
    0021647 DBTEXT Failed to allocate theDb->text.txtTable in TextCreate
    0021649 DBTEXT "index" out of range (1, theDb->header.txtMax)
    0021650 DBTEXT "index" out of range (1, theDb->header.txtMax)
    0021651 DBTEXT "(short) view->type" out of range (0, TEXT_OTHER)
    0021652 DBTEXT Failed assumption view->width >= 0
    0021653 DBTEXT Failed assumption view->height >= 0
    0021654 DBTEXT Failed assumption view->radius >= 0
    0021655 DBTEXT "view->rotation" out of range (0, 4 * COMP_90_DEGREES)
    0021656 DBTEXT "(short) view->lev" out of range (0, theDb->header.levMax)
    0021657 DBTEXT "view->aspect" out of range (1, 1000)
    0021658 DBTEXT "view->charRot" out of range (0, 4* COMP_90_DEGREES)
    0021660 DBTEXT "index" out of range (1, theDb->header.txtMax)
    0021661 DBTEXT "i" out of range (1, theDb->header.txtMax)
    0021661 DBTEXT Can't allocate renumber table
    0021662 DBTEXT "j" out of range (1, theDb->header.txtMax)
    0021668 DBTEXT Failed assumption lstrLen(view->string)
    0021671 DBTEXT "textPtr->symId" out of range (0, theDb->header.symMax)
    0021672 DBTEXT Failed to allocate theDb->text.symFirst in addToLink
    0021675 DBTEXT "-textPtr->symId" out of range (0, theDb->header.compMax)
    0021676 DBTEXT Failed to allocate theDb->text.compFirst in addToLink
    0021680 DBTEXT "index" out of range (1, theDb->text.txtLimit)
    0021681 DBTEXT Failed assumption --count > 0
    0021682 DBTEXT Expected view->symId == 0
    0021683 DBTEXT Text not found on correct list
    0021684 DBTEXT Expected view->symId != 0
    0021687 DBTEXT Failed assumption theDb
    0021688 DBTEXT Failed assumption theDb
    0021691 DBTEXT Failed assumption theDb
    0021691 DBTEXT Failed to allocate theDb->text.txtTable in TextPut for first time
    0021692 DBTEXT Failed assumption theDb
    0021693 DBTEXT Failed assumption theDb
    0021694 DBTEXT Failed assumption theDb
    0021701 DBFONT Cannot read font file
    0021703 DBFONT Failed to read font file header
    0021710 DBFONT Font header format error
    0021711 DBFONT Font header format error
    0021712 DBFONT Font header format error
    0021715 DBFONT "(short) fontHeader.cellSize" out of range (0, MAX_CELL_SIZE)
    0021717 DBFONT "(short) fontHeader.numChars" out of range (1, MAX_FONT_CHARS)
    0021720 DBFONT Failed to allocate font charTable
    0021723 DBFONT Failed to read font char
    0021725 DBFONT "fontChar.index" out of range (1, MAX_FONT_CHARS)
    0021726 DBFONT "fontChar.segs" out of range (0, MAX_CHAR_SEGS)
    0021730 DBFONT Failed to allocate font segTable
    0021733 DBFONT Failed to read font segments
    0021741 DBFONT Failed assumption charTable
    0021775 DBFONT "charIdx" out of range (1, MAX_FONT_CHARS)
    0021776 DBFONT "charIdx" out of range (1, MAX_FONT_CHARS)
    0021807 DBLOAD Failed assumption theDb
    0021811 DBLOAD "size" out of range (0, LSTR_LIMIT)
    0021814 DBLOAD Failed assumption !dbFound
    0021817 DBLOAD "size" out of range (2, sizeof (ioBuff->conn))
    0021817 DBLOAD "size" out of range (2, sizeof (ioBuff->v70Conn))
    0021823 DBLOAD Expected CompSymNext (0, symIndex) == 0); // Shouldn't happen, but... ...
    0021830 DBLOAD Expected nameCount == 1
    0021837 DBLOAD Failed assumption nameCount < NAME_COUNT_LIMIT
    0021838 DBLOAD "size" out of range (0, NAME_STR_LIMIT+1)
    0021839 DBLOAD "nameCount" out of range (1, 3)
    0021843 DBLOAD Text attached to derived footprint
    0021845 DBLOAD undefined binaryType in DbLoad
    0021846 DBLOAD Expected nameCount == 1
    0021849 DBLOAD Failed assumption namesProcessed == nameCount
    0021851 DBLOAD Failed assumption nameCount == symPtr->header.pads + 1
    0021851 DBLOAD Failed assumption nameCount == v70SymPtr->header.pads + 1
    0021853 DBLOAD "nameCount" out of range (1, 3)
    0021854 DBLOAD Failed assumption size == sizeof (LEV_VIEW)
    0021855 DBLOAD Failed assumption nameCount == packPtr->header.pads * 2 + 1
    0021856 DBLOAD Failed assumption size == sizeof (THRU_VIEW)
    0021857 DBLOAD Expected nameCount == 1
    0021858 DBLOAD Expected nameCount == 1
    0021861 DBLOAD Expected nameCount == 1
    0021862 DBLOAD Failed assumption ioBuff->db.levMax > 0
    0021863 DBLOAD Failed assumption ioBuff->db.levMax <= LEV_ETCH_LIMIT
    0021865 DBLOAD Failed assumption ioBuff->db.gridDiv >= 0
    0021866 DBLOAD Failed assumption ioBuff->db.viaGrid >= 0
    0021873 DBLOAD Failed assumption theDb
    0021880 DBLOAD "binaryType" out of range (DEFAULT_BINARY, BINARY_TYPE_LIMIT - 1)
    0021887 DBLOAD "nameCount" out of range (1, 4)
    0021889 DBLOAD Expected nameCount == 0
    0021894 DBLOAD Expected nameCount == 3
    0021898 DBLOAD Default kind in DbLoad
    0021901 DBSAVE Failed assumption theDb
    0021945 DBSAVE undefined binaryType in DbSave
    0021976 DBSAVE "drillSymbols" out of range (0, DRILL_LIMIT + SPECIAL_SYM_LIMIT)
    0021980 DBSAVE "binaryType" out of range (DEFAULT_BINARY, BINARY_TYPE_LIMIT - 1)
    0021999 DBSAVE Security device failure
    0022010 DBERR Failed to allocate errTable in DbErrInit
    0022011 DBERR Failed assumption theDb
    0022012 DBERR Failed assumption theDb
    0022013 DBERR Failed assumption theDb
    0022014 DBERR Failed assumption theDb
    0022017 DBERR Failed assumption theDb
    0022023 DBERR Failed assumption theDb
    0022031 DBERR Failed to allocate errTable in ErrorPut for first time
    0022044 DBERR Too many Errors
    0022047 DBERR Failed to allocate errTable in DbErrorCreate
    0022049 DBERR "index" out of range (1, theDb->header.errMax)
    0022050 DBERR "index" out of range (1, theDb->header.errMax)
    0022051 DBERR "(short) ptr->kind" out of range (1, ERR_KIND_LIMIT)
    0022056 DBERR "(short) ptr->lev" out of range (0, theDb->header.levMax)
    0022060 DBERR "index" out of range (1, theDb->header.errMax)
    0022087 DBERR Failed assumption theDb
    0022091 DBERR Bad error type in ErrorTypeName
    0022093 DBERR Bad error type in ErrorIsSpacing
    0023002 ASCWDATA Failed assumption nameList
    0023004 ASCWDATA Failed assumption nameList[index]
    0023005 ASCWDATA Failed assumption nameCount < NAME_COUNT_LIMIT
    0023006 ASCWDATA Failed assumption len <= LSTR_LIMIT + 1
    0023007 ASCWDATA "nameIndex" out of range (0, nameCount)
    0023010 ASCWDATA Failed assumption nameCount < NAME_COUNT_LIMIT
    0023041 ASCWDATA Can't allocate compNameList
    0023042 ASCWDATA Failed assumption compNameList
    0023042 ASCWDATA Failed assumption symPinList
    0023043 ASCWDATA Can't allocate compNameList[index]
    0023050 ASCWDATA "compNo" out of range (1, MaxComp)
    0023051 ASCWDATA Can't allocate nameList
    0023052 ASCWDATA Failed assumption netNameList
    0023053 ASCWDATA Can't allocate netNameList[index]
    0023060 ASCWDATA "netNo" out of range (1, MaxNet)
    0023091 ASCWDATA Can't allocate compFrViaList
    0023092 ASCWDATA Failed assumption compFrViaList
    0023627 ASCWDATA Failed assumption nameCount == packPtr->header.pads * 2 + 1
    0023646 ASCWDATA Failed assumption netIndex <= NET_LIMIT
    0023876 DBLOAD3 Failed assumption sourceFile == NULL
    0023879 DBLOAD3 Failed assumption sourceFile != NULL
    0023888 DBLOAD3 Failed assumption compPtr->partName != 0
    0023897 DBLOAD3 LIBRARY not enabled
    0023987 ASCWDATA Can't allocate symPinList
    0026425 DBOBS3 "crn" out of range (0, obsPtr->crns - 1)
    0028692 DBALT Failed assumption theDb->alt.depth == 0
    0030511 WINPEN Allocate window's logical palette
    0031106 WINCTL Failed assumption Dlg->ctl
    0031107 WINCTL "just" out of range (0, CELL_LIMIT)
    0031109 WINCTL Multiply defined control
    0031181 WINCTL Too many controls
    0031257 WINMAIN Failed assumption ActiveWindow
    0031301 WINADD Control id not found in UDSetFocus
    0031308 WINDLG Dialog Heaps
    0031309 WINDLG Cannot allocate Dialog globals
    0031310 WINDLG Allocate control records
    0031313 WINDLG Failed assumption ourDlg->nestLevel == 0
    0031344 WINDLG Failed assumption Dlg != NULL
    0031345 WINDLG Failed assumption Dlg != NULL
    0031346 WINDLG Failed assumption Dlg != NULL
    0031346 WINDLG Failed assumption Dlg->dialogHandle != 0
    0031347 WINDLG Failed assumption Dlg != NULL
    0031352 WINDLG2 Failed assumption idx < Dlg->ctlMax
    0031352 WINDLG Failed assumption idx < Dlg->ctlMax
    0031356 WINDLG Failed assumption Dlg->dialogHandle != 0
    0031403 WINDRAW Bad via shape
    0031445 WINDRAW Failed assumption DATA->hDC
    0031446 WINDRAW Failed assumption (connPtr->crn[crn + 1].flags & CRN_ARC)
    0031453 WINDRAW Failed assumption DATA->hDC
    0031455 WINDRAW Failed assumption DATA->hDC
    0031615 WINDRAW2 "Ui->level" out of range (1, DbView.levMax)
    0031633 WINPEN Bad color rule
    0031637 WINDRAW2 Bad drawing mode in DrawRectangle
    0031638 WINDRAW2 Bad drawing mode in DrawRectangle
    0031666 WINDRAW2 "lev" out of range (0, DbView.levMax)
    0031684 WINPEN "(short) colorView.kind" out of range (0, TEXT_OTHER-1)
    0031685 WINPEN "(short) colorView.kind" out of range (0, OBS_OTHER-1)
    0031724 WINIPC Failed assumption atom
    0031752 WINIPC Failed assumption LayoutToOrCAPMessage != 0
    0031756 WINIPC Failed assumption backAtom
    0031772 WINIPC Failed assumption lstrLen (command) + lstrLen(parameters) < CMD_LINE_LIMIT
    0031817 WINSYS Failed assumption Ui
    0031818 WINSYS Failed assumption info
    0031819 WINSYS Failed assumption info->hWnd
    0031821 WINSYS Failed assumption idleCursorHandle = ...
    0031823 WINSYS Failed assumption commandCursorHandle = ...
    0031825 WINSYS Failed assumption helpCursorHandle = ...
    0031827 WINSYS Failed assumption dragCursorHandle = ...
    0031829 WINSYS Failed assumption noCursorHandle = ...
    0031831 WINSYS Failed assumption zoomCursorHandle = ...
    0031833 WINSYS Bad cursor shape
    0031835 WINSYS Failed assumption cursorHandle
    0031857 WINSYS Failed assumption ApplicWindow
    0031858 WINSYS Failed assumption info
    0031859 WINSYS Failed assumption info->hWnd
    0031873 WINQUERY Bad kind in UProbe
    0031890 WINSYS Cannot find layout.lic
    0031899 WINSYS Cannot find layout.dat
    0031935 WINFILE Expected DbView.valid
    0031990 WINFILE Cannot find layout.lic
    0031999 WINFILE Unexpected command
    0032037 WINOBS Bad drawing mode in DrawObsInstance
    0032046 WINDRAW3 Bad drawing mode in DrawTextSegs
    0032071 WINOBS "(short) kind" out of range (0, OBS_OTHER)
    0032072 WINOBS Expected DATA->hDC
    0032201 WINMENU Failed assumption accelTable
    0032203 WINMENU Too many hotkeys defined
    0032205 WINMENU Hotkey already defined (and different)
    0032207 WINMENU Failed assumption accelTable
    0032209 WINMENU Bad special accel chord
    0032216 WINMENU Failed assumption accelTable
    0032217 WINMENU unknown hotkey type
    0032219 WINMENU Bad pulldown
    0032221 WINMENU Can't find own menu items
    0032223 WINMENU Failed assumption subMenu
    0032225 WINMENU Failed assumption AppendMenu ( parentMenu, MF_POPUP, (UINT) subMenu, ...
    0032225 WINMENU Failed assumption AppendMenu ( mainMenu, MF_POPUP, (UINT) subMenu, ...
    0032227 WINMENU Failed assumption subMenu
    0032229 WINMENU Failed assumption addIsValid
    0032231 WINMENU Failed assumption menuPosition
    0032233 WINMENU Unrecognized hotkey
    0032235 WINMENU Failed assumption AppendMenu ( menuPosition, MF_STRING, (UINT) id, string)
    0032237 WINMENU Failed assumption subMenu
    0032239 WINMENU Failed assumption InsertMenu ( mainMenu, ...
    0032241 WINMENU Failed assumption subMenu
    0032243 WINMENU Failed assumption InsertMenu ( mainMenu, ...
    0032245 WINMENU Failed assumption subMenu
    0032247 WINMENU Failed assumption InsertMenu ( mainMenu, ...
    0032249 WINMENU Failed assumption mainMenu
    0032255 WINMENU Failed assumption SetMenu (hWnd, mainMenu)
    0032257 WINMENU Failed assumption addIsValid
    0032259 WINMENU "accel" out of range ('A', 'Z')
    0032261 WINMENU Failed assumption addIsValid
    0032263 WINMENU Failed assumption menuPosition
    0032265 WINMENU Failed assumption AppendMenu ( hMenuParent, MF_SEPARATOR, 0, NULL)
    0032265 WINMENU Failed assumption AppendMenu ( menuPosition, ...
    0032267 WINMENU Failed assumption addIsValid
    0032269 WINMENU Failed assumption accelPtr
    0032273 WINMENU Failed assumption mainMenu
    0032275 WINMENU Bad menu state
    0032279 WINMENU Failed assumption DeleteMenu ( mainMenu, ...
    0032281 WINMENU Failed assumption DeleteMenu ( mainMenu, ...
    0032283 WINMENU "newLevel" out of range (0, DbView.levMax)
    0032285 WINMENU "fKey" out of range (2, 10)
    0032287 WINMENU Failed assumption (lParam & 0x80000000) == 0
    0032391 WINPAINT Failed assumption obsPtr->symId == 0
    0032399 WINPAINT "id" out of range (IDM_L1, IDM_L1 + DbView.levMax - 1)
    0032561 WINZOOM Failed assumption DbView.viewWidth > 0
    0032562 WINZOOM Failed assumption DbView.viewHeight > 0
    0032585 WINZOOM Default id in ZoomCommand
    0032597 WINZOOM Failed assumption DbView.batchIndex == 0
    0032617 WINADD No such item in this dialog
    0032618 WINADD No such item in this dialog
    0032619 WINADD No such item in this dialog
    0032622 WINADD Failed assumption Dlg->nestLevel
    0032625 WINADD Unknown style in UDAddCombo
    0032628 WINADD Unknown style in UDAddButton
    0032629 WINADD Unknown style in UDAddStatic
    0032633 WINADD Failed assumption idx < Dlg->ctlMax
    0032636 WINADD Failed assumption idx < Dlg->ctlMax
    0032637 WINADD Failed assumption idx < Dlg->ctlMax
    0032645 ASCWDATA Failed assumption compIndex <= COMP_LIMIT
    0032647 WINADD Failed assumption idx < Dlg->ctlMax
    0032660 WINADD "item" out of range (1, ctl[idx].count)
    0032661 WINADD Failed assumption idx < Dlg->ctlMax
    0032662 WINADD Failed assumption ctl[idx].class != COMBO_CLASS); /* Not supported */ ...
    0032662 WINADD Failed assumption ctl[idx].class != COMBO_CLASS); /* Use UDGetListSelection */ ...
    0032663 WINADD Failed assumption len <= maxLen
    0032664 WINADD "item" out of range (1, ctl[idx].count)
    0032665 WINADD Failed assumption idx < Dlg->ctlMax
    0032666 WINADD Failed assumption idx < Dlg->ctlMax
    0032667 WINADD Failed assumption idx < Dlg->ctlMax
    0032668 WINADD Failed assumption idx < Dlg->ctlMax
    0032669 WINADD Failed assumption idx < Dlg->ctlMax
    0032670 WINADD Failed assumption item <= ctl[idx].itemMax
    0032671 WINADD Failed assumption index > 0
    0032673 WINADD Could not find control id
    0032675 WINADD Control id not found in UDSetButtonState
    0032678 WINADD Unknown style
    0032679 WINADD Control id not found in UDIsButtonChecked
    0032685 WINADD Failed assumption ctl[idx].count <= ctl[idx].itemMax
    0032812 WINASK AskInterrupt terminated (debug version only)
    0032814 WINASK AskInterrupt Terminated (debug version only)
    0032903 WININIT Incompatible library
    0032908 WININIT Cannot find LAYOUT.CTL
    0032909 WININIT Cannot read LAYOUT.CTL
    0033130 WINPREF undefined preference
    0033132 WINPREF undefined preference
    0033133 WINPREF undefined preference
    0033134 WINPREF undefined preference
    0033135 WINPREF undefined preference
    0033141 WINASK2 ShowAbout not supported in WIN3_VERSION
    0033195 WINASK2 GetOpenFileName failed
    0033196 WINASK2 GetSaveFileName failed
    0033208 WINQUERY Failed assumption hWnd
    0033210 WINQUERY Failed assumption data
    0033215 WINLIBM Class not registered
    0033215 WINQUERY Class not registered
    0033221 DBATTR "tableIndex" out of range (0, queryNumberOfSymAtr)
    0033222 DBATTR "tableIndex" out of range (0, queryNumberOfNetAtr)
    0033223 DBATTR "tableIndex" out of range (0, queryNumberOfPinAtr)
    0033224 DBATTR Bad kind in GetQueryAttrib
    0033230 WINQUERY Failed assumption hWnd
    0033236 WINQUERY Failed assumption data
    0033237 WINQUERY Failed assumption data
    0033241 WINQUERY Not enough RAM for query data
    0033242 WINQUERY Failed assumption hWnd);           /* Unable to create window */ ...
    0033244 WINQUERY Failed assumption hWnd != NULL
    0033245 WINQUERY Failed assumption data
    0033246 WINQUERY Failed assumption data
    0033247 WINQUERY Expected AltGetDepth () == 0, 0
    0033248 WINQUERY Expected DragProc == NULL
    0033249 WINQUERY Failed assumption data
    0033251 WINMENU Failed assumption !accelTable
    0033256 WINQUERY Expected Ui->graphicsMode
    0033270 WINQUERY Failed assumption data
    0033271 WINQUERY Failed assumption hWnd
    0033272 WINQUERY Failed assumption Ui
    0033278 WINQUERY Failed assumption index >= 1
    0033279 WINQUERY Failed assumption offset >= 0
    0033282 WINQUERY Failed assumption tmFontInfo.tmHeight > 0
    0033283 WINQUERY Failed assumption data
    0033284 WINQUERY Failed assumption tmFontInfo.tmAveCharWidth > 0
    0033290 WINQUERY Expected offset == 0
    0033291 WINQUERY Expected offset == 0
    0033293 WINQUERY Expected offset == 0
    0033294 WINQUERY Expected offset == 0
    0033295 WINQUERY Expected offset == 0
    0033296 WINQUERY Expected offset == 0
    0033297 WINQUERY Expected offset == 0
    0033335 WINALT Bad conn draw mode in DrawAlt
    0033373 WINALT ALT kind not supported
    0033374 WINALT ALT kind not supported
    0033375 WINALT ALT kind not supported
    0033376 WINALT ALT kind not supported
    0033380 WINALT Expected AltGetDepth () > 0, 1
    0033381 WINALT Expected AltGetDepth () > 0, 1
    0033382 WINALT Expected depth > 0, 1
    0033383 WINALT Expected AltGetDepth () > 0, 1
    0033384 WINALT Expected AltGetDepth () > 0, 1
    0033385 WINALT Expected AltGetMax () > 0
    0033402 WINSHOW Failed assumption linenum >= 0
    0033406 WINSHOW Can't allocate table
    0033408 WINSHOW Can't allocate copy of string
    0033475 WINEDITP Failed assumption EDIT->printDC
    0033510 WINREC Failed assumption !RecorderIsActive
    0033632 WINDRAW5 Bad shape in DrawPad
    0033640 WINDRAW4 Bad drawing mode in DrawCluster
    0033650 WINDRAW5 Bad drawing mode in DrawPad
    0033660 WINDRAW4 Failed assumption DATA->hDC
    0033661 WINDRAW4 Bad drawing mode in drawClusterLabel
    0033671 WINDRAW4 "symIndex" out of range (1, DbView.symMax)
    0033674 WINDRAW4 "pinNum" out of range (1, symPtr->header.pads)
    0033683 WINDRAW4 Failed assumption DATA->hDC
    0033698 WINDRAW4 Failed assumption DATA->hDC
    0033701 WINHATCH Failed to allocate hatchHeap
    0033702 WINHATCH Failed to allocate polyList in HatchObs
    0033705 WINHATCH Failed to increase polyList in HatchObs
    0033706 WINHATCH Failed to allocate poly data in HatchObs
    0033723 WINHATCH Failed to allocate poly data in HatchObs
    0033737 WINHATCH Bad drawing mode in drawHatchLine
    0033771 WINHATCH Failed assumption hatchKind
    0033782 WINHATCH Failed assumption obsPtr->lev
    0033804 WINDEBUG Failed assumption logHeap != 0
    0033870 WINDEBUG Failed to allocate new message record
    0033954 WINSTAT Failed assumption hDC != 0
    0033956 WINSTAT Failed assumption hDC
    0033957 WINTOOL Unknown case in UGlobalStatus
    0033972 WINSTAT Expected LangTest ((LANG_ID_TYPE) helpId+1, ...
    0033972 WINSTAT Failed assumption gaugeMax == 0
    0033973 WINSTAT Failed assumption maxVal > 0
    0033974 WINSTAT Failed assumption gaugeMax > 0
    0033975 WINSTAT Failed assumption gaugeMax > 0
    0033976 WINSTAT "val" out of range (0, gaugeMax)
    0033979 WINSTAT Expected info
    0033982 WINSTAT Can't allocate info text area
    0033985 WINSTAT Failed assumption tmFontInfo.tmHeight > 0
    0033986 WINSTAT Failed assumption info
    0034101 WINLIBM Expected localHeap == 0
    0034101 WINBROWS Failed assumption localHeap == 0
    0034102 WINLIBM Expected fpListHeap == 0
    0034102 WINBROWS Failed assumption fpListHeap == 0
    0034109 UIINIT Cannot find LAYOUT.FNT
    0034130 WINLIBM Failed assumption lev != 0
    0034131 WINFRAME Failed assumption dwp
    0034131 WINLIBM Failed assumption lev != 0
    0034133 URINIT Security device missing
    0034134 WINLIBM Failed assumption DbLoad (fullName, DEFAULT_BINARY)
    0034134 WINBROWS Failed assumption DbLoad (fullName, DEFAULT_BINARY)
    0034135 URINIT Security device missing
    0034136 WINLIBM Failed assumption dlgReturnDb != 0
    0034150 WINFRAME Failed assumption dwp
    0034151 WINFRAME Failed assumption dwp
    0034156 WINLIBM Failed assumption localHeap == 0
    0034157 WINLIBM Failed assumption fpListHeap == 0
    0034167 WINFRAME Failed assumption RecordStart ("TEST.REC")
    0034172 WINFRAME Failed assumption GlobalGetAtomName (atom, string, LSTR_LIMIT)
    0034178 WINFRAME Failed assumption strlen (netListFilename) != 0
    0034181 WINFRAME failed timer test
    0034191 WINFILE Failed assumption DbView.backupInterval >= 0
    0034199 WINFILE Security device failed at least one query
    0034210 WINGRAPH Failed assumption data
    0034215 WINGRAPH Class not registered
    0034235 WINGRAPH Failed assumption BusyProc
    0034241 WINGRAPH Not enough RAM for edit data
    0034242 WINGRAPH Failed assumption graphicsWindow); /* Unable to create window */ ...
    0034294 WINGRAPH Unknown window kind
    0034310 WINEDITW Failed assumption EditData
    0034315 WINEDITW Class not registered
    0034341 WINEDITW Not enough RAM for edit data
    0034342 WINEDITW Failed assumption editWindow); /* Unable to create window */ ...
    0034358 WINEDITW Failed assumption EDIT
    0034359 WINEDITW Failed assumption Ui
    0034382 WINEDITW Failed assumption tmFontInfo.tmHeight > 0
    0034384 WINEDITW Failed assumption tmFontInfo.tmAveCharWidth > 0
    0034407 WINEDITP Failed assumption rows % rowsPerRecord == 0
    0034422 WINEDITP "col" out of range (0, COLUMN_LIMIT)
    0034423 WINEDITP header text
    0034426 WINEDITP "col" out of range (0, COLUMN_LIMIT)
    0034427 WINEDITP "row" out of range (0, EDIT->rowMax-2)
    0034464 WINEDITP Failed assumption pen
    0034465 WINEDITP Failed assumption EDIT->printDC
    0034466 WINEDITP Failed assumption pen
    0034476 WINEDITP "col" out of range (0, COLUMN_LIMIT)
    0034484 WINEDITP "EDIT->headerMax" out of range (1, HEADER_LIMIT)
    0034512 WINEDITC Failed assumption row < EDIT->rowMax
    0034525 WINEDITC Failed assumption BusyProc
    0034572 WINEDITC Failed assumption row < EDIT->rowMax
    0034767 WINPREF Expected DbView.pragma != 0
    0034768 WINPREF Expected DbView.pragma != 0
    0034787 WINPREF No tool bar type
    0034822 WINNEW Security device missing
    0034824 WINNEW Security device missing
    0034851 UIWND Security device missing
    0034852 UIWND Security device missing
    0034861 WINNEW Failed assumption info
    0034862 WINNEW Failed assumption ui
    0034904 WINTOOL "lev" out of range (0, DbView.levMax)
    0034910 WINTOOL Expected data->kind == BITMAP_TOOL
    0034911 WINTOOL Failed assumption data->hNormal
    0034912 WINTOOL Failed assumption BitBlt (hDC, ...
    0034913 WINTOOL Failed assumption hDC
    0034914 WINTOOL Failed assumption hDC
    0034915 WINTOOL Normal bitmap not found
    0034916 WINTOOL Grayed bitmap not found
    0034916 WINTOOL Unknown tool type
    0034917 WINTOOL Highlighted bitmap not found
    0034917 WINTOOL Unknown tool type
    0034931 WINTOOL Failed assumption hDC
    0034932 WINTOOL Failed assumption hSrcDC
    0034943 WINTOOL Failed assumption totalTools < MAX_TOOLS
    0034945 WINTOOL Failed assumption totalTools < MAX_TOOLS
    0034961 WINTOOL Expected rect.left == 0
    0034962 WINTOOL Expected rect.top == 0
    0034971 WINTOOL Bad menu state
    0034981 WINTOOL Can't allocate toolbar table
    0034982 WINTOOL Failed assumption tmFontInfo.tmHeight > 0
    0034983 WINTOOL "lev" out of range (0, DbView.levMax)
    0034984 WINTOOL Failed assumption dragging == FALSE
    0034984 WINTOOL Failed assumption tmFontInfo.tmAveCharWidth > 0
    0034985 WINTOOL Failed assumption tmFontInfo.tmHeight > 0
    0034987 WINTOOL Expected selectedTool >= 0
    0034990 WINTOOL "button" out of range (NO_AREA + 1, (totalTools-1))
    0035002 WINPEN Heap for caching drawing information
    0035010 WINPEN Bad drawing mode in PenMode
    0035012 WINPEN Not enough RAM for altLev Table
    0035017 WINPEN Failed assumption localHeap
    0035032 WINPEN Expected DeleteObject(currentBrush)
    0035033 WINPEN Failed assumption (hPalette = CreatePalette (palettePtr))
    0035033 WINPEN Expected (hPalette = CreatePalette (palettePtr))
    0035034 WINPEN Failed assumption SelectPalette (DATA->hDC, hPalette, NO)
    0035035 WINPEN Expected SelectPalette (DATA->hDC, ...
    0035036 WINPEN Expected DeleteObject (hPalette)
    0035042 WINPEN Failed assumption pen
    0035044 WINPEN Expected DeleteObject(currentPen)
    0035050 WINPEN unable to assign palette
    0035052 WINPEN Failed assumption pen
    0035053 WINPEN Expected DeleteObject(currentPen)
    0035060 WINPEN Pen table not initialized
    0035063 WINPEN Color class not recognized
    0035065 WINPEN Pen table not initialized
    0035068 WINPEN Color class not recognized
    0035072 WINPEN Bad color in initColors
    0035074 WINPEN Expected DeleteObject (oldPalette)
    0035077 WINPEN Expected SelectObject (DATA->hDC, GetStockObject (HOLLOW_BRUSH))
    0035078 WINPEN Expected SelectObject (DATA->hDC, GetStockObject (BLACK_PEN))
    0035081 WINPEN Expected DeleteObject(currentPen)
    0035082 WINPEN Failed assumption brush
    0035083 WINPEN Expected oldBrush == currentBrush
    0035084 WINPEN Expected DeleteObject(currentBrush)
    0035101 WINPAIR Allocate memory for finding duplicates
    0035102 WINPAIR Failed to allocate duplicate list
    0035121 WINPAIR Failed assumption x1 >= ptr->x1
    0035122 WINPAIR Failed assumption x2 <= ptr->x2
    0035123 WINPAIR Failed to allocate duplicate list entry
    0035167 WINPAIR Expected 1 == 0
    0037354 COMMEM "size" out of range (0, 0x7fff)
    0037355 COMMEM "size" out of range (0, 0x7fff)
    0037370 COMMEM Failed assumption header->magicNumber == MAGIC_NUMBER
    0037371 COMMEM Failed assumption header->magicNumber == MAGIC_NUMBER
    0037372 COMMEM Failed assumption header->magicNumber == MAGIC_NUMBER
    0037373 COMMEM Failed assumption header->magicNumber == MAGIC_NUMBER
    0037379 COMMEM "unionSize" out of range (0, unionLimit)
    0037380 COMMEM "unionSize" out of range (0, unionLimit)
    0037381 COMMEM Failed assumption unionLimit < UNION_DEPTH_LIMIT
    0037382 COMMEM Failed assumption unionPtr
    0037383 COMMEM Failed Union Alloc
    0037384 COMMEM Failed assumption unionPtr
    0037385 COMMEM Failed assumption unionLimit < UNION_DEPTH_LIMIT
    0037386 COMMEM Failed assumption unionStack[unionSize].ptr == unionPtr
    0037387 COMMEM Failed assumption handle
    0037390 COMMEM Failed assumption handle
    0037391 COMMEM Failed assumption handle
    0037394 COMMEM Failed Union Realloc
    0037401 COMHEAP Failed assumption ! heapInUse
    0037405 COMHEAP "heap" out of range (1, MAX_HEAP_ID)
    0037406 COMHEAP Failed assumption ptr
    0037407 COMHEAP Failed assumption ptr
    0037409 COMHEAP Failed assumption pagePtr[pagesAllocated]
    0037413 COMHEAP Failed assumption heapInUse
    0037414 COMHEAP Failed assumption heapInUse
    0037415 COMHEAP Failed assumption heapInUse
    0037416 COMHEAP Failed assumption heapInUse
    0037417 COMHEAP Failed assumption heapInUse
    0037418 COMHEAP Failed assumption heapInUse
    0037425 COMHEAP "heap" out of range (1, MAX_HEAP_ID)
    0037426 COMHEAP "heap" out of range (1, MAX_HEAP_ID)
    0037430 COMHEAP "size" out of range (1, EXP_SIZE)
    0037450 COMHEAP Failed assumption header->magicNumber == MAGIC_NUMBER + heap
    0037451 COMHEAP Failed assumption oldHeader->magicNumber == MAGIC_NUMBER + heap
    0037452 COMHEAP Failed assumption header->size >= header->next->size
    0037455 COMHEAP Failed assumption header->next->prev == header
    0037457 COMHEAP Failed assumption header->magicNumber == MAGIC_NUMBER2 + heap
    0037458 COMHEAP Failed assumption header->next->prev == header
    0037459 COMHEAP Failed assumption header->prev->next == header
    0037460 COMHEAP Failed assumption header->prev->next == header
    0037462 COMHEAP Failed assumption header->size > list->size
    0037463 COMHEAP "heap" out of range (1, MAX_HEAP_ID)
    0037464 COMHEAP Failed assumption heapOwner[heap]
    0037465 COMHEAP Failed assumption header == &activeList[heap]
    0037466 COMHEAP Failed assumption header == &freeList[heap]
    0037470 COMHEAP "size" out of range (1, EXP_SIZE - sizeof (MEM_HEADER))
    0037471 COMHEAP "size" out of range (1, EXP_SIZE - sizeof (MEM_HEADER))
    0037475 COMHEAP "heap" out of range (HEAP_ANON+1, MAX_HEAP_ID)
    0037480 COMHEAP Anon
    0037481 COMHEAP DB
    0037482 COMHEAP ALT
    0037483 COMHEAP Failed assumption totalPages == pagesAllocated
    0037484 COMHEAP SORT
    0037486 COMHEAP SEG
    0037487 COMHEAP SEG2
    0037488 COMHEAP SEG3
    0037490 COMHEAP PLACE
    0037812 COMPARSE Not enough RAM for Flags Table
    0037814 COMPARSE Failed assumption Flags
    0037822 COMPARSE Not enough RAM for LoadFilename
    0037824 COMPARSE Failed assumption LoadFilename
    0037832 COMPARSE Not enough RAM for SaveFilename
    0037834 COMPARSE Failed assumption SaveFilename
    0037842 COMPARSE Not enough RAM for StratFilename
    0037843 COMPARSE Not enough RAM for SixthFilename
    0037843 COMPARSE Not enough RAM for FifthFilename
    0037843 COMPARSE Not enough RAM for FourthFilename
    0037844 COMPARSE Failed assumption StratFilename
    0037846 COMPARSE Failed assumption SixthFilename
    0037846 COMPARSE Failed assumption FifthFilename
    0037846 COMPARSE Failed assumption FourthFilename
    0038011 WINHELP Failed assumption searchString[0] != '\0'
    0038401 COMFIND Error accessing Registry root or subkey
    0038680 COMLEV Default case in AskLevClass
    0038690 COMLEV Default case in LevClassInit
    0038711 COMLANG Failed assumption blockBuffer[MAGIC_NUMBER_OFFSET] == MAGIC_NUMBER
    0038712 COMLANG "sizeOfDirectory" out of range (1,  BLOCK_LIMIT - DATA_OFFSET)
    0038713 COMLANG Failed assumption dirHandle
    0038714 COMLANG Failed assumption directory
    0038720 COMLANG LangLoad ID not found
    0038721 COMLANG LangStr not found
    0038725 COMLANG LangCache not found
    0038730 COMLANG Language subsystem not yet initialized
    0038735 COMLANG Failed assumption blockBuffer[MAGIC_NUMBER_OFFSET] == MAGIC_NUMBER
    0039165 ECOMAIN Failed assumption oldDatumX == DbView.datumX
    0039166 ECOMAIN Failed assumption oldDatumY == DbView.datumY
    0039190 ECOMAIN Data Heap
    0039211 ECOREAD Error allocating LevTable
    0039212 ECOREAD Error allocating ThruTable
    0039213 ECOREAD Error allocating SymTable
    0039214 ECOREAD Error allocating PackTable
    0039215 ECOREAD Error allocating CompTable
    0039216 ECOREAD Error allocating NetTable
    0039218 ECOREAD Error allocating ObsTable
    0039219 ECOREAD Error allocating TextTable
    0039220 ECOREAD Error allocating nameList
    0039221 ECOREAD Error allocating SymNameTable
    0039230 ECOREAD "nameCount" out of range (1, 3)
    0039231 ECOREAD Error allocating lev record
    0039232 ECOREAD Error allocating connection record
    0039233 ECOREAD Failed assumption connRecordPtr->connId == connIndex
    0039234 ECOREAD Failed assumption connIndex == 0
    0039235 ECOREAD Failed assumption connRecordPtr->connId == connIndex
    0039236 ECOREAD Failed assumption connIndex == 0
    0039241 ECOREAD Failed assumption nameCount == 1
    0039242 ECOREAD Error allocating thru record
    0039243 ECOREAD Error reallocating thru table
    0039244 ECOREAD Error reallocating pack table
    0039245 ECOREAD Failed assumption nameCount == unionPtr->sym.header.pads + 1
    0039245 ECOREAD Failed assumption nameCount == ptr->header.pads + 1
    0039246 ECOREAD Error allocating symbol record
    0039247 ECOREAD Error reallocating sym table
    0039248 ECOREAD Failed assumption nameCount ==  2 * packPtr->header.pads + 1
    0039249 ECOREAD Error allocating package record
    0039250 ECOREAD Failed assumption nameCount >= 1
    0039251 ECOREAD Error allocating comp record
    0039252 ECOREAD Error allocating symname record
    0039253 ECOREAD Error reallocating comp table
    0039254 ECOREAD Error reallocating symName table
    0039255 ECOREAD Failed assumption nameCount == 1
    0039256 ECOREAD Error allocating net record
    0039257 ECOREAD Error reallocating net table
    0039260 ECOREAD "nameCount" out of range (0, 1)
    0039261 ECOREAD Error allocating connection record
    0039267 ECOREAD "packIndex" out of range (1, DbViewB.packMax)
    0039270 ECOREAD Failed assumption nameCount == 1
    0039271 ECOREAD Error allocating obs record
    0039272 ECOREAD Error reallocating obs table
    0039273 ECOREAD Failed assumption nameCount == 1
    0039274 ECOREAD Error allocating text record
    0039275 ECOREAD Error reallocating text table
    0039276 ECOREAD Failed assumption nameCount == 1
    0039277 ECOREAD Error allocating attribute record
    0039278 ECOREAD Failed assumption nameCount == 3
    0039279 ECOREAD Error allocating text record
    0039283 ECOREAD Error allocating revised pack record
    0039285 ECOREAD Failed assumption fakeSym->header.flags & SYM_HOLDER
    0039291 ECOREAD Failed assumption nameCount < NAME_COUNT_LIMIT
    0039292 ECOREAD Failed assumption nameList
    0039305 ECOMAP Failed assumption connRecordPtr->connId == connIndexB
    0039311 ECOMAP Error allocating LevAB
    0039312 ECOMAP Error allocating LevBA
    0039315 ECOMAP Error allocating ThruAB
    0039316 ECOMAP Error allocating ThruBA
    0039317 ECOMAP Error allocating SymAB
    0039318 ECOMAP Error allocating SymBA
    0039319 ECOMAP Error allocating PackAB
    0039320 ECOMAP Error allocating PackBA
    0039333 ECOMAP "connRecordPtr->compId" out of range (1, DbViewB.compMax)
    0039334 ECOMAP "connRecordPtr->netId" out of range (1, DbViewB.netMax)
    0039335 ECOMAP "connRecordPtr->compId" out of range (1, DbViewB.compMax)
    0039336 ECOMAP "connRecordPtr->netId" out of range (1, DbViewB.netMax)
    0039351 ECOMAP Error allocating CompAB
    0039352 ECOMAP Error allocating compBA
    0039353 ECOMAP Error allocating NetAB
    0039354 ECOMAP Error allocating NetBA
    0039373 ECOMAP Error allocating ObsAB
    0039374 ECOMAP Error allocating ObsBA
    0039375 ECOMAP Error allocating TxtAB
    0039376 ECOMAP Error allocating TxtBA
    0039393 ECOMAP Failed assumption connRecordPtr->connId == connIndexB
    0039398 ECOMAP "derivedIndex" out of range (1, DbView.symMax)
    0039431 ECOMERGE Failed assumption packAIndex <= maxPacks
    0039441 ECOMERGE Failed assumption thruAIndex <= maxThrus
    0039451 ECOMERGE Failed assumption symAIndex <= maxSyms
    0039461 ECOMERGE Failed assumption compAIndex <= maxComps
    0039471 ECOMERGE Failed assumption netAIndex <= maxNets
    0039472 ECOMERGE Failed assumption obsAIndex <= maxObs
    0039473 ECOMERGE Failed assumption txtAIndex <= maxTxt
    0039481 ECOMERGE Error reallocating ThruAB
    0039482 ECOMERGE Error reallocating SymAB
    0039483 ECOMERGE Error reallocating CompAB
    0039484 ECOMERGE Error reallocating NetAB
    0039485 ECOMERGE Error reallocating PackAB
    0039486 ECOMERGE Error reallocating ObsAB
    0039487 ECOMERGE Error reallocating TxtAB
    0039501 ECOCONN Failed assumption connRecordPtr->pinNameId
    0039505 ECOCONN Error allocating netModified
    0039510 ECOCONN Failed assumption connRecordPtr->connId == connIndex
    0039511 ECOCONN Failed assumption connRecordPtr->connId == connIndex
    0039512 ECOCONN Failed assumption connIndex == 0
    0039513 ECOCONN Failed assumption connIndex == 0
    0039514 ECOCONN Failed assumption connRecordPtr->connId == connBIndex
    0039515 ECOCONN Failed assumption connBIndex == 0
    0039557 ECOCONN Error allocating netPad entry
    0039569 ECOCONN "netId" out of range (1, DbView.netMax)
    0039576 ECOCONN Failed assumption connRecordPtr->connPtr == NULL
    0039577 ECOCONN Failed assumption compId
    0039585 ECOCONN Error allocating netPad
    0039621 ECODLG Failed to alloc partNameTable
    0039636 ECODLG Failed to alloc lib name buffer
    0039644 ECODLG Failed to alloc libNameTable
    0039646 ECODLG Failed to alloc savePartName buffer
    0039671 ECODLG Failed to alloc successList
    0039672 ECODLG Failed to alloc successPair buffer
    0041082 PADXMAIN Expected ComPushDir (TCH_LIB)
    0041086 PADXMAIN Error allocating CompTyp
    0041531 PADXPAR Error reallocating CompTyp
    0042567 PADBCONN Failed assumption connView.net == netIndex
    0042587 PADBCONN Allocating appHashTable
    0043193 MINXMAIN "obsPtr->symId" out of range (1, DbView.symMax)
    0043194 MINXMAIN "-obsPtr->symId" out of range (1, DbView.compMax)
    0043220 MINXLEX Failed assumption sourceFile
    0043265 MINXLEX Failed assumption ptr->next == NULL
    0043602 MINWMAIN Failed assumption nameList
    0043604 MINWMAIN Failed assumption nameList[index]
    0043610 MINWMAIN Failed assumption nameCount < NAME_COUNT_LIMIT
    0043627 MINWMAIN Failed assumption nameCount == packPtr->header.pads * 2 + 1
    0043645 MINWMAIN Failed assumption compIndex <= COMP_LIMIT
    0043646 MINWMAIN Failed assumption netIndex <= NET_LIMIT
    0043784 MINBMAIN Failed assumption symId
    0043786 MINBMAIN Failed assumption compId >= 0
    0043787 MINBMAIN Failed assumption packId >= 0
    0043788 MINBMAIN Failed assumption netId >= 0
    0043789 MINBMAIN Failed assumption compId >= 0
    0043791 MINBMAIN "pinId" out of range (0, symPtr->header.pads)
    0043940 MINWMAIN "nameIndex" out of range (0, nameCount)
    0043943 MINWMAIN Failed assumption nameCount < NAME_COUNT_LIMIT
    0043945 MINWMAIN Failed assumption len <= LSTR_LIMIT + 1
    0045010 MPXFILE "rotation" out of range (0, 3)
    0045031 MPXPTAB Failed assumption PCADTableHeadHeap > 0
    0045033 MPXPTAB Expected PCADTableHead[type].table[count] == NULL
    0045033 MPXPTAB Expected PCADTableHead[type].table[0] == NULL
    0045034 MPXPTAB Expected PCADTableHead[type].drillSize[count] == 0
    0045034 MPXPTAB Expected PCADTableHead[type].padStackNameId[count] == 0
    0045034 MPXPTAB Expected PCADTableHead[type].drillSize[0] == 0
    0045034 MPXPTAB Expected PCADTableHead[type].padStackNameId[0] == 0
    0045035 MPXPTAB Failed assumption PCADTableHead[type].drillHeap > 0
    0045035 MPXPTAB Failed assumption PCADTableHead[type].drillHeap == 0
    0045036 MPXPTAB Failed assumption type < PCAD_TABLE_TYPE_LIMIT
    0045037 MPXPTAB Failed assumption PCADTableHead[type].tableHeap == 0
    0045038 MPXPTAB Failed assumption PCADTableHead[type].tableHeap > 0
    0045038 MPXPTAB Failed assumption PCADTableHead[type].nameHeap == 0
    0045039 MPXPTAB Failed assumption PCADTableHead[type].nameHeap > 0
    0045051 MPXPTAB Failed assumption PCADTableHeadHeap > 0
    0045159 MPBNET "viaIndex" out of range (2, DbView.viaMax)
    0045223 PROTXWIN Bad layer type in updateStrat
    0045231 MPXPTAB Failed assumption PCADTableHead[type].table[index] != NULL
    0045233 MPXPTAB Failed assumption sizeof (RAW_LEVEL_DATA) < sizeof (UNION_VIEW)
    0045234 MPXMAIN Failed assumption dbView.userDiv == 6000
    0045234 MPXPTAB Failed assumption prevIndex == index
    0045234 MPXPTAB Failed assumption obsPtr->crns <= OBS_CRN_LIMIT
    0045236 MPXPTAB Failed to allocate errTable in DbErrorCreate
    0045236 MPXPTAB Failed assumption PCADTableHead[type].max == 0
    0045236 MPXPTAB Failed assumption prevIndex == outIndex
    0045239 MPXPTAB Expected layerNameID > 0
    0045239 MPXPTAB Expected rawLevelPtr->layerNameID > 0
    0045239 MPXPTAB Failed assumption layerNameID > 0
    0045239 MPXPTAB Expected ((foundFirst == YES) && (foundSecond == YES))
    0045247 MPXPTAB Failed assumption rawLevelPtr->obsPtr != NULL
    0045248 MPXPTAB Failed assumption rawLevelPtr->obsPtr->crns <= OBS_CRN_LIMIT
    0045282 MPXMAIN Expected ComPushDir (TCH_LIB)
    0045297 MPXMAIN Failed assumption ObsLinkTable[thruId] != NULL
    0045298 MPXMAIN Failed assumption ObsLinkTable[thruId][lev] != NULL
    0045298 MPXPTAB Expected padstackDrill >= 0
    0045367 MPXFILE Expected shape == POLYGON_PAD
    0045607 MPXCOMP Failed assumption PadIndex
    0045671 MPXCOMP "symPtr->pad[pinIndex].thru" out of range (dbView.viaMax + 1, dbView.thruMax)
    0045672 MPXCOMP "symPtr->pad[tmpCount].thru" out of range (dbView.viaMax + 1, dbView.thruMax)
    0045672 MPXSYM "newThruIndex" out of range (dbView.viaMax + 1, dbView.thruMax)
    0045823 MPXPTAB Expected lastLayerNameId == layerNameId
    0045823 MPXPTAB Expected lastIndex == index
    0045823 MPXPTAB Expected lastType == type
    0045847 MPXPTAB Failed assumption rawLevelPtr->obsPtr != NULL
    0045848 MPXPTAB Failed assumption rawLevelPtr->obsPtr->crns <= OBS_CRN_LIMIT
    0045876 MPXPAD Failed assumption returnedVia == via
    0045878 MPXPAD Failed assumption returnedVia == 1
    0045883 MPXPTAB Failed assumption inIndex >= 0
    0045886 MPXPTAB Failed assumption outIndex >= 0
    0049025 TANGMAIN Heap Map
    0049082 TANGMAIN Expected ComPushDir (TCH_LIB)
    0049111 TANGWIN Bad layer class in updateStrat
    0050098 DBATTR Unknown case in SchemAttribLimit
    0050137 UIAUTO Failed assumption SfView.sweepPrimary == SF_SWEEP_NEXT
    0050157 UIAUTO Security device missing
    0050158 UIAUTO Security device missing
    0050182 UIAUTO Security device missing
    0050184 UIAUTO Security device missing
    0050190 UIAUTO Failed assumption Ui->windowType == IDS_ROUTE
    0050191 UIAUTO Failed assumption Ui->windowType == IDS_ROUTE
    0050196 UIAUTO Failed assumption fatMap.usingFatMap == NO
    0050197 UIAUTO Failed assumption fatMap.usingFatMap == NO
    0050199 UIAUTO Default id in AutoCommand
    0050299 UIDEBUG Crash forced by user
    0050310 UIGEN Failed assumption dividend > 0
    0050331 UCNET netCount Heap
    0050334 UCNET Failed to allocate netCountTable
    0050530 UIMAIN Expected AltGetDepth() == 0, 0
    0050620 UIQUERY "compId" out of range (0, DbView.compMax)
    0050621 UIQUERY Expected attr.majorId == symIndex
    0050623 UIQUERY ATTR not yet supported
    0050625 UIQUERY Failed assumption (unionPtr->obs.symId == symIndex)
    0050640 UIQUERY Expected attr.majorId == thruIndex
    0050642 UIQUERY ATTR not yet supported
    0050645 UIQUERY Failed to allocate pinTreeNode
    0050653 UIQUERY "compId" out of range (1, DbView.compMax)
    0050655 UIQUERY "-obsPtr->symId" out of range (1, DbView.compMax)
    0050657 UIQUERY "obsPtr->net" out of range (1, DbView.netMax)
    0050670 UIQUERY "symIndex" out of range (1, DbView.symMax)
    0050671 UIQUERY "symPtr->header.pads" out of range (0, SYM_PAD_LIMIT)
    0050673 UIQUERY Failed to allocate pinTreeNode
    0050684 UIQUERY Failed assumption (textView.symId == symIndex)
    0050684 UIQUERY Failed assumption (unionPtr->obs.symId == symIndex)
    0050690 UIQUERY "levIndex" out of range (0, DbView.levMax)
    0050694 UIQUERY Expected attr.majorId == levIndex
    0050695 UIQUERY This Lev ATTR not yet supported
    0050893 COMUNITS Bad units
    0050906 UIQUERY "unionPtr->pack.header.pads" out of range (0, SYM_PAD_LIMIT)
    0050907 UIQUERY "gateGroup[padIndex]" out of range (-1, PACK_GATE_LIMIT)
    0050908 UIQUERY "gates" out of range (1, PACK_GATE_LIMIT)
    0050931 UIQUERY Expected attr.minorKind == THRU_KIND
    0050932 UIQUERY Expected attr.minorKind == LEV_KIND
    0050934 UIQUERY "levOffset" out of range (0, DbView.levMax)
    0050935 UIQUERY ATTR not yet supported
    0050936 UIQUERY Failed assumption unionPtr->conn.net == netIndex
    0050937 UIQUERY Failed assumption unionPtr->conn.net == netIndex
    0050940 UIQUERY ATTR not yet supported
    0050941 UIQUERY Expected attr.majorId == packIndex
    0050942 UIQUERY ATTR not yet supported
    0050944 UIQUERY Expected attr.minorKind == THRU_KIND
    0050948 UIQUERY Expected attr.majorId == symIndex
    0050953 UIQUERY "-obsPtr->symId" out of range (1, DbView.compMax)
    0050954 UIQUERY "-obsPtr->symId" out of range (1, DbView.compMax)
    0050989 UIQUERY "padOffset" out of range (0, symPtr->header.pads)
    0050995 UIQUERY Unexpected probe kind
    0051023 UAMAIN Bad mode in startDrag
    0051030 UAMAIN Expected AltGetDepth () == 1, 1
    0051072 UAMAIN Unexpected data type in ALT
    0051091 UAMAIN Failed assumption MzGoal->connIndex
    0051093 UAMAIN Expected !visible
    0051094 UAMAIN Bad drawing mode in UaHighlight
    0051232 UAERR Expected AltGetDepth () > 0, 1
    0051242 UAERR Expected AltGetDepth () > 0, 0
    0051282 UEATTACH Unexpected KIND
    0051292 UEATTACH Failed assumption altView.instance <= DbView.compMax
    0051313 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051317 UAVERTEX Failed assumption obsPtr->crns == 2
    0051318 UAVERTEX Failed assumption altView.offset == 1
    0051320 UAVERTEX "crn" out of range (0, obsPtr->crns)
    0051324 UAVERTEX Failed assumption obsPtr->crns + 1 < OBS_CRN_LIMIT
    0051333 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051338 UAVERTEX Expected obsPtr->kind == OBS_POURED_COPPER
    0051339 UAVERTEX Expected AltGetDepth () == 0, 0
    0051343 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051345 UAMAIN Expected AltGetDepth () == 1, 1
    0051345 UAVERTEX "altPtr->instance" out of range (1, DbView.compMax)
    0051346 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051347 UAVERTEX "altView.instance" out of range (1, DbView.compMax)
    0051349 UAVERTEX Expected AltGetDepth () == 1, 1
    0051355 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051356 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051357 UAVERTEX Expected AltGetDepth() == 2, 2
    0051371 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051375 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051376 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051378 UAVERTEX Expected AltGetDepth () == 1, 1
    0051382 UAVERTEX "crn" out of range (0, obsPtr->crns-2)
    0051384 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051385 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051386 UAVERTEX Failed assumption obsIndex == altView.id
    0051387 UAVERTEX Expected AltGetDepth () == 1, 1
    0051388 UAVERTEX Failed assumption altView.kind == OBS_KIND
    0051389 UAVERTEX Unknown case in obsFinish
    0051396 UAVERTEX "work->obs.symId" out of range (-DbView.compMax, -1)
    0051439 UAOBS Expected AltGetDepth () == 0, 0
    0051442 UAOBS Expected AltGetDepth() > 0, 1
    0051451 UAOBS Failed assumption altView.kind == OBS_KIND
    0051456 UAOBS Failed assumption altView.kind == OBS_KIND
    0051461 UAOBS Expected AltGetDepth() == 1, 1
    0051464 UAOBS Cannot determine whether to add or delete
    0051467 UAOBS Expected AltGetDepth () == 0, 0
    0051468 UAOBS Failed assumption defaultObsIndex >= 0
    0051469 UAOBS Failed assumption defaultObstacleIndex >= 0
    0051471 UAOBS Expected AltGetDepth() == 1, 1
    0051472 UAOBS Expected AltGetMax() >= 1
    0051475 UAOBS Expected AltGetDepth() == 1, 1
    0051485 UAOBS Failed assumption AltGetFirst (OBS_KIND)
    0051732 UATEXT Expected AltGetDepth () > 0, 1
    0051742 UATEXT Expected AltGetDepth () > 0, 1
    0051765 UATEXT Expected AltGetDepth () == 1, 1
    0051767 UATEXT Expected AltGetDepth () == 1, 1
    0051786 UATEXT "compId" out of range (0, DbView.compMax)
    0051787 UATEXT Expected highlightedComp == 0
    0051881 UETEXT Failed assumption altView.kind == TEXT_KIND
    0051882 UETEXT Failed assumption altView.kind == TEXT_KIND
    0051887 UETEXT Expected AltGetDepth () == 1, 1
    0051892 UETEXT Failed assumption compId <= DbView.compMax
    0051972 UADATUM Expected AltGetDepth () == 0, 0
    0052025 UPMAIN Failed assumption Ui->windowType != IDS_PLACE
    0052030 UPMAIN Expected AltGetDepth () == 1, 1
    0052033 UPMAIN Expected connId == altView.id
    0052045 UPMAIN Failed assumption (! (altView.flags & ALT_ADD))
    0052046 UPMAIN Failed assumption altView.id > DbView.connMax
    0052062 UPMATRIX Expected AltGetDepth () == 1, 1
    0052072 UPMAIN Unexpected data type in ALT
    0052098 UPMAIN Expected AltGetDepth () == 1, 1
    0052111 UPMOVE unable to allocate ignoreList
    0052121 UPMOVE Expected AltGetDepth () == 0, 0
    0052122 UPMOVE Failed assumption comp1Index > 0
    0052123 UPMOVE Failed assumption comp2Index > 0
    0052130 UPMOVE Expected altView.kind == COMP_KIND
    0052133 UPMOVE Expected AltGetDepth() == 1, 1
    0052134 UPMOVE Expected AltGetDepth () == 0, 0
    0052136 UPMOVE "requestedLayer" out of range (1, DbView.levMax)
    0052138 UPMOVE Failed assumption Ui->windowType == IDS_ROUTE
    0052139 UPMOVE Expected 1 == 0
    0052168 UPMOVE Expected AltGetDepth() > 0, 1
    0052176 UPMOVE "altView.id" out of range (1, DbView.compMax)
    0052176 UPMAIN "altView.id" out of range (1, DbView.compMax)
    0052182 UPMOVE Failed assumption selectedComp > 0
    0052186 UPMOVE "altView.id" out of range (1, DbView.connMax)
    0052186 UPMAIN "altView.id" out of range (1, DbView.connMax)
    0052190 UPMOVE Expected AltGetDepth () == 2, 2
    0052198 UPMOVE Expected AltGetDepth () == 0, 0
    0052233 UPDRAW Failed assumption Ui->modeId == IDM_INVOKE_TOOL_COMPONENT
    0052234 UPDRAW Expected AltGetDepth () > 0, 1
    0052314 UPEDIT Bad command id in UpSetFlag
    0052377 UPEDIT Failed assumption sizeof (altView.instance) >= sizeof (work->comp.rotation)
    0052378 UPEDIT Expected altView.instance == 0
    0052426 UPINIT Failed assumption Up.netList
    0052427 UPINIT Failed assumption Up.selected
    0052471 UPINIT Failed assumption selectedHandle
    0052473 UPINIT Failed assumption Up.selected
    0052510 UPPICK Failed assumption Up.dragCount >= 0
    0052512 UPPICK Failed assumption masterId
    0052513 UPPICK Failed assumption Up.dragCount >= 0
    0052515 UPPICK Expected AltGetDepth () == 1, 1
    0052517 UPPICK Expected AltGetDepth () == 1, 1
    0052519 UPPICK Failed assumption masterId > 0
    0052527 URROUTE Security device missing
    0052537 UPPICK Expected AltGetDepth () == 0, 0
    0052538 UPPICK Failed assumption (compView.flag & (COMP_FIXED | COMP_LOCKED)) == 0
    0052539 UPPICK Expected 1 == 0
    0052542 UPPICK Failed assumption masterId
    0052546 UPPICK Expected Obj.valid
    0052547 UPPICK Expected AltGetDepth () == 0, 0
    0052555 UPPICK "compId" out of range (1, DbView.compMax)
    0052556 UPPICK "compId" out of range (1, DbView.compMax)
    0052557 UPPICK Failed assumption (compView.flag & (COMP_FIXED | COMP_LOCKED)) == 0
    0052578 UPPICK "compLev" out of range (1, DbView.levMax)
    0052579 UPPICK Failed assumption Obj.valid
    0052587 UPPICK "compLev" out of range (1, DbView.levMax)
    0052591 UPPICK "nextComp" out of range (0, DbView.compMax)
    0052612 UPPIN Expected AltGetDepth () > 0, 1
    0052622 UPPIN "pin" out of range (1, symPtr->header.pads)
    0052631 UPPIN "selectedPin" out of range (1, lastPin)
    0052632 UPPIN "selectedPin" out of range (1, lastPin)
    0052633 UPPIN Failed assumption altView.kind == COMP_KIND
    0052634 UPPIN Failed assumption selectedPin > 0
    0052634 UPPIN "OBS_PIN (work->obs.net)" out of range (1, altSymPtr->header.pads)
    0052637 UPPIN Bad DRAW_MODE in calcMode
    0052638 UPPIN how could we have gotten here?
    0052639 UPPIN Expected 1 == 0
    0052642 UPPIN Expected AltGetDepth() > 0, 1
    0052643 UPPIN unknown mode in pin/gate proc
    0052646 UPPIN Failed assumption altView.kind == COMP_KIND
    0052647 UPPIN Failed assumption selectedPin > 0
    0052648 UPPIN Unknown drawing mode
    0052649 UPPIN "selectedPin" out of range (1, lastPin)
    0052651 UPPIN Failed assumption work->obs.symId == symId
    0052652 UPPIN Failed assumption altView.kind == COMP_KIND
    0052653 UPPIN Failed assumption altView.kind == COMP_KIND
    0052654 UPPIN Failed assumption selectedPin > 0
    0052655 UPPIN Failed assumption work->obs.symId == -compId
    0052656 UPPIN Failed assumption selectedPin > 0
    0052657 UPPIN Expected AltGetDepth() > 0, 1
    0052661 UPPIN Failed assumption symHeader.pads == altSymPtr->header.pads + 1
    0052662 UPPIN Failed assumption obsPtr->symId == work->comp.symIndex
    0052663 UPPIN Failed assumption obsPtr->symId == -altView.id
    0052664 UPPIN Failed assumption Ui->modeId == IDM_INVOKE_TOOL_PIN
    0052665 UPPIN Failed assumption Ui->moveMode
    0052666 UPPIN Failed assumption work->obs.symId == symId
    0052667 UPPIN Failed assumption work->obs.symId == -compId
    0052668 UPPIN Failed assumption work->obs.symId == symId
    0052669 UPPIN Failed assumption work->obs.symId == -compId
    0052672 UPPIN Failed assumption Ui->modeId == IDM_INVOKE_TOOL_PIN
    0052674 UPPIN Failed assumption InLibMan
    0052678 UPPIN "altView.offset" out of range (1, symPtr->header.pads)
    0052679 UPPIN Expected AltGetDepth () > 0, 1
    0052682 UPPIN Failed assumption selectedPin > 0
    0052683 UPPIN Failed assumption work->obs.symId == symId
    0052684 UPPIN Failed assumption work->obs.symId == -compId
    0052690 UPPIN "compIndex" out of range (1, DbView.compMax)
    0052691 UPPIN Failed assumption work->obs.symId == symId
    0052692 UPPIN Failed assumption work->obs.symId == -compId
    0052788 UPAUTO Unknown place operation
    0052840 UPQUERY "compIndex" out of range (1, DbView.compMax)
    0052854 UPQUERY ATTR not yet supported
    0052864 UPQUERY Failed assumption unionPtr->conn.comp[0] == compId
    0052871 UPQUERY Expected attr.minorKind == PIN_ATTR
    0052872 UPQUERY Failed assumption (unionPtr->obs.symId == compView.symIndex) ...
    0052874 UPQUERY Failed to allocate compNetTable
    0052878 UPQUERY Failed to allocate compNetPtr
    0052880 UPQUERY Failed assumption Ui->probe.kind == COMP_KIND
    0052881 UPQUERY "compId" out of range (1, DbView.compMax)
    0052892 UPQUERY Failed assumption (unionPtr->text.symId == compView.symIndex) ...
    0052896 UPQUERY Failed assumption compId >= 0
    0052899 UPQUERY Failed assumption (unionPtr->obs.symId == compView.symIndex) ...
    0052951 UPMATRIX Expected AltGetDepth () == 2, 2
    0052952 UPMATRIX Expected AltGetMax () == 1
    0052953 UPMATRIX Failed assumption obsPtr->crns == 2
    0052955 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052956 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052957 UPMATRIX Expected AltGetDepth () == 2, 2
    0052958 UPMATRIX Expected AltGetMax () == 1
    0052962 UPMATRIX Expected AltGetDepth () == 1, 1
    0052966 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052971 UPMATRIX Expected AltGetDepth () == 1, 1
    0052972 UPMATRIX Expected AltGetMax () >= 1
    0052977 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052978 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052979 UPMATRIX Failed assumption altView.kind == OBS_KIND
    0052988 UPMATRIX Failed assumption AltLoadShadow (altIndex, &altView, ptr)
    0052989 UPMATRIX Expected AltGetDepth () == 0, 0
    0053023 URMAIN Bad mode in startDrag
    0053030 URMAIN Expected AltGetDepth () == 1, 1
    0053038 URMAIN "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053056 URMAIN Security device missing
    0053058 URMAIN Security device missing
    0053067 URMAIN "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053072 URMAIN Unexpected data type in ALT
    0053093 URMAIN Unknown tool
    0053094 URMAIN Unknown tool
    0053193 URAUTO Failed assumption Obj.valid
    0053194 URAUTO Failed assumption mz.mapValid
    0053199 URAUTO Bad id in RouteAutoCommand
    0053250 UIAUTO Failed assumption DbView.batchIndex > 0
    0053257 URINIT Security device missing
    0053258 URINIT Security device missing
    0053380 URINSTAL Failed assumption mz.mapValid
    0053381 URINSTAL Failed assumption mz.hopAllocated
    0053383 URINSTAL Path had too many corners
    0053391 URINSTAL Bad status in hopFail
    0053392 URINSTAL Bad status in hopFail
    0053398 URINSTAL Expected AltGetDepth () > 0, 1
    0053401 URMOVE Expected MzGoal->objIndex != 0
    0053402 URMOVE "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053444 URMOVE Failed assumption crn1Index > 0
    0053445 URMOVE Failed assumption crn1Index < workPath->crns - 1
    0053461 URMOVE "crn1Index" out of range (1, workPath->crns - 2)
    0053467 URMOVE "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053469 URMOVE "crn1Index" out of range (0, workPath->crns-1)
    0053474 URMOVE Failed to allocate lastPath
    0053488 URMOVE Failed assumption workPath->crns > 2
    0053490 URMOVE Expected AltGetDepth () == 0, 0
    0053525 URROUTE Security device missing
    0053557 URROUTE Security device missing
    0053558 URROUTE Security device missing
    0053566 URROUTE Failed assumption MzGoal->connIndex == 0
    0053571 URROUTE Failed assumption SfView.options[MzGoal->pass] & PASS_ENABLED_OPTION
    0053576 URROUTE Bad sweep direction in nextWindow
    0053577 URROUTE Bad sweep direction in nextWindow
    0053579 URROUTE Cannot allocate lastPath
    0053581 URROUTE Failed assumption nextPass() == PASS
    0053584 URROUTE Failed assumption lastPath
    0053589 URROUTE Failed assumption MzGoal->connIndex != 0
    0053590 URROUTE Failed assumption Ui->windowType == IDS_ROUTE
    0053591 URROUTE Failed assumption MzGoal->connIndex
    0053592 URROUTE Failed assumption MzGoal->objIndex != 0
    0053595 URROUTE Status error in failOneCell2
    0053595 URROUTE "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053597 URROUTE Failed assumption objRecord.kind == OBJ_CONN
    0053598 URROUTE Failed assumption fatMap.usingFatMap == NO
    0053607 URGEN Unexpected mode
    0053654 URSTEER "newLevel" out of range (0, DbView.levMax)
    0053690 URSTEER Bad dir in findOnePath
    0053691 URSTEER Failed assumption MzGoal->objIndex
    0053692 URSTEER "MzGoal->connIndex" out of range (1, DbView.connMax)
    0053745 URTACK Failed to allocate saveConnOrig
    0053749 URTACK Failed assumption saveConnOrig
    0053767 URTACK Failed assumption connIndex != 0
    0053792 URTACK Failed assumption MzGoal->connIndex
    0053919 URUNRUT rectEdgeSplit vertical with no crossing
    0053920 URUNRUT ConnEdgeSplit horizontal with no crossing
    0053991 URUNRUT Failed assumption MzGoal->connIndex
    0053992 URUNRUT Failed assumption MzGoal->objIndex
    0053995 URUNRUT (crn != crn1) && (crn != crn2) in breakLineAtEdge
    0054087 UVCOMP Expected AltGetDepth () == 0, 0
    0054088 UVCOMP Failed assumption Ui->rowCount == 0
    0054091 UVCOMP UNION stack not empty
    0054092 UVCOMP UNION stack not empty
    0054093 UVCOMP Expected AltGetDepth () == 0, 0
    0054097 UVCOMP Failed assumption Ui->rowCount == 0
    0054218 UCNET "firstSelected" out of range (1, DbView.netMax)
    0054219 UCNET Failed assumption DbView.netMax < NET_LIMIT
    0054287 UVNET Expected AltGetDepth () == 0, 0
    0054288 UVNET Failed assumption Ui->rowCount == 0
    0054293 UVNET Expected AltGetDepth () == 0, 0
    0054297 UVNET Failed assumption Ui->rowCount == 0
    0054387 UVOBS Expected AltGetDepth () == 0, 0
    0054388 UVOBS Failed assumption Ui->rowCount == 0
    0054393 UVOBS Expected AltGetDepth () == 0, 0
    0054397 UVOBS Failed assumption Ui->rowCount == 0
    0054510 UVSPACE Failed assumption levMap
    0054567 UVSPACE Failed assumption result == PASS
    0054714 UVSWEEP Failed assumption numSelected
    0054814 UVSWLEV Failed assumption numSelected
    0054857 UVSWLEV Security device missing
    0054858 UVSWLEV Security device missing
    0054872 UVSWLEV "levMax" out of range (1, DbView.levMax)
    0054923 UVPP Failed assumption hRestore == 0
    0054926 UVPP Failed to allocate save image
    0054932 UVPP Failed assumption numSelected == 1
    0054933 UVPP Expected AltGetDepth () == 0, 0
    0054934 UVPP Expected lastReport == NO
    0054935 UVPP Expected AltGetDepth () == 0, 0
    0054936 UVPP Expected AltGetDepth () == 0, 0
    0054939 UVPP "firstSelected+1" out of range (1, DbView.ppMax)
    0054943 UVPP Failed assumption hSaveRestore == 0
    0054946 UVPP Failed to allocate save image
    0054963 UVPP "firstSelected+1" out of range (1, DbView.ppMax)
    0054966 UVPP Failed assumption DbView.colorMax == 0
    0054987 UVPP Expected AltGetDepth () == 0, 0
    0054988 UVPP Failed assumption Ui->rowCount == 0
    0055038 UVTHRU Failed assumption Ui->rowCount == 0
    0055039 UVTHRU Expected AltGetDepth () == 0, 0
    0055087 UVTHRU Failed assumption probeSet
    0055096 UVTHRU Failed assumption Ui->rowCount == 0
    0055143 UVCOLOR Failed assumption altView.kind == COLOR_KIND
    0055153 UVCOLOR Failed assumption altView.kind == COLOR_KIND
    0055163 UVCOLOR bad colorView.kind
    0055173 UVCOLOR "colorIndex" out of range (0, UD_COLOR_MAX)
    0055174 UVCOLOR Expected AltGetDepth () == 0, 0
    0055175 UVCOLOR bad colorView.rule
    0055182 UVCOLOR Expected AltGetDepth () == 0, 0
    0055317 UVPACK Failed assumption numSelected
    0055318 UVPACK "pack" out of range (1, DbView.packMax)
    0055396 UVPACK Failed assumption Ui->rowCount == 0
    0055421 UVDRC Expected AltGetDepth () == 1, 1
    0055456 UVDRC Expected AltGetDepth () == 0, 0
    0055787 UVTEXT Expected AltGetDepth () == 0, 0
    0055788 UVTEXT Failed assumption Ui->rowCount == 0
    0055793 UVTEXT Expected AltGetDepth () == 0, 0
    0055797 UVTEXT Failed assumption Ui->rowCount == 0
    0055811 UESYM Failed to alloc symbol name record
    0055812 UESYM Failed to alloc symbol name data
    0055813 UESYM Failed to alloc symbol lib name data
    0055821 UESYM Unknown case in variable dialog switch
    0055822 UESYM Unknown case in dialog title switch
    0055833 UESYM "compId" out of range (1, DbView.compMax)
    0055852 UESYM how could we have gotten here?
    0055859 UESYM "altView.id" out of range (1, DbView.symMax)
    0055861 UESYM Failed assumption sample->sym.pad[sampleOffset].flags ...
    0055862 UESYM "altView.id" out of range (1, DbView.symMax+1)
    0055872 UESYM "altView.offset" out of range (0, sample->sym.header.pads)
    0055883 UESYM Failed assumption pinCount == sample->sym.header.pads
    0055891 UESYM Failed assumption altMax
    0055898 UESYM Failed assumption lastAltId > 0
    0055936 UVSYM Failed assumption Ui->rowCount == 0
    0055938 UVSYM Failed assumption Ui->rowCount == 0
    0055939 UVSYM Expected AltGetDepth () == 0, 0
    0055952 UVSYM "lastPinOffset" out of range (0, tempPtr->header.pads)
    0055987 UVSYM Failed assumption probeSet
    0055990 UVSYM UNION stack not empty
    0055991 UVSYM UNION stack not empty
    0055992 UVSYM UNION stack not empty
    0056019 UIGRAPH Failed assumption dispatchWindowCommand (msg)
    0056026 UIGRAPH Unknown mode
    0056061 UPSWAP AltStore Heap
    0056064 UPSWAP Failed to allocate pairViewTable
    0056065 UPSWAP Failed to allocate pairViewPtr
    0056078 UIGRAPH Expected Ui->windowType == IDS_ROUTE
    0056110 URSPLIT Expected MzGoal->objIndex != 0
    0056120 URSPLIT Expected MzGoal->connIndex != 0
    0056126 URSPLIT Failed assumption catFromPtr->crn[0].x == catToPtr->crn[catToPtr->crns-1].x
    0056127 URSPLIT Failed assumption catFromPtr->crn[0].y == catToPtr->crn[catToPtr->crns-1].y
    0056128 URSPLIT Failed assumption catFromPtr->crn[0].lev == catToPtr->crn[catToPtr->crns-1].lev
    0056129 URSPLIT Failed assumption catFromPtr->crn[0].viaIndex == catToPtr->crn[catToPtr->crns-1].viaIndex
    0056131 URSPLIT2 Failed assumption inPtr->crn[0].x == outPtr->crn[outPtr->crns-1].x
    0056132 URSPLIT2 Failed assumption inPtr->crn[0].y == outPtr->crn[outPtr->crns-1].y
    0056133 URSPLIT2 Failed assumption inPtr->crn[0].lev == outPtr->crn[outPtr->crns-1].lev
    0056134 URSPLIT2 Failed assumption inPtr->crn[0].viaIndex == outPtr->crn[outPtr->crns-1].viaIndex
    0056135 URSPLIT2 Failed assumption inPtr->net == outPtr->net
    0056150 URSPLIT Failed assumption catFromPtr->net == catToPtr->net
    0056178 URSPLIT Failed assumption connListMax > 0
    0056179 URSPLIT Failed assumption connListMax > 0
    0056183 URSPLIT Failed assumption foundSections == SEG_OTHER
    0056190 URSPLIT Expected AltGetDepth () == 0, 0
    0056212 URMANUAL Expected MzGoal->objIndex != 0
    0056215 URMANUAL Failed assumption MzGoal->connIndex != 0
    0056217 URSELECT Failed assumption MzGoal->connIndex != 0
    0056217 URMANUAL Failed assumption MzGoal->crn2Index > MzGoal->crn1Index
    0056230 URMANUAL "lastIndex" out of range (1, DbView.connMax)
    0056234 URMANUAL tmpPtr->net != connPtr->net
    0056234 URMANUAL Expected AltGetDepth () == 0, 0
    0056269 URMANUAL Failed assumption altView.id
    0056271 URMANUAL Failed to allocate undoListConn
    0056272 URMANUAL Failed to allocate undoListIndexes
    0056273 URMANUAL Failed to allocate connPtr
    0056274 URMANUAL Failed to allocate lastPath
    0056274 URMANUAL Failed assumption undoListIndexes[item] == 0
    0056276 URMANUAL Failed to allocate lastPath
    0056282 URMANUAL Expected AltGetDepth () == 1, 1
    0056298 URMANUAL "connIndex" out of range (1, DbView.connMax)
    0056312 URGEN Failed assumption MzGoal->connIndex
    0056317 URGEN "viaIndex" out of range (1, DbView.viaMax)
    0056350 URGEN Failed assumption MzGoal->connIndex != 0
    0056351 URGEN Failed assumption MzGoal->connIndex != 0
    0056370 URGEN Failed assumption MzGoal->connIndex != 0
    0056371 URGEN Failed assumption MzGoal->connIndex != 0
    0056372 URGEN Failed assumption MzGoal->connIndex != 0
    0056373 URGEN Failed assumption MzGoal->connIndex != 0
    0056374 URGEN Failed assumption MzGoal->connIndex != 0
    0056377 URGEN Failed assumption MzGoal->connIndex != 0
    0056379 URGEN Failed assumption MzGoal->connIndex != 0
    0056465 UCCONN Failed assumption connPtr->crn[connPtr->crns-1].x ...
    0056466 UCCONN Failed assumption connPtr->crn[connPtr->crns-1].y ...
    0056483 URQUERY Invalid kind in tellAboutObject
    0056573 URCOMP Expected AltGetDepth () == 0, 0
    0056789 UPDENSE Failed assumption value >= 0
    0056790 UPDENSE Expected AltGetDepth () == 0, 0
    0056904 UETHRU Failed assumption foundLegitLayer
    0056908 UETHRU "newId" out of range (1, DbView.thruMax)
    0056922 UETHRU Unknown case in dialog title switch
    0056923 UETHRU "newId" out of range (1, DbView.thruMax + 1)
    0056939 UETHRU "altView.id" out of range (1, DbView.thruMax)
    0056953 UETHRU Failed assumption match[0] > 0
    0056954 UETHRU Failed assumption match[1] == 0
    0056961 UETHRU Failed assumption sample->thru.layer[sampleOffset].flags ...
    0056962 UETHRU "altView.id" out of range (1, DbView.thruMax+1)
    0056972 UETHRU "altView.offset" out of range (0, DbView.levMax)
    0056978 UETHRU Failed assumption altView.offset > 0
    0056987 UETHRU Unknown case in dialog choice switch
    0056991 UETHRU Failed assumption altMax
    0057118 UIPROBE Bad kind
    0057145 UIPROBE Bad kind in validateprobe.index
    0057219 UELEVEL Failed assumption numSelected
    0057327 UPSWAP Failed assumption altIndex > 0
    0057328 UPSWAP "selectedComp" out of range (1, DbView.compMax)
    0057329 UPSWAP Failed assumption selectedPin > 0
    0057358 UPSWAP Invalid swap mode
    0057359 UPSWAP Invalid swap mode
    0057387 UPSWAP Failed assumption newPin2[pin2] == pin
    0057403 UESYM Failed assumption localHeap == 0
    0057404 UESYM Failed assumption thruNameHead == NULL
    0057411 UECOMP Failed assumption altMax
    0057411 UEFRVIA Failed assumption altMax
    0057422 UECOMP Failed assumption fetchedAction == ACTION_REPLACE_ALL
    0057422 UEFRVIA Failed assumption fetchedAction == ACTION_REPLACE_ALL
    0057434 UECOMP Failed assumption oldSymId != 0
    0057436 UECOMP "compId" out of range (1, DbView.compMax)
    0057436 UECOMP "symId" out of range (1, DbView.symMax)
    0057457 UECOMP Failed assumption replaceAction != 0
    0057463 UECOMP Failed assumption symId != 0
    0057464 UECOMP Failed assumption symId != 0
    0057471 UECOMP Failed assumption symHeader.derived != 0
    0057482 UECOMP Failed assumption newPin > 0
    0057483 UECOMP Failed assumption newPin > 0
    0057519 UENET Failed assumption altMax
    0057574 UENET Failed assumption netIndex
    0057587 UENET Failed assumption netIndex
    0057588 UENET Failed assumption netIndex
    0057589 UENET Failed assumption netIndex
    0057615 UEOBS Failed assumption numSelected > 0
    0057623 UEOBS "typeVal" out of range (OBS_OUTLINE, OBS_OTHER)
    0057627 UEOBS Bad shape in queryConnSeg
    0057681 UEOBS Failed assumption altView.kind == OBS_KIND
    0057682 UEOBS Failed assumption altView.kind == OBS_KIND
    0057687 UEOBS Expected AltGetDepth () == 1, 1
    0057691 UEOBS Failed assumption (obsPtr->kind == OBS_KEEPOUT) ...
    0057692 UEOBS Failed assumption compId <= DbView.compMax
    0057901 UEUNITS Failed assumption DbView.userDiv == newUserDiv
    0057902 UEUNITS Failed assumption DBL_EQUAL (DbView.inchFactor, newInchFactor) == YES
    0057903 UEUNITS Failed assumption DbView.userDiv == newUserDiv
    0057904 UEUNITS Failed assumption DBL_EQUAL (DbView.inchFactor, newInchFactor) == YES
    0057923 UEUNITS Failed assumption (workDb.flags & DB_METRIC) == (DbView.flags & DB_METRIC)
    0057926 UEUNITS Failed assumption (workDb.flags & DB_METRIC) == (DbView.flags & DB_METRIC)
    0057927 UEUNITS Failed assumption workDb.displayUnits == DbView.displayUnits
    0057928 UEUNITS Failed assumption (workDb.flags & DB_METRIC) == (DbView.flags & DB_METRIC)
    0057929 UEUNITS Failed assumption (workDb.flags & DB_METRIC) == (DbView.flags & DB_METRIC)
    0057931 UEUNITS Failed assumption workDb.displayUnits == DbView.displayUnits
    0058482 PROTXMAI Expected ComPushDir (TCH_LIB)
    0058801 PROTXNUM Failed assumption theDialog
    0059069 UIHILITE Expected pairPtr->count < PAIR_LIMIT
    0059071 UIHILITE Expected pairPtr->count < PAIR_LIMIT
    0059072 UIHILITE Expected pairPtr->count < PAIR_LIMIT
    0059400 UECOMP Failed assumption compId > 0
    0059401 UECOMP "newSym" out of range (1, DbView.symMax)
    0059403 UECOMP unexpected case in replaceFrViaFootprint
    0059411 UECOMP nonsense case in replaceFrViaFootprint
    0059413 UECOMP nonsense case in replaceFrViaFootprint
    0059414 UECOMP nonsense case in replaceFrViaFootprint
    0059415 UECOMP nonsense case in replaceFrViaFootprint
    0059416 UECOMP nonsense case in replaceFrViaFootprint
    0061003 URCOPY Failed assumption cloneHead == NULL
    0061009 URCOPY Failed assumption ptr->connPtr != NULL
    0061014 URCOPY Failed assumption ptr->connPtr != NULL
    0061016 URCOPY Failed assumption ptr->connPtr != NULL
    0061018 URCOPY Failed assumption ptr->connPtr != NULL
    0061034 URCOPY Expected (! (connPtr->crn[tmpCrn].flags & CRN_FREE_VIA))
    0061042 URCOPY Failed assumption newConn->crn[0].lev == 0
    0061045 URCOPY Expected AltGetDepth () == 0, 0
    0061064 URCOPY "comp1" out of range (1, DbView.compMax)
    0061101 URCHECK Expected mz.qtreeActive == YES
    0061102 URCHECK Expected mz.qtreeActive == YES
    0061103 URCHECK Expected mz.qtreeActive == YES
    0061130 URCHECK Failed assumption DbView.batchIndex > 0
    0061141 URCHECK Failed assumption Obj.valid
    0061150 URCHECK Failed assumption DbView.batchIndex > 0
    0061171 URCHECK Failed assumption Obj.valid
    0061172 URCHECK Route not enabled
    0061176 URCHECK Bad sweep direction in nextWindow
    0061177 URCHECK Bad sweep direction in nextWindow
    0061182 URCHECK Route not enabled
    0061186 URCHECK Route not enabled
    0061189 URCHECK Failed assumption Obj.valid
    0061199 URCHECK Bad command
    0061245 URCHECK2 Expected AltGetDepth () == 0, 0
    0061247 URCHECK2 "compId" out of range (1, DbView.compMax)
    0061297 URCHECK2 Expected AltGetDepth () == 0, 0
    0061300 URDFM Failed assumption 0 == 1
    0061306 URDFM Failed assumption filterFunc != NULL
    0061307 URDFM "passLimit" out of range (1, 5)
    0061308 URDFM "dfmLevel" out of range (DFM_OPTIMIZE_LEVEL, DFM_GLOSS_LEVEL)
    0061322 URDFM "c" out of range (0, connPtr->crns - 1)
    0061323 URDFM "crn1" out of range (0, connPtr->crns - 1)
    0061324 URDFM "crn2" out of range (0, connPtr->crns - 1)
    0061333 URDFM "crn" out of range (1, connPtr->crns-2)
    0061354 URDFM Failed assumption connPtr->crn[viaCrn].viaIndex != 0
    0061380 URFANOUT Heap for dispersion list
    0061381 URFANOUT Cannot allocate temporary table to compute cluster areas
    0061381 URFANOUT Allocating one component score record
    0061384 URFANOUT "connPtr->net" out of range (1, DbView.netMax)
    0061385 URFANOUT Failed assumption ++maxPad <= SYM_PAD_LIMIT
    0061389 URDFM Failed assumption connPtr->crn[crn].viaIndex
    0061391 URDFM3 Failed assumption lev
    0061394 URDFM Expected AltGetDepth () == 0, 0
    0061395 URDFM Expected AltGetDepth () == 0, 0
    0061439 URRECON Expected AltGetDepth () == 1, 1
    0061456 URRECON Failed assumption crn + diff - addCorners < tmpPtr->crns
    0061470 URRECON Failed to allocate newNode
    0061472 URRECON Failed to allocate reconnectTable
    0061473 URRECON Failed assumption AltGetDepth () >= 1
    0061477 URRECON Failed assumption prevPtr != NULL
    0061481 URRECON Failed assumption oldPath->crn[0].x == newPath->crn[0].x
    0061482 URRECON Failed assumption oldPath->crn[0].y == newPath->crn[0].y
    0061490 URRECON Failed assumption reconnectTableMax > 0
    0061491 URRECON Failed assumption reconnectTableMax < altMax
    0061494 URRECON Failed assumption lastChangedNewCrn - lastChangedOldCrn == addCorners
    0061528 URDFM2 Failed assumption ret == 1
    0061531 URDFM2 Failed assumption ret != 0
    0061543 URDFM2 Failed assumption (ang1 % ROT_90) == 0
    0061561 URDFM2 Failed assumption conn2Ptr->comp[0] == conn1Ptr->comp[0]
    0061562 URDFM2 Failed assumption conn2Ptr->pin[0] == conn1Ptr->pin[0]
    0061563 URDFM2 Failed assumption conn2Ptr->crn[0].x == conn1Ptr->crn[0].x
    0061564 URDFM2 Failed assumption conn2Ptr->crn[0].y == conn1Ptr->crn[0].y
    0061586 URDFM2 Failed assumption crn > 0
    0061601 URDFM3 Failed assumption CheckAlt (NO)
    0061634 URDFM3 Failed assumption AltGetMax () != 0
    0061635 URDFM3 Failed assumption AltGet (CONN_KIND, connId, connPtr)
    0061636 URDFM3 Failed assumption AltGetDepth () != 0
    0061637 URDFM3 Failed assumption AltGetDepth () == 0
    0061642 URDFM3 "crn" out of range (1, connPtr->crns - 1)
    0061678 URDFM3 "symIndex" out of range (1, DbView.symMax)
    0061679 URDFM3 "pin" out of range (1, SymPads(symIndex))
    0061697 URDFM3 Failed assumption found == TRUE
    0061710 URDFM4 Failed assumption DFMCheckAlt (connId, objIndex, connPtr, install)
    0061711 URDFM4 Failed assumption DFMCheckAlt (connId, objIndex, connPtr, install)
    0061742 URDFM4 Failed assumption result
    0061743 URDFM4 Failed assumption result == 1
    0061746 URDFM4 Failed assumption result == 1
    0061811 URDFM5 Failed assumption connPtr->comp[0] == compId
    0061877 URDFM5 Failed assumption width == height
    0061878 URDFM5 Failed assumption width == height
    0061879 URDFM5 Failed assumption width == height
    0061901 URMATCH Failed assumption matchHeap == 0
    0061903 URMATCH "netPtr->matchGroup" out of range (1, MATCH_GROUP_LIMIT)
    0061931 URMATCH Failed assumption delta >= 0
    0061933 URMATCH Failed assumption netPtr->minLength >= 0
    0061934 URMATCH Failed assumption netPtr->minLength >= 0
    0061935 URMATCH Failed assumption netPtr->maxLength >= 0
    0061980 URMATCH Failed assumption lengthHeap == 0
    0061982 URMATCH Failed to allocate new share record
    0062047 UADIM Expected AltGetDepth() == 1, 1
    0062049 UADIM Expected AltGetDepth () == 1, 1
    0062071 UADIM Expected AltGetDepth() == 1, 1
    0062081 UADIM Expected AltGetDepth () == 0, 0
    0062082 UADIM Expected AltGetDepth () == 1, 1
    0062083 UADIM Expected AltGetDepth () == 1, 1
    0062084 UADIM Expected AltGetDepth () == 1, 1
    0062088 UADIM Expected AltGetDepth() == 2, 2
    0062089 UADIM Expected AltGetDepth() == 2, 2
    0062304 UVCHART "idx" out of range (1, DbView.drillChart.drills)
    0063360 UMODNET Failed assumption nodeHeap == 0
    0063365 UMODNET Failed assumption nodeCount < MAX_NODES
    0063369 UMODNET Failed assumption AltGetDepth () == 0
    0063371 UMODNET Failed assumption n1 != 0
    0063372 UMODNET Failed assumption n2 != 0
    0064012 UCLEVEL Failed assumption symIndex <= DbView.symMax
    0064013 UCLEVEL Failed assumption symIndex == DbView.symMax
    0064018 UCLEVEL "firstSelected" out of range (1, DbView.levMax)
    0064019 UCLEVEL Failed assumption DbView.levMax < LEV_ETCH_LIMIT
    0064034 UCLEVEL Expected AltGetDepth () == 1, 1
    0064056 UCLEVEL Failed assumption attrPtr->value > 0
    0064057 UCLEVEL Failed assumption attrPtr->stringId > 0
    0064058 UCLEVEL Expected AltGetDepth () == 1, 1
    0064062 UCLEVEL "altView.id" out of range (0, DbView.levMax)
    0064116 UCTHRU Failed assumption refLevel != 0
    0064117 UCTHRU Failed assumption applyLevel != 0
    0064133 UCTHRU "altView.offset" out of range (0, DbView.levMax)
    0064134 UCTHRU "altView.offset" out of range (0, DbView.levMax)
    0064136 UCTHRU Failed assumption DbView.thruMax < THRU_LIMIT
    0064137 UCTHRU Failed assumption Ui->probe.kind == THRU_KIND
    0064138 UCTHRU Failed assumption altView.offset > 0
    0064141 UCTHRU Failed assumption DbLoad (fullName, DEFAULT_BINARY)
    0064142 UCTHRU Failed assumption GetActiveDatabase () == topDb
    0064143 UCTHRU Failed assumption localHeap == 0
    0064147 UCTHRU Failed assumption altView.offset == 0
    0064156 UCTHRU Failed assumption collisionCount == collisionCount2
    0064196 UCTHRU "collisionCount2" out of range (1, collisionCount)
    0064197 UCTHRU "collisionCount" out of range (1, altMax)
    0064211 UCSYM UNION stack not empty
    0064212 UCSYM UNION stack not empty
    0064222 UCSYM "altView.offset" out of range (0, sample->sym.header.pads)
    0064223 UCSYM Failed assumption DbView.symMax < SYM_IDX_LIMIT
    0064225 UCSYM Expected Ui->probe.kind == SYM_KIND
    0064234 UCSYM "altView.offset" out of range (0, sample->sym.header.pads)
    0064235 UCSYM Failed assumption (obsPtr->symId == altView.id)
    0064238 UCSYM Failed assumption altView.offset > 0
    0064240 UCSYM Failed assumption (obsPtr->symId == obsSymIndex)
    0064247 UCSYM Failed assumption altView.offset == 0
    0064249 UCSYM Failed assumption (textPtr->symId == textSymIndex)
    0064261 UCSYM Failed assumption symHeader.pads == altSymPtr->header.pads + 1
    0064262 UCSYM Failed assumption (obsPtr->symId == sampleSymIndex)
    0064263 UCSYM Failed assumption pinNumber > 0
    0064265 UCSYM Failed assumption (textPtr->symId == altView.id)
    0064276 UCSYM Failed assumption work->obs.symId == symId
    0064277 UCSYM Failed assumption work->obs.symId == symId
    0064278 UCSYM "OBS_PIN (work->obs.net)" out of range (1, altSymPtr->header.pads)
    0064405 UCCOMP Expected AltGetDepth () == 1, 1
    0064417 UCCOMP "symIndex" out of range (1, DbView.symMax)
    0064443 UCCOMP Failed assumption compId
    0064446 UCCOMP Failed to allocate tmpHeap
    0064456 UCCOMP Expected altDepth > 0
    0064462 UCCOMP Failed assumption compId
    0064475 UCCOMP Expected AltGetDepth () == 1, 1
    0064491 UCCOMP Expected AltGetDepth () == 0, 0
    0064492 UCCOMP Failed assumption symPtr->header.derived != 0
    0064492 UCCOMP Failed assumption minorId
    0064493 UCCOMP Failed assumption mirroredIndex
    0064532 UCNET Failed assumption sizeof (UNION_VIEW) > sizeof (BASE_UNIT) * (LEV_ETCH_LIMIT + 1)
    0064543 UCNET "colorIndex" out of range (0, UD_COLOR_MAX)
    0064567 UCNET "altView.id" out of range (1, DbView.netMax)
    0064574 UCNET Expected netIndex > 0
    0064581 UCNET Expected AltGetDepth () == 1, 1
    0064606 UCCONN Failed assumption unionPtr->conn.comp[0] != 0
    0064607 UCCONN Failed assumption unionPtr->conn.pin[0] != 0
    0064608 UCCONN Failed assumption unionPtr->conn.comp[1] == 0
    0064609 UCCONN Failed assumption unionPtr->conn.pin[1] == 0
    0064621 UCCONN Failed assumption connPtr->comp[0] == 0
    0064622 UCCONN Failed assumption connPtr->pin[0] == 0
    0064623 UCCONN Failed assumption connPtr2->comp[1] == 0
    0064624 UCCONN Failed assumption connPtr2->pin[1] == 0
    0064632 UCFRVIA Expected AltGetDepth () == 0, 0
    0064633 UCCONN Failed assumption compIndex == Ui->probe.index
    0064634 UCCONN Failed assumption compIndex <= DbView.compMax
    0064635 UCCONN "pinIndex" out of range (1, symHeader.pads)
    0064638 UCCONN Failed assumption nodesFoundNet == 1
    0064639 UCCONN Failed assumption nodesFoundNewNet == 1
    0064646 UCFRVIA Failed assumption obsPtr->net > 0
    0064646 UEFRVIA Failed assumption Ui->compFlags & COMP_FREE_AND_TP
    0064647 UEFRVIA Failed assumption Ui->compFlags & COMP_FREE_AND_TP
    0064651 UEFRVIA "testIndex" out of range (1, DbView.frViaMax)
    0064654 UCCONN Expected AltGetDepth () > 0, 1
    0064657 UCFRVIA Expected AltGetDepth () == 0, 0
    0064658 UCFRVIA Expected AltGetDepth () == 1, 1
    0064662 UCCONN "compIndex" out of range (1, DbView.compMax)
    0064663 UCCONN Failed assumption pinIndex > 0
    0064667 UCCONN Failed assumption ++loopCheck < LSTR_LIMIT/3
    0064672 UCCONN Net discontinuity in original net
    0064673 UCCONN Net discontinuity in new net
    0064674 UCCONN Failed assumption connPtr->net == netIndex
    0064678 UCCONN Failed assumption connPtr2->net == netIndex
    0064681 UCCONN connection has two nodes
    0064685 UCCONN Failed assumption ourPinConns > 0
    0064691 UCCONN Nothing in Alt
    0064696 UCCONN Failed assumption unionPtr->conn.net == netIndex
    0064718 UCOBS "firstSelected" out of range (1, DbView.obsMax)
    0064719 UCOBS Failed assumption DbView.obsMax < OBS_LIMIT
    0064818 UCTEXT "firstSelected" out of range (1, DbView.txtMax)
    0064819 UCTEXT Failed assumption DbView.txtMax < TEXT_LIMIT
    0064879 UCTEXT "-textPtr->symId" out of range (1, DbView.compMax)
    0065034 UPSYM Expected AltGetDepth () == 1, 1
    0065039 UPSYM Expected 1 == 0
    0065076 UPSYM "symIndex" out of range (1, DbView.symMax)
    0065077 UPSYM Failed assumption countComps
    0065089 UPSYM Expected AltGetDepth () == 1, 1
    0065090 UPSYM Expected altMax > 0
    0065093 UPSYM Failed assumption !visible
    0065094 UPSYM "symIndex" out of range (1, DbView.symMax)
    0065098 UPSYM Expected AltGetDepth () == 0, 0
    0065344 URINIT Failed assumption MzGoal
    0065345 UROBJ Expected Ui->windowType != IDS_ROUTE
    0065346 UROBJ "obsPtr->symId" out of range (1, DbView.symMax)
    0065346 URINIT Failed assumption GoalPath
    0065347 UROBJ Failed assumption compViewPtr->symIndex == obsPtr->symId
    0065390 UROBJ Failed assumption obsViewPtr->symId == 0
    0071344 NPPMAIN Expected AltGetDepth () == 0, 0
    0071346 NPPMAIN Allocating finalReportTable
    0071954 NPPINIT "reportIndex" out of range (1, DbView.ppMax)
    0072202 NPPDLG "formatKind" out of range (GERBER_FORMAT, EXTENDED_GERBER_FORMAT)
    0072232 NPPDLG "rotValue" out of range (ROT0, ROT270)
    0072282 NPPDLG2 "typeVal" out of range (HPPEN, HP7580)
    0072284 NPPDLG2 "typeVal" out of range (EPSON1, EPSON3)
    0072287 NPPDLG2 "typeVal" out of range (PEN1, PEN8)
    0075002 NPPGER Failed to allocate draw sort table
    0075002 NPPGER Unknown kind
    0075003 NPPGER "DbView.appMax" out of range (DeviceParameter.maxApp, DeviceParameter.maxApp)
    0075003 NPPGER Allocating AppTable
    0075003 NPPGER Unknown shape
    0075003 NPPPLOT Allocating AppTable
    0075003 NPPHPGL Allocating AppTable
    0075004 NPPGER Failed to allocate sort table
    0075005 NPPGER Failed assumption prevPtr
    0075007 NPPGER Unknown kind
    0075008 NPPGER Allocating StdAppTable
    0075009 NPPGER Failed assumption size > 12
    0075010 NPPGER "DbView.appMax" out of range (0, 0)
    0075020 NPPSIMAP Allocating one DRAW RECORD
    0075029 NPPGER Unknown shape
    0075032 NPPGER Failed assumption altView.kind == APP_KIND
    0075055 NPPGER Unable to complete spooling due to aperture overload
    0075063 NPPGER Failed assumption rememberSimulateTable
    0075083 NPPGER Unknown shape
    0075087 NPPGER Expected AltGetDepth () == 0, 0
    0075088 NPPGER Expected AltGetDepth () == 0, 0
    0075212 NPPRPT Allocating Drill Tape Table
    0075234 NPPRPT Failed assumption customReportXRef[idx] < iniPtr->count
    0075402 NPPNET connTable heap
    0075404 NPPNET Allocating connTable
    0075408 NPPNET local heap
    0075409 NPPNET Allocating buffer
    0075701 NPPCONN local heap
    0075703 NPPCONN Allocating buffer
    0075901 NPPNET3 viaCountTable heap
    0075904 NPPNET3 viaCountTable heap
    0075905 NPPNET3 Allocating viaCountTable
    0076089 NPPPART nppPartHeap heap
    0076100 NPPDRI1 Can't reallocate drill sort table
    0076103 NPPDRI1 drillTable heap
    0076104 NPPDRI1 Allocating DrillTable
    0076234 NPPTSTPT Unable to allocate via duplicate table
    0076301 NPPRENAM Failed assumption compIndex2
    0076303 NPPRENAM "pin1" out of range (1, maxPin)
    0076304 NPPRENAM Failed assumption compIndex2
    0076305 NPPRENAM Failed assumption compIndex2
    0076306 NPPRENAM Failed assumption compIndex2
    0076307 NPPRENAM Failed assumption AttrGet (WAS_ATTR, COMP_KIND, ...
    0076308 NPPRENAM Failed assumption ++chainLength <= DbView.compMax
    0076309 NPPRENAM Failed assumption AttrGet (WAS_ATTR, COMP_KIND, ...
    0076310 NPPRENAM Failed assumption compIndex2
    0076311 NPPRENAM Infinite pin rename loop
    0076313 NPPRENAM Failed assumption AttrGet (WAS_ATTR, COMP_KIND, ...
    0076314 NPPRENAM Failed assumption compIndex2
    0076502 NPPDTAPE Can't allocate flashPtr
    0076504 NPPDTAPE Can't allocate flashPtr
    0076506 NPPDTAPE Can't reallocate drill sort table
    0076508 NPPDTAPE Can't reallocate drill sort table
    0076510 NPPDTAPE Can't reallocate drill location table
    0076512 NPPDTAPE Local heap for drill tape
    0076514 NPPDTAPE Allocating DriTable
    0076516 NPPDTAPE Can't allocate DriPadsTable
    0214101 DBCOMP Failed assumption theDb
    0214102 DBCOMP Failed assumption theDb
    0214103 DBCOMP Failed assumption theDb
    0214104 DBCOMP Failed assumption theDb
    0214107 DBCOMP Failed assumption theDb
    0214108 DBCOMP Failed assumption theDb
    0214111 DBCOMP Failed assumption theDb
    0214115 DBCOMP Failed assumption theDb
    0214117 DBCOMP Failed assumption theDb
    0214121 DBCOMP Failed assumption theDb
    0214125 DBCOMP Failed assumption theDb
    0214131 DBCOMP Failed assumption theDb
    0436026 GEOTHERM Expected --infiniteLoopTest > 0
    0436029 GEOTHERM Expected --infiniteLoopTest > 0
    0436401 GEOTRACE Failed assumption MzGoal->connIndex != 0
    0436726 GEOTHERM Expected --infiniteLoopTest > 0
    0436729 GEOTHERM Expected --infiniteLoopTest > 0
    0520508 DBDLL Cannot find LAYOUT.CTL
    0520509 DBDLL Cannot find LAYOUT.FNT
    0520550 DBDLL No expanded memory
    0526703 DBPINMAP Failed assumption pinMap->ourUID > 0
    0712621 NPPDXF Failed assumption dpb->format == DXF_FORMAT
    0712623 NPPDXF Failed assumption DbView.boardXMin >= 0
    0712625 NPPDXF Failed assumption DbView.boardYMin >= 0
    0713183 NPPAPP3 Failed to allocate object_list HeapSlice in PltApp3
    0713192 NPPAPP3 Failed to allocate conTablePtr HeapSlice in PltApp3
    0713193 NPPAPP3 Failed to allocate conTablePtr HeapSlice in PltApp3
    0752001 NPPRPT Failed assumption iniPtr != NULL
    0752008 NPPRPT Drill tape heap
    0752016 NPPRPT Allocating buffer
    0752020 NPPRPT local heap
    0752031 NPPRPT Failed assumption iniPtr == NULL
    0752035 NPPRPT Failed assumption ReportHeap == 0
    0752062 NPPRPT local heap
    0752063 NPPRPT Allocating buffer
    0759020 NPPNET3 Allocating viaCountTable
    2150012 MZSHOVE Failed to allocate retry candidates in mzShovePath
    2150291 MZSHOVE Bad status in failRectCells
    2152018 MZCLEARS Failed assumption xC == pathPtr->crn[currentCrn+1].x
    2152052 MZCLEARS Failed assumption (dx == dy) || (dx == -dy)
    2152053 MZCLEARS Failed assumption rowInfo[rowLimit].x == x2
    2152072 MZCLEARS Failed to allocate rowInfo in ClearVert
    2152080 MZCLEARS Failed assumption rowInfo
    2152081 MZCLEARS Failed assumption stitchCrn (xC, yC, 0, 0)
    2152082 MZCLEARS "rowLimit" out of range (0, ROW_LIMIT*2)
    2152083 MZCLEARS Failed assumption stitchCrn(oldX, yC, oldLev, 0)
    2152084 MZCLEARS Failed assumption stitchCrn(xC, yC, oldLev, rowPtr->viaIndex)
    2152085 MZCLEARS Failed assumption stitchCrn(xC, oldY, oldLev, 0)
    2152086 MZCLEARS Failed assumption stitchCrn(xC, yC, oldLev, rowPtr->viaIndex)
    2152087 MZCLEARS Failed assumption stitchCrn (xC, yC, 0, 0)
    2152088 MZCLEARS Failed assumption stitchCrn (xC, yC, oldLev, rowPtr->viaIndex)
    2152089 MZCLEARS Failed assumption stitchCrn (xC, yC, 0, 0)
    2152090 MZCLEARS "rowLimit" out of range (0, ROW_LIMIT)
    2152091 MZCLEARS Failed assumption stitchCrn (xC, yC, Shove.level, 0)
    2152095 MZCLEARS Status error in failOneCell
    2152172 MZCLEARS Failed to allocate rowInfo in ClearVert
    2152346 MZCLEARS "(int) currentConn->crn[viaCrn].viaIndex" out of range (1, DbView.viaMax)
    2152350 MZCLEARS Failed assumption rowInfo
    2152351 MZCLEARS Failed assumption rowInfo
    2152450 MZCLEARS Failed assumption shadowRowInfo
    2152678 MZPUSH2 "ObjTable[obstacle].id" out of range (1, DbView.connMax)
    2152678 MZCLEARS "objRecord.id" out of range (1, DbView.connMax)
    2152988 MZCLEARS Failed assumption rowPtr == testPtr
    2152989 MZCLEARS Failed assumption pos >= 0
    2153002 MZCLEARV Failed assumption limit > 0
    2153010 MZCLEARV Failed assumption newCrn < CONN_CRN_LIMIT
    2153011 MZCLEARV Failed assumption newCrn < CONN_CRN_LIMIT
    2153015 MZCLEARV Failed assumption newCrn + returnPath->crns < CONN_CRN_LIMIT
    2153016 MZCLEARV Failed assumption newCrn + returnPath->crns < CONN_CRN_LIMIT
    2153019 MZCLEARV "newCrn" out of range (0, CONN_CRN_LIMIT-2)
    2153021 MZCLEARV "viaIndex" out of range (1, DbView.viaMax)
    2153022 MZCLEARV Failed assumption crn+2 < CONN_CRN_LIMIT
    2153023 MZCLEARV "recursionDepthRemaining" out of range (0, VIA_DEPTH_LIMIT*4)
    2153091 MZCLEARV Status error in stitchFailure
    2154235 MZPUSH Bad delta in PushSeg
    2154245 MZPUSH Failed assumption pushGoal->view.crn[crn+1].lev == 0
    2154246 MZPUSH Failed assumption  ...
    2154255 MZPUSH Failed assumption pushGoal->view.crn[crn].x < pushGoal->view.crn[crn+1].x
    2154270 MZPUSH Unexpected shovable object type
    2154271 MZPUSH Failed assumption IntSegSeg (&pushGoal->xNew, &pushGoal->yBNew, ...
    2154272 MZPUSH Failed assumption pushGoal->xOld == pushGoal->xNew
    2154273 MZPUSH Failed to allocate stack in PushInit
    2154274 MZPUSH Failed assumption pushGoal->yBNew >= pushGoal->view.crn[crn].y
    2154275 MZPUSH Failed assumption pushGoal->yBNew <= pushGoal->view.crn[crn+1].y
    2154276 MZPUSH Failed assumption pushGoal->yBNew >= pushGoal->view.crn[crn+1].y
    2154277 MZPUSH Failed assumption pushGoal->yBNew <= pushGoal->view.crn[crn].y
    2155112 MZPUSH2 Failed pushParallel test
    2155234 MZPUSH2 Failed assumption pushGoal->view.crn[crn].x == pushGoal->view.crn[crn+1].x
    2155235 MZPUSH2 Failed assumption pushGoal->view.crn[crn].y < pushGoal->view.crn[crn+1].y
    2155254 MZPUSH2 Failed assumption pushGoal->view.crn[crn].y == pushGoal->view.crn[crn+1].y
    2155270 MZPUSH2 Failed assumption thruLevView.shape != THRU_UNDEF_PAD
    2155351 MZPUSH2 Failed assumption crn == 0
    2155352 MZPUSH2 Failed assumption pushGoal->view.crn[crn].y == pushGoal->view.crn[crn+1].y
    2155353 MZPUSH2 Failed assumption crn == 0
    2155353 MZPUSH2 Failed assumption pushGoal->view.comp[0] == 0
    2155452 MZPUSH2 Failed assumption pushGoal->view.crn[0].x == pushGoal->view.crn[1].x
    2155453 MZPUSH2 Failed assumption pushGoal->view.comp[0] == 0
    2156255 MZALT Failed assumption ObjTable[altView.objIndex].id == altView.id
    2156257 MZALT Failed assumption ObjTable[altView.objIndex].id == altView.id
    2156258 MZALT Failed assumption ObjTable[altView.objIndex].id == altView.id
    2156259 MZALT Failed assumption ObjTable[altView.objIndex].id == altView.id
    2156282 MZALT unexpected kind
    2156283 MZALT unexpected kind
    2156284 MZALT unexpected kind
    2156285 MZALT unexpected kind
    2157211 MZCLEARJ Failed assumption crn1 > 0
    2157212 MZCLEARJ Failed assumption crn2 < connPtr->crns-1
    2157213 MZCLEARJ Failed assumption crn1 > 0
    2157214 MZCLEARJ Failed assumption crn2 < connPtr->crns-1
    2157218 MZCLEARJ Failed assumption length > 0
    2157239 MZCLEARJ Failed assumption crn1x % viaGrid == 0
    2157255 MZCLEARJ Status error in failJumper
    2157261 MZCLEARJ Failed assumption findJumper (newPath, count, &crn1, &crn2)
    2157264 MZCLEARJ Jumper segment with no via
    2157268 MZCLEARJ Failed assumption crn2 == crn1+1
    2157296 MZCLEARJ Infinite loop detected
    2157298 MZCLEARJ Infinite loop detected
    2157890 MZCLEARJ Unable to route horizontal or vertical jumpers
    2158220 MZPUSHP Failed assumption ShoveReserve
    2158223 MZPUSHP "pinNumber" out of range (1, symPtr->header.pads)
    2158224 MZPUSHP Failed assumption (ObjTable[objIndex].flags & OBJ_RECURSION) == 0
    2158227 MZPUSHP Failed assumption pinPtr[pinNumber].objIndex
    2160110 MZCONN "crn" out of range (0, connPtr->crns - 2)
    2160120 MZCONN Failed assumption (connPtr->crn[crn + 1].flags & CRN_ARC)
    2160180 MZCONN Bad flag during in connReduce
    2160180 DBCONN2 Bad flag during in ConnReduce2
    2160190 MZCONN ConnEdgeSplit vertical with no crossing
    2160200 MZCONN ConnEdgeSplit horizontal with no crossing
    2160230 MZCONN "firstCrn" out of range (0, lastCrn)
    2160240 MZCONN "lastCrn" out of range (firstCrn, connPtr->crns-1)
    2160310 MZCONN extra via in ConnReduce
    2160320 MZCONN missing via in ConnReduce
    2160330 MZCONN wrong via in ConnReduce
    2160340 MZCONN Bad via found in ConnReduce
    2160400 MZCONN "myIndex" out of range (Obj.connMin, Obj.connMax)
    2160401 MZCONN Failed assumption ObjTable[myIndex].kind == OBJ_CONN
    2160760 MZCONN Bad via shape found during viaMap
    2161080 MZRANK Heap for mzRank
    2161810 MZRANK Failed to allocate sort buffer in RankRoutes
    2161910 MZRANK Too many!  Must ignore
    2161970 MZRANK Bad sort in heapTest
    2162300 MZPICK Expected MzGoal->crn1Index < connPtr->crns - 1
    2162310 MZPICK Expected MzGoal->crn2Index == MzGoal->crn1Index + 1
    2162345 MZPICK Failed assumption DbView.thruMax > 0
    2163020 MZINIT Heap Map
    2163030 MZINIT Heap Near
    2163040 MZINIT Heap Seed
    2163410 MZINIT Failed to allocate ViaCost in mzInit
    2163420 MZINIT Failed to allocate LevTable in initLev
    2163532 MZINIT Failed assumption !mz.drcEnabled
    2163533 MZINIT Failed assumption !Obj.valid
    2164020 MZPREP Failed assumption DbView.viaMax <= THRU_VIA_LIMIT
    2164022 MZPREP Failed assumption crn >= 0
    2164024 MZPREP "MzGoal->crn2Index" out of range (crn+1, connPtr->crns-1)
    2164040 MZPREP "value" out of range (0, 100)
    2164042 MZPREP Failed assumption nominal >= 0
    2164072 MZPREP Failed to allocate rowInfo in ClearVert
    2164073 MZPREP PrepRipBack Walked off edge
    2164090 MZPREP Failed assumption ObjTable[MzGoal->objIndex].kind == OBJ_CONN
    2164092 MZPREP "MzGoal->objIndex" out of range (Obj.connMin, Obj.connMax)
    2164093 MZPREP Failed assumption crn1 >= 0
    2164094 MZPREP "crn2" out of range (crn1+1, connPtr->crns-1)
    2164095 MZPREP "MzGoal->connIndex" out of range (1, DbView.connMax)
    2164298 MZPREP Failed assumption actualViaCost
    2164299 MZPREP Failed assumption LevTable
    2164333 MZPREP Expected mz.usedVias != 0
    2164398 MZPREP Failed assumption actualViaCost
    2164399 MZPREP Failed assumption LevTable
    2165003 MZPATH Failed assumption !MzGoal->hopActive
    2165011 MZPATH Kludge
    2165015 MZPATH Impossible back track
    2165070 MZPATH "pathPtr->crns" out of range (2, CONN_CRN_LIMIT-1)
    2165076 MZPATH Couldn't find reconnect reason
    2165077 MZPATH Default case in connectToTarget
    2165079 MZPATH How did we get here?
    2165083 MZPATH Failed assumption lastCrn > 0
    2165092 MZPATH "crn" out of range (1, conn2Ptr->crns-1)
    2166027 MZCHECK Bad shape in checkConnSeg
    2166028 MZCHECK Bad mark in checkConnRect
    2166029 MZCHECK Bad mark in checkConnRect
    2166030 MZCHECK Bad mark in checkConnSeg
    2166031 MZCHECK Bad mark in checkConnSeg
    2166036 MZCHECK Failed assumption majorId > 0
    2166037 MZCHECK Failed assumption object > 0
    2166038 MZCHECK bad shape found during checkConnRect
    2166078 MZCHECK Bad shape in checkConnConn
    2166079 MZCHECK Bad shape in checkConnConn
    2166080 MZCHECK Failed assumption crn1 >= 0
    2166082 MZCHECK "crn2" out of range (crn1, connPtr->crns-1)
    2166083 MZCHECK bad shape found during checkConnRotPad
    2166084 MZCHECK Bad mark in checkConnRotPad
    2166087 MZCHECK Bad mark in checkConn
    2166088 MZCHECK bad object kind in checkConn
    2166091 MZCHECK Bad fill type in checkConnObs
    2166092 MZCHECK Bad mark in checkConnRotPad
    2166093 MZCHECK Bad mark in checkJumpers
    2166094 MZCHECK Failed assumption attr.minorKind == THRU_KIND
    2166098 MZCHECK Bad shape in checkConnPad
    2166387 MZCHECK Bad mark in checkConn
    2167009 MZQTREE Bad object in MzQTreeGatherShovable
    2167009 MZGATHER Bad object in GatherShovable
    2167011 MZGATHER Failed assumption Obj.valid
    2167012 MZGATHER "lev" out of range (0, DbView.levMax)
    2167014 MZGATHER Bad entry in GatherAll
    2167020 MZGATHER "myIndex" out of range (1, Obj.objMax)
    2167021 MZGATHER Bad object in GatherAll
    2167022 MZGATHER "lev" out of range (0, DbView.levMax)
    2167023 MZGATHER Bad pushDir in GatherShovable
    2167029 MZGATHER Failed assumption Obj.valid
    2167030 MZGATHER Failed assumption Obj.valid
    2167031 MZGATHER "myIndex" out of range (1, Obj.objMax)
    2167032 MZQTREE "lev" out of range (0, DbView.levMax)
    2167032 MZGATHER "lev" out of range (0, DbView.levMax)
    2167033 MZGATHER "lev" out of range (0, DbView.levMax)
    2167039 MZGATHER Bad object in GatherIsEmpty
    2167080 MZGATHER Failed assumption crn1 >= 0
    2167081 MZGATHER Failed assumption Obj.valid
    2167082 MZGATHER "crn2" out of range (crn1, connPtr->crns-1)
    2167091 MZGATHER Bad obstacle in queryObs
    2167801 MZGATHER Failed assumption ObjTable[myIndex].kind == OBJ_CONN
    2167802 MZGATHER Failed assumption ObjTable[myIndex].kind == OBJ_CONN
    2167803 MZGATHER Failed assumption ObjTable[objIndex].kind == OBJ_PAD
    2167805 MZGATHER Failed assumption ObjTable[myObjIndex].kind == OBJ_OBS
    2167806 MZGATHER Failed assumption ObjTable[myObjIndex].kind == OBJ_TEXT
    2169004 MZMAZE "SfView.routeLayers" out of range (0, LEV_ETCH_LIMIT)
    2169010 MZMAZE "x" out of range (0, mz.statusWidth-1)
    2169011 MZMAZE "SfView.xMax" out of range (2, ROW_LIMIT)
    2169012 MZMAZE "y" out of range (0, mz.statusHeight-1)
    2169013 MZMAZE "SfView.yMax" out of range (2, 2*ROW_LIMIT)
    2169014 MZMAZE "level" out of range (1, DbView.levMax)
    2169015 MZMAZE Failed assumption LevTable[level].enabled
    2169016 MZMAZE "x" out of range (0, mz.statusWidth-1)
    2169017 MZMAZE "y" out of range (0, mz.statusHeight-1)
    2169018 MZMAZE "level" out of range (1, DbView.levMax)
    2169019 MZMAZE Failed assumption LevTable[level].enabled
    2169020 MZMAZE "x" out of range (0, mz.statusWidth-1)
    2169021 MZMAZE "level" out of range (1, DbView.levMax)
    2169022 MZMAZE "y" out of range (0, mz.statusHeight-1)
    2169023 MZMAZE Failed assumption LevTable[level].enabled
    2169024 MZMAZE Failed assumption mz.hopAllocated
    2169025 MZMAZE Failed assumption mz.mazeAllocated
    2169026 MZMAZE Failed assumption numberOfStatusLayers > 0
    2169027 MZMAZE "y" out of range (0, mz.statusHeight-1)
    2169028 MZMAZE "level" out of range (1, DbView.levMax)
    2169029 MZMAZE Failed assumption LevTable[level].enabled
    2169030 MZMAZE "x" out of range (0, mz.statusWidth-1)
    2169081 MZMAZE Failed assumption LevTable[lev].enabled
    2169082 MZMAZE "level" out of range (1, DbView.levMax)
    2169087 MZMAZE Failed assumption mz.mazeAllocated
    2169345 MZMAZE resetFull not properly initialized
    2169421 MZMAZE "(short) level" out of range (1, DbView.levMax)
    2169423 MZMAZE Failed assumption LevTable[level].enabled
    2169425 MZMAZE "statusLev" out of range (1, 16)
    2169555 MZMAZE "statusLev" out of range (1, 16)
    2170012 MZWAVE Failed assumption bitCount == 1
    2170014 MZWAVE "size" out of range (4, EXP_SIZE)
    2170040 MZWAVE "ptr->x" out of range (2, mz.statusWidth-2)
    2170042 MZWAVE "ptr->y" out of range (2, mz.statusHeight-2)
    2170046 MZWAVE "ptr->lev" out of range (1, DbView.levMax)
    2170048 MZWAVE Failed assumption LevTable[ptr->lev].enabled
    2170056 MZWAVE Failed assumption waveValid
    2170060 MZWAVE Failed assumption waveSize == 0);  // Give up ...
    2170070 MZWAVE Expected waveSize == 0
    2170080 MZWAVE Failed assumption mz.mapValid
    2170081 MZWAVE Failed assumption waveValid
    2170092 MZWAVE Bad cell class in WaveRun
    2170093 MZWAVE Bad cell class in FastRun
    2171004 MZMAP "lev" out of range (1, DbView.levMax)
    2171008 MZMAP "lev" out of range (1, DbView.levMax)
    2171020 MZMAP "myIndex" out of range (2, Obj.objMax)
    2171022 MZMAP "lev" out of range (0, DbView.levMax)
    2171030 MZMAP "myIndex" out of range (2, Obj.objMax)
    2171032 MZMAP "lev" out of range (0, DbView.levMax)
    2171040 MZMAP "myIndex" out of range (1, Obj.objMax)
    2171042 MZMAP "lev" out of range (0, DbView.levMax)
    2171081 MZMAP "lev" out of range (0, DbView.levMax)
    2171091 MZMAP "lev" out of range (0, DbView.levMax)
    2171098 MZMAP "lev" out of range (1, DbView.levMax)
    2172093 MZCOMP Failed assumption unionPtr->conn.comp[0] == compId
    2172094 MZCOMP Needs comment:  line 496, mzcomp.c
    2172464 MZCOMP Failed assumption AltLoadShadow (altIndex, &altView, unionPtr)
    2173023 MZOBS Undefined state in findNet
    2173026 MZOBS Failed assumption currentObsPtr->crns < OBS_CRN_LIMIT
    2173043 MZOBS Failed assumption myHeap == 0
    2173076 MZOBS Failed assumption currentObsPtr->lev != 0
    2174001 MZSEED Failed to allocate seed record in createSeedRecord
    2174005 MZSEED Failed assumption LevTable[level].enabled
    2174084 MZSEED "lev" out of range (0, DbView.levMax)
    2176052 MZSTRAIT Failed assumption crn2 == crn1+2
    2177012 MZNEAR Failed to allocate nearestPath in NearestReset
    2177678 MZNEAR Expected nearestPath != NULL
    2181021 MZMEM Failed assumption thruView.shape != THRU_UNDEF_PAD); /* Shouldn't be in map */ ...
    2181040 MZMEM Failed assumption ObjTable[middleObj].kind == OBJ_PAD
    2181042 MZMEM "middleLev" out of range (1, DbView.levMax)
    2185016 MZVIA Failed assumption otherThruView.rotation == 0); /* Kludge */ ...
    2185024 MZVIA "viaIndex" out of range (1, DbView.viaMax)
    2185041 MZVIA "lev1" out of range (0, DbView.levMax)
    2185042 MZVIA "lev2" out of range (0, DbView.levMax)
    2185052 MZVIA "viaIndex" out of range (1, DbView.viaMax)
    2185062 MZVIA "viaIndex" out of range (1, DbView.viaMax)
    2185073 MZVIA Failed assumption lastCrn < connPtr->crns
    2185074 MZVIA "firstCrn" out of range (0, lastCrn-1)
    2186017 MZOBJ Failed assumption Obj.valid
    2186018 MZOBJ Failed assumption ObjTable
    2186019 MZOBJ "index" out of range (0, Obj.objMax)
    2186021 MZOBJ Failed assumption Obj.valid
    2186022 MZOBJ Failed assumption ObjTable
    2186023 MZOBJ "index" out of range (0, Obj.objMax)
    2186026 MZOBJ Failed assumption Obj.valid
    2186027 MZOBJ Failed assumption ObjTable
    2186028 MZOBJ Failed assumption ObjTable[objIndex].kind == OBJ_CONN
    2186034 MZOBJ Failed assumption ObjTable
    2186043 MZOBJ "index" out of range (0, Obj.objMax)
    2186044 MZOBJ Bad object in ObjOut
    2186049 MZOBJ Bad object in ObjAdd
    2186073 MZOBJ Failed to allocate object table in ObjInit
    2186092 MZOBJ Failed assumption ObjTable
    2186236 MZOBJ Failed assumption Obj.valid
    2186237 MZOBJ Failed assumption ObjTable
    2186336 MZOBJ Failed assumption Obj.valid
    2186337 MZOBJ Failed assumption ObjTable
    2186521 MZOBJ Failed assumption Obj.valid
    2186522 MZOBJ Failed assumption ObjTable
    2186934 MZOBJ Failed assumption ObjTable
    2187014 MZPAD "level" out of range (0, DbView.levMax)
    2187081 MZPAD Failed assumption connPtr->crns > 3
    2187082 MZPAD Failed assumption PT_IN_MAP (xCrn, yCrn)
    2187087 MZPAD This crn has a redundant via
    2187091 MZPAD Failed assumption viaIndex > 0
    2187100 MZPAD Failed assumption dirDist[0] <= dirDist[1]
    2187101 MZPAD Failed assumption dirDist[1] <= dirDist[2]
    2187102 MZPAD Failed assumption dirDist[2] <= dirDist[3]
    2187103 MZPAD Failed assumption testNDist == dirDist[NDist]
    2187104 MZPAD Failed assumption numberOfBlocks < 5
    2187667 MZPAD Failed assumption (result & (DIR_NE | DIR_NW | DIR_SW | DIR_NE)) == 0
    2189012 MZCHECK2 ALT kind not supported
    2189023 MZCHECK2 bad mark type found during checkPadExit
    2189041 MZCHECK2 Failed assumption comp1
    2189043 MZCHECK2 Failed assumption comp2
    2189044 MZCHECK2 Failed assumption pin2
    2189072 MZCHECK2 Unexpected object type
    2189078 MZCHECK2 Bad shape in checkPadToVia
    2189080 MZCHECK2 Failed assumption crn1 >= 0
    2189082 MZCHECK2 "crn2" out of range (crn1, connPtr->crns-1)
    2189091 MZCHECK2 EDGE or ERROR found during MarkError
    2189095 MZCHECK2 Bad shape in checkOnePad
    2189223 MZCHECK2 bad mark type found during checkPadLevel
    2189306 MZCHECK2 Bad kind in OBJ table
    2189307 MZCHECK2 Bad kind in OBJ table
    2189543 MZCHECK2 Failed assumption compPtr->flags2 & COMP_FREE_AND_TP
    2190620 MZCLEAN Failed assumption conn1.beg <= conn1.end
    2190630 MZCLEAN Failed assumption conn2.beg <= conn2.end
    2190880 MZCLEAN Default object in processObject
    2192310 MZCLEAN2 "(int) conn1->view->crn[crn1].viaIndex" out of range (1, DbView.viaMax)
    2192320 MZCLEAN2 "(int) conn2->view->crn[crn2].viaIndex" out of range (1, DbView.viaMax)
    2192470 MZCLEAN2 "viaIndex" out of range (1, DbView.viaMax)
    2192620 MZCLEAN2 "viaIndex" out of range (1, DbView.viaMax)
    2192710 MZCLEAN2 "viaIndex" out of range (1, DbView.viaMax)
    2194230 MZCLEANX Default checkFlag in checkEndAngle
    2201056 MZCHECKO Failed assumption ! (obs1Ptr->flags & (OBS_CIRCLE | OBS_ARC))
    2201057 MZCHECKO Failed assumption ! (obs2Ptr->flags & (OBS_CIRCLE | OBS_ARC))
    2201080 MZCHECKO Failed assumption idx != myObsId
    2201086 MZCHECKO Failed assumption textId
    2201306 MZCHECKO Bad kind in OBJ table
    2202010 MZQTREE Tree Heap
    2202080 MZQTREE Failed assumption crn1 >= 0
    2202082 MZQTREE "crn2" out of range (crn1, connPtr->crns-1)
    2202110 MZQTREE Couldn't allocate first quad entry
    2202241 MZQTREE "lev" out of range (0, DbView.levMax)
    2202330 MZQTREE Failed assumption mz.qtreeActive
    2202339 MZQTREE Bad object in MzQTreeGatherIsEmpty
    2202423 MZQTREE Bad pushDir in GatherShovable
    2202440 MZQTREE Couldn't allocate first quad entry
    2202443 MZQTREE Failed assumption 0 == 1
    2202444 MZQTREE Failed assumption 0 == 1
    2202501 MZQTREE "compId" out of range (1, DbView.compMax)
    2202664 MZQTREE Failed assumption treeHeap
    2202666 MZQTREE Failed assumption erase == NO
    2202668 MZQTREE Failed assumption treeHeap
    2202991 MZQTREE Bad obstacle in queryObs
    2301456 URFANOUT "newIndex" out of range (1, DB_ERROR_LIMIT)
    2301456 MZDISP "newIndex" out of range (1, DB_ERROR_LIMIT)
    2301901 MZDISP Failed assumption ObjTable[objIndex].kind == OBJ_PAD
    2301903 MZDISP "compIndex" out of range (1, DbView.compMax)
    2301904 MZDISP "netIndex" out of range (0, DbView.netMax)
    2301905 MZDISP "pinIndex" out of range (1, SymPads (compView.symIndex))
    2302323 MZDISPR "ObjTable[objIndex].net" out of range (1, DbView.netMax)
    2302405 MZDISPR Failed assumption ++maxPad <= SYM_PAD_LIMIT
    2302411 MZDISPR Linked list of pads to disperse
    2302710 MZDISPR Cannot allocate temporary sort table
    2302808 MZDISPR Heap for scoring components and pins
    2302810 MZDISPR Cannot allocate temporary table to compute cluster areas
    2302815 MZDISPR Allocating one component score record
    2303011 MZFANOUT "info->pinLev" out of range (1, DbView.levMax)
    2303011 MZDISPP "info->pinLev" out of range (1, DbView.levMax)
    2303234 MZFRVIA Expected AltGetDepth () > 0, 1
    2303272 MZFANOUT Bad search direction
    2303272 MZDISPP Bad search direction
    2303292 MZFANOUT Bad search direction
    2303292 MZDISPP Bad search direction
    2303456 MZFRVIA Allocating locationTable
    2303457 MZFRVIA Allocating locationTable
    2303458 MZFRVIA Allocating locationTable
    2303587 MZFRVIA Failed assumption connPtr->pin[0] == 1
    2303716 MZDISPP Failed assumption PT_IN_MAP (info->xPad, info->yPad)
    2303760 MZFANOUT Failed assumption info->shift > 0
    2303760 MZDISPP Failed assumption info->shift > 0
    3130701 WINDLG "ctl[idx].state" out of range (0, 2)
    3130920 WINDLG Help id not defined for dialog
    3602120 PLBUBBLE "plView.cooldown" out of range (0, 100)
    3602220 PLBUBBLE Failed assumption ClustTablePtr[clustId].compPtr
    3602380 PLBUBBLE "compId" out of range (1, DbView.compMax)
    3602620 PLBUBBLE Failed assumption NetClustTable
    3602730 PLBUBBLE Failed assumption clustRecord.compPtr
    3602880 PLBUBBLE "compId" out of range (1, DbView.compMax)
    3604070 PLCLUST "compId" out of range (1, DbView.compMax)
    3604120 PLCLUST "plView.cooldown" out of range (0, 100)
    3604140 PLCLUST "netId" out of range (1, DbView.netMax)
    3604240 PLCLUST "compId" out of range (1, DbView.compMax)
    3604310 PLCLUST "groupId" out of range (1, DbView.compMax)
    3604311 PLCLUST "groupId" out of range (1, GROUP_LIMIT)
    3604410 PLCLUST Failed assumption compPtr
    3604440 PLCLUST Failed assumption netOut >= 0
    3604470 PLCLUST "netId" out of range (1, DbView.netMax)
    3604480 PLCLUST Failed assumption netPtr
    3604610 PLCLUST Failed assumption NetClustTable
    3604620 PLCLUST Failed assumption NetClustTable
    3604630 PLCLUST Failed assumption NetClustTable
    3604640 PLCLUST Failed assumption ClustTablePtr
    3604650 PLCLUST Failed assumption NetClustTable
    3604660 PLCLUST Failed assumption netCompTable
    3604670 PLCLUST Failed assumption NetClustTable
    3604680 PLCLUST Failed assumption NetClustTable
    3604690 PLCLUST Failed assumption NetClustTable
    3604710 PLCLUST Failed assumption netPtr
    3604740 PLCLUST Failed assumption netCompTable
    3604760 PLCLUST Failed to allocate group table
    3606010 PLANNEAL Selected Heap
    3606120 PLANNEAL "plView.cooldown" out of range (0, 100)
    3606220 PLANNEAL Failed assumption placeXGrid > 0
    3606230 PLANNEAL Failed assumption placeYGrid > 0
    3606380 PLANNEAL "comp" out of range (1, DbView.compMax)
    3606760 PLANNEAL Failed to allocate component selelection table
    3606810 PLANNEAL Failed assumption compSelected
    3607010 PLPAIR Failed to allocate net pairs
    3607020 PLPAIR Failed to allocate drag pairs
    3607030 PLPAIR Failed to allocate selected component table
    3607050 PLPAIR Failed to allocate empty pairview
    3607350 PLPAIR Failed to allocate net pairs
    3607410 PLPAIR Pair Heap
    3607420 PLPAIR Pair Selected Heap
    3607510 PLPAIR Failed assumption compSelected
    3607520 PLPAIR Failed assumption netPairs
    3607550 PLPAIR Failed assumption pairPtr->count < PAIR_LIMIT
    3607560 PLPAIR Failed to allocate drag pair
    3607610 PLPAIR Failed assumption compSelected
    3607620 PLPAIR Failed assumption netPairs
    3607810 PLPAIR Failed assumption compSelected
    3607820 PLPAIR Failed assumption dragPairs
    3607830 PLPAIR Failed assumption resultPtr
    3607910 PLPAIR Failed assumption compSelected
    3608020 PLRECON Failed to allocate new pair
    3608040 PLRECON "hashCount" out of range (1, PAIR_LIMIT)
    3608120 PLRECON Can not allocate hash element
    3608240 PLRECON "link" out of range (0, PAIR_LIMIT)
    3608260 PLRECON "link" out of range (0, PAIR_LIMIT)
    3608320 PLRECON Can not allocate pair hash
    3608420 PLRECON Recon Heap
    3608430 PLRECON Recon Edge Heap
    3608510 PLRECON Failed to allocate new node
    3608520 PLRECON Failed to allocate new pair
    3608610 PLRECON Failed to allocate new node
    3608710 PLRECON Failed to allocate new pair
    3608720 PLRECON Failed to allocate new pair
    3608770 PLRECON Failed to allocate new edge
    3608820 PLRECON Failed assumption dragPairs
    3609010 PLINIT Selected Heap
    3609020 PLINIT Component Heap
    3609040 PLINIT Cluster Heap
    3609060 PLINIT Failed to allocate component table
    3609090 PLINIT Failed assumption compHeap
    3609140 PLINIT "netId" out of range (1, DbView.netMax)
    3609160 PLINIT Failed to allocate net-component bit map
    3609170 PLINIT Failed to allocate net-component row
    3609210 PLINIT Failed assumption plView.levMax < PLACE_LAYER_LIMIT
    3609220 PLINIT Failed assumption placeToXGrid > 0
    3609230 PLINIT Failed assumption placeToYGrid > 0
    3609240 PLINIT "compId" out of range (1, DbView.compMax)
    3609250 PLINIT Failed to allocate cluster table
    3609260 PLINIT Failed to allocate net-cluster bit map
    3609270 PLINIT Failed to allocate net-cluster row
    3609360 PLINIT Failed to allocate net weights table
    3609370 PLINIT Failed to allocate net-node table
    3609390 PLINIT Failed to allocate table of components to process
    3609440 PLINIT Failed to allocate obstacle table
    3609470 PLINIT "compLimit" out of range (1, COMP_LIMIT)
    3609480 PLINIT "DbView.netMax" out of range (0, NET_LIMIT)
    3609610 PLINIT Failed to allocate component net-list record
    3609647 PLINIT "compId" out of range (1, DbView.compMax)
    3609657 PLINIT "clustId" out of range (1, CLUSTER_LIMIT)
    3609660 PLINIT Failed to allocate test table
    3609710 PLINIT Failed assumption DbView.placeXGrid > 0
    3609720 PLINIT Failed assumption DbView.placeYGrid > 0
    3609750 PLINIT Failed to allocate component record
    3609760 PLINIT Failed to allocate component selelection table
    3609780 PLINIT "compLev" out of range (1, DbView.levMax)
    3609830 PLINIT Failed to allocate net node record
    3610010 PLNEXT Allocate a heap for scoreTable and netFlagTable
    3610050 PLNEXT Failed to allocate net flag table
    3610110 PLNEXT compNetHeap
    3610150 PLNEXT Failed to allocate comp net table
    3610170 PLNEXT Failed to allocate comp net table
    3610710 PLNEXT Can't allocate left stack
    3610730 PLNEXT Can't allocate right stack
    3610760 PLNEXT Failed to allocate component selection table
    3612010 PLPACK Spread Heap
    3612120 PLPACK Expected AltGetDepth () > 0, 1
    3612200 PLPACK Failed assumption (spreadTable[compId].enabled == YES)
    3612210 PLPACK Failed assumption (spreadTable[compId].processed == NO)
    3612250 PLPACK Bad direction in minimizeCompScore
    3612660 PLPACK Failed to allocate component spread table
    3612760 PLPACK Failed to allocate component selelection table
    3613010 PLPIN Pin Selected Heap
    3613060 PLPIN Bad segment in SwapPins
    3613100 PLPIN Failed assumption netCount == 1
    3613160 PLPIN Bad connection in swapPinsInstall
    3613960 PLPIN Failed to allocate component selelection table
    3614110 PLSCORE Failed assumption reconnectTable
    3614130 PLSCORE Failed assumption reconnectTable
    3614140 PLSCORE "netId" out of range (1, DbView.netMax)
    3614150 PLSCORE "netId" out of range (1, DbView.netMax)
    3614170 PLSCORE "netId" out of range (1, DbView.netMax)
    3614370 PLSCORE Failed to allocate reconnect table
    3614580 PLSCORE "compId" out of range (1, DbView.compMax)
    3614780 PLSCORE "compId" out of range (1, DbView.compMax)
    3614870 PLSCORE Failed assumption NetNodePtr
    3615580 PLSWAP "compId" out of range (1, DbView.compMax)
    3615760 PLSWAP Failed to allocate component selelection table
    3616010 PLDENSE Density Map Heap
    3616030 PLDENSE Failed to allocate map
    3616040 PLDENSE Failed to allocate row of the density map
    3616990 PLDENSE Expected result >= 0.0
    3617010 PLMATRIX Matrix Heap
    3617110 PLMATRIX Cannot allocate comp record
    3617170 PLMATRIX Cannot allocate cell record
    3618010 PLTREE Tree Heap
    3618070 PLTREE Failed PlTreeClose test
    3618110 PLTREE Couldn't allocate first quad entry
    3618190 PLTREE obstacle missing from map
    3618440 PLTREE Couldn't allocate first quad entry
    3618710 PLTREE Failed assumption --count >= 0
    3618720 PLTREE Failed assumption count == 0
    3618810 PLTREE Failed assumption compPtr
    3618910 PLTREE Failed assumption foundCount <= 1
    3618920 PLTREE Failed assumption classify[obs1Ptr->kind] != CLASS_KEEPIN
    3618940 PLTREE Failed assumption classify[obs1Ptr->kind] != CLASS_KEEPIN
    3618980 PLTREE Failed assumption classify[obsPtr->kind] != CLASS_KEEPIN
    3619010 PLGATE Gate Heap
    3619140 PLGATE "netId" out of range (1, DbView.netMax)
    3619240 PLGATE "netId" out of range (1, DbView.netMax)
    3619340 PLGATE "netId" out of range (1, DbView.netMax)
    3619370 PLGATE Failed to allocate reconnect table
    3619440 PLGATE "netId" out of range (1, DbView.netMax)
    3619790 PLGATE Failed assumption pin1 == newPin2[pin2]
    3619820 PLGATE Failed assumption NetNodePtr
    3619840 PLGATE Failed assumption reconnectTable
    3620010 PLGROUP Group Heap
    3620020 PLGROUP Group Heap2
    3620070 PLGROUP Failed to allocate group table
    3620220 PLGROUP Failed assumption compNumber < COMP_GROUP_LIMIT
    3620420 PLGROUP Failed assumption compNumber < COMP_GROUP_LIMIT
    3620470 PLGROUP Failed to allocate group record
    3620480 PLGROUP "compId" out of range (1, DbView.compMax)
    3620640 PLGROUP Failed assumption netCompTable
    3620670 PLGROUP Failed to allocate group record
    3621010 PLRENAME rename Heap
    3621030 PLRENAME Bucket Heap
    3621036 PLRENAME Failed assumption BUCKET_TABLE_LIMIT < 32000
    3621070 PLRENAME Failed to allocate name table
    3621120 PLRENAME Failed to allocate bucket record
    3621170 PLRENAME Failed to allocate bucket table
    3621170 PLRENAME Failed to allocate duplicate table
    3621270 PLRENAME Failed to allocate currentName
    3621580 PLRENAME Failed assumption len <= LSTR_LIMIT
    3621590 PLRENAME Failed assumption renameLimit > 0
    3621590 PLRENAME Failed assumption symPtr->header.derived != 0
    3621680 PLRENAME Failed assumption nameTable[nameTableId].selected == YES
    3622010 PLCAPS Caps Heap
    3622090 PLCAPS Failed assumption CompTablePtr
    3622110 PLCAPS Cannot allocate cap record
    3622120 PLCAPS Cannot allocate component record
    3622190 PLCAPS Failed assumption CompGoalTable
    3622220 PLCAPS Failed assumption placeXGrid > 0
    3622230 PLCAPS Failed assumption placeYGrid > 0
    3622240 PLCAPS Failed assumption bestPtr->numberOfCaps < 2
    3624100 PLCLEAR Expected AltGetDepth () > 0, 1
    3624120 PLCLEAR Expected AltGetDepth () > 0, 1
    3624124 PLCLEAR Failed to alloc obsInnerTable
    3624125 PLCLEAR Failed to alloc innerPtr
    3624345 PLCLEAR Failed assumption innerPtr != NULL
    3624940 PLCLEAR Infinite loop detected
    3625030 PLSHOVE Failed assumption (blockedDir & shoveDir) == 0
    3625060 PLSHOVE Bad shoveDir
    3625124 PLSHOVE Failed to alloc obsInnerTable
    3625125 PLSHOVE Failed to alloc innerPtr
    3625130 PLSHOVE "recursionLimit" out of range (0, RECURSION_LIMIT)
    3625290 PLSHOVE Failed assumption !(compView.flag & COMP_NOT_PLACED)
    3625345 PLSHOVE Failed assumption innerPtr != NULL
    3626010 PLMEM Selected Heap
    3626220 PLMEM Failed assumption placeXGrid > 0
    3626230 PLMEM Failed assumption placeYGrid > 0
    3626233 PLMEM Failed assumption compPtr->type == COMP_MEMORY
    3626241 PLMEM Failed assumption bestRows > 0
    3626242 PLMEM Failed assumption bestColumns > 0
    3626337 PLMEM Expected compCount > 0
    3626338 PLMEM Expected compPtr
    3626657 PLMEM "compPtr->clustId" out of range (1, CLUSTER_LIMIT)
    3626760 PLMEM Failed to allocate component selelection table
    4351550 GEOSEG Failed assumption hatchPtr
    4351557 GEOSEG Failed assumption iSect[0].seg == NULL
    4351558 GEOSEG Failed assumption iSect[0].x <= iSect[1].x
    4351559 GEOSEG Failed assumption iSect[iCount-1].x >= iSect[iCount-2].x
    4352010 GEOSPLIT Failed to allocate seglist heap
    4352010 GEOOBS Failed to allocate seglist heap
    4352020 GEOOBS Failed to allocate seglist heap
    4352082 GEOOFFST Failed assumption obsPtr->flags & OBS_SHRINKED
    4352111 GEOOBS Failed assumption chainTableSize > 0
    4352112 GEOOBS Failed assumption chainPtr
    4352143 GEOSPLIT Failed to allocate new seg record
    4352143 GEOOBS Failed to allocate new seg record
    4352151 GEOSPLIT Failed assumption obsTail->next == NULL
    4352151 GEOOBS Failed assumption obsTail->next == NULL
    4352183 GEOOBS Failed to allocate new seg record
    4352340 GEOSPLIT Failed to allocate new seglist record
    4352340 GEOOBS Failed to allocate new seglist record
    4352341 GEOSPLIT Failed to allocate new altlist record
    4352341 GEOOBS Failed to allocate new altlist record
    4352350 GEOSPLIT Failed to allocate new seglist record
    4352350 GEOOBS Failed to allocate new seglist record
    4352351 GEOSPLIT Failed to allocate new altlist record
    4352351 GEOOBS Failed to allocate new altlist record
    4352359 GEOOBS Failed to allocate new seglist record
    4352371 GEOSPLIT Failed to allocate chainTable in GeoObs
    4352371 GEOOBS Failed to allocate chainTable in GeoObs
    4353022 GEOOFFST Failed assumption ObsIsClosed (obsPtr)
    4353098 GEOOFFST Bad orientation in offsetPoly
    4353122 GEOOFFST Failed assumption (obsPtr->kind == OBS_KEEPOUT || obsPtr->kind == OBS_HOLE)
    4353220 GEOOFFST "crn" out of range (0, connPtr->crns - 1)
    4353222 GEOOFFST Failed assumption obsPtr->kind == OBS_KEEPOUT
    4353230 GEOOFFST "crn" out of range (0, obsPtr->crns - 1)
    4353310 GEOOFFST "viaIndex" out of range (1, DbView.viaMax)
    4353710 GEOOFFST "symIndex" out of range (1, DbView.symMax)
    4353720 GEOOFFST "pin" out of range (1, SymPads(symIndex))
    4353780 GEOOFFST Bad shape in offsetVia
    4353980 GEOOFFST Bad shape in OffsetPad
    4354100 GEOPOUR Failed assumption obsPtr->kind == OBS_POURED_COPPER
    4354103 GEOPOUR Failed assumption parentHead
    4354120 GEOPOUR "obsIndex" out of range (1, DbView.obsMax)
    4354123 GEOPOUR "netIndex" out of range (1, DbView.netMax)
    4354129 GEOPOUR "compId" out of range (1, DbView.compMax)
    4354440 GEOPOUR Failed to allocate new poly record
    4354441 GEOPOUR Failed to allocate new seg record
    4354444 GEOPOUR Failed to allocate parent poly
    4354445 GEOPOUR Failed to allocate new seg record
    4354446 GEOPOUR Failed to allocate new share record
    4354447 GEOPOUR Failed to allocate new share record
    4354525 GEOPOUR Failed assumption connPtr->crn[crn+1].flags & CRN_ARC
    4354723 GEOPOUR Undefined state in findNet
    4354776 GEOPOUR Failed assumption obsPtr->lev != 0
    4354923 GEOPOUR findNet: symIndex == 0 for assigned pin
    4355627 GEOCHECK Bad shape in queryConnSeg
    4355691 GEOCHECK Failed assumption obsPtr->kind == OBS_KEEPOUT
    4357001 GEOFILE Failed assumption parentHead != NULL
    4357013 GEOFILE "kind" out of range (PARENT_KIND, HEAT_KIND)
    4357063 GEOFILE "rHeader.kind" out of range (PARENT_KIND, HEAT_KIND)
    4357101 GEOFILE Failed assumption polyHeap != 0
    4357321 GEOFILE Failed assumption currentPoly != NULL
    4357340 GEOFILE Failed to allocate new seg record
    4357440 GEOFILE Failed to allocate new poly record
    4357445 GEOFILE Unknown poly kind
    4361010 GEODRD Create a new drill record
    4361090 GEODRD Expected DbView.drillChart.drill[idx].symbol
    4361092 GEODRD Failed assumption DbView.drillChart.drill[idx].symbol
    4361096 GEODRD Failed assumption DbView.drillChart.drill[idx].symbol
    4361098 GEODRD Failed assumption found == TRUE
    4361100 GEODRD Drill drawing heap
    4361102 GEODRD Failed to allocate hash table head pointer
    4361104 GEODRD Failed to default text record
    4361202 GEODRD "drlIdx" out of range (1, DbView.drillChart.drills)
    4361204 GEODRD "symIdx" out of range ('A', LAST_ASC_SYM)
    4361305 GEODRD Failed assumption hash >= 0
    4361330 GEODRD Failed to allocate via heap
    4361331 GEODRD Failed to allocate via hash table
    4361337 GEODRD Failed to allocate via table entry
    4361356 GEODRD Failed to allocate drill symbol segment
    4362001 GEOTHERM Failed to allocate heapThermal
    4362010 GEOTHERM Failed to allocate padTable in GeoThermInit
    4362029 GEOTHERM Expected --infiniteLoopTest > 0
    4362157 GEOTHERM Failed assumption comp > 0
    4362158 GEOTHERM Failed assumption pin > 0
    4362228 GEOTHERM Failed assumption hash < HASH_LIMIT
    4362229 GEOTHERM Failed to allocate padTable entry
    4363440 GEOTRACE Failed to allocate new poly record
    4363440 GEOSS Failed to allocate new poly record
    4363441 GEOTRACE Failed to allocate new seg record
    4363441 GEOSS Failed to allocate new seg record
    4364031 GEOTRACE Failed assumption connPtr->crn[crn].viaIndex != 0
    4364040 GEOTRACE Failed assumption holeHead != NULL
    4364041 GEOTRACE Failed assumption holeHead->next == NULL
    4364051 GEOTRACE Failed assumption segPtr->x1 == prevPtr->x2
    4364052 GEOTRACE Failed assumption segPtr->y1 == prevPtr->y2
    4364442 GEOTRACE Failed to allocate new poly record
    4364443 GEOTRACE Failed to allocate new seg record
    5200016 DBINIT Failed assumption theDb->header.valid
    5200020 DBINIT Failed assumption theDb->header.levMax == ptr->levMax
    5200021 DBINIT Failed assumption theDb != NULL
    5200022 DBINIT Failed assumption theDb->header.viaMax == ptr->viaMax
    5200022 DBINIT Failed assumption !theDb->header.valid
    5200024 DBINIT Failed assumption ptr->batchIndex <= SF_BATCH_LIMIT
    5200024 CONTAIN Failed assumption theDb != NULL
    5200025 DBINIT Failed assumption ptr->viaGrid >= 0
    5200027 DBINIT Failed assumption ptr->userDiv > 0
    5200071 DBINIT Can't allocate DbSort left stack
    5200073 DBINIT Can't allocate DbSort right stack
    5200083 DBINIT Can't allocate DbSort auxilliary table
    5200084 DBINIT Bad displayUnits
    5200086 DBINIT Failed assumption oneUnit > 0.0
    5200087 DBINIT Failed assumption oneUnit > 0.0
    5200088 DBINIT Failed assumption oneUnit > 0.0
    5200107 DBINIT Failed assumption theDb
    5200110 DBINIT Failed assumption theDb
    5200112 DBINIT Failed assumption theDb
    5200127 DBINIT Failed assumption theDb
    5200303 CONTAIN Failed assumption theDb
    5200304 CONTAIN Failed assumption theDb
    5200305 CONTAIN Failed assumption theDb
    5200505 DBINIT Failed assumption hashHeap == 0
    5211005 DBTIMING Failed to allocate event in TimingEvent
    5211012 DBTIMING stackDepth is >= STACK_LIMIT in TimingStart
    5211015 DBTIMING "idLimit" out of range (0, TIMING_LIMIT-1)
    5211020 DBTIMING Attempt to leave module that we didn't enter!
    5211024 DBTIMING stackDepth-- < 0
    5211025 DBTIMING Failed to allocate name[currentId] in TimingStart
    5211080 DBTIMING Failed assumption eTime >= sTime
    5211091 DBTIMING stackDepth != 0 in TimingReport
    5214010 DBOUT Failed assumption outFile
    5214012 DBOUT Failed assumption outFile
    5214013 DBOUT Failed assumption outFile
    5214014 DBOUT Failed assumption outFile
    5214015 DBOUT Failed assumption outFile
    5214017 DBOUT Failed assumption outFile
    5214020 DBOUT default currentMode in OutStr
    5214030 DBOUT default currentMode in OutReset
    5220029 DBUNION Bad UNION kind in UnionCreate
    5220039 DBUNION Bad UNION kind in UnionDelete
    5220049 DBUNION Bad UNION kind in UnionGet
    5220059 DBUNION Bad UNION kind in UnionPut
    5220079 DBUNION Bad UNION kind in unionOut
    5220101 DBUNION Failed assumption kind != NODE_KIND
    5220102 DBUNION Failed assumption kind != NODE_KIND
    5220103 DBUNION Failed assumption kind != NODE_KIND
    5220104 DBUNION Failed assumption kind != NODE_KIND
    5220201 DBUNION Failed assumption theDb
    5220204 DBUNION Failed assumption theDb
    5220445 DBUNION Lev renumbering not supported
    5220493 DBUNION Lev renumbering not supported
    5220533 DBUNION Bad UNION kind in UnionGet
    5220534 DBUNION Bad UNION kind in UnionRangeCheck
    5221010 DBNAME Too many names defined or names too long
    5221012 DBNAME No RAM for names
    5221022 DBNAME No RAM for master name table
    5221045 DBNAME Failed assumption len <= LSTR_LIMIT
    5221052 DBNAME "heapNumber" out of range (0, theDb->name.maxHeapNumber)
    5221054 DBNAME Failed assumption lstrLen (namePtr) <= NAME_STR_LIMIT
    5221055 DBNAME Failed assumption hashValue < NAME_HASH_LIMIT
    5221056 DBNAME Failed assumption hashValue < NAME_HASH_LIMIT
    5221058 DBNAME Failed assumption maxLen <= LSTR_LIMIT
    5221078 DBNAME Failed assumption maxLen <= LSTR_LIMIT
    5221301 DBNAME Failed assumption theDb
    5221302 DBNAME Failed assumption theDb
    5221303 DBNAME Failed assumption theDb
    5221304 DBNAME Failed assumption theDb
    5221305 DBNAME Failed assumption theDb
    5221306 DBNAME Failed assumption theDb
    5221307 DBNAME Failed assumption theDb
    5221308 DBNAME Failed assumption theDb
    5221309 DBNAME Failed assumption theDb
    5222201 DBUNITS Failed assumption theDb
    5223011 DBATTR No RAM for attribute hash table
    5223012 DBATTR No RAM for attribute
    5223105 DBATTR Failed assumption theDb
    5223205 DBATTR Failed assumption theDb
    5223212 DBATTR Failed assumption theDb
    5223221 DBATTR Failed assumption theDb
    5223231 DBATTR Failed assumption theDb
    5223236 DBATTR Failed assumption theDb
    5223444 DBATTR Failed assumption found == TRUE
    5224044 DBPS "ptr->iterations[pass]" out of range (0, 100)
    5224046 DBPS "ptr->attempts[pass]" out of range (0, 100)
    5224048 DBPS Failed assumption ptr->clustNumber[pass] >= 0
    5224201 DBPS Failed assumption theDb
    5224204 DBPS Failed assumption theDb
    5224205 DBPS Failed assumption theDb
    5224206 DBPS Failed assumption theDb
    5225012 DBTHRU "theDb->header.viaMax" out of range (1, THRU_VIA_LIMIT)
    5225015 DBTHRU "theDb->header.thruMax" out of range (theDb->header.viaMax, THRU_LIMIT)
    5225017 DBTHRU Failed to allocate theDb->thru.thruTable in ThruInit
    5225018 DBTHRU Failed to assign default names to vias in ThruInit
    5225029 DBTHRU Too many Padstacks
    5225032 DBTHRU Failed to allocate theDb->thru.thruTable in ThruCreate
    5225034 DBTHRU Failed to create padstack id in ThruCreate
    5225039 DBTHRU Failed assumption theDb->thru.thruTable[index]
    5225040 DBTHRU Failed assumption levPtr->radius[0] == levPtr->radius[1]
    5225041 DBTHRU Failed assumption levPtr->radius[0] == levPtr->radius[2]
    5225042 DBTHRU Failed assumption levPtr->radius[0] == levPtr->radius[3]
    5225044 DBTHRU Failed assumption levPtr->radius[0] >= 0
    5225045 DBTHRU Failed assumption levPtr->radius[1] >= 0
    5225046 DBTHRU Failed assumption levPtr->radius[2] >= 0
    5225047 DBTHRU "deletedIndex" out of range (theDb->header.viaMax+1, theDb->header.thruMax)
    5225049 DBTHRU Invalid pad shape - levPtr->shape
    5225051 DBTHRU Failed assumption levPtr->radius[3] >= 0
    5225054 DBTHRU Failed assumption theDb->thru.thruTable[index]
    5225055 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225056 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225057 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225057 DBTHRU Failed assumption theDb->thru.thruTable[index]
    5225060 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225070 DBTHRU "level" out of range (0, theDb->header.levMax)
    5225072 DBTHRU "level" out of range (1, theDb->header.levMax)
    5225076 DBTHRU Failed assumption !(levPtr->flags & ALT_THRULEV_SELECTED)
    5225080 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225111 DBTHRU Wrong index in ThruDelete
    5225147 DBTHRU Failed assumption theDb->thru.thruTable
    5225148 DBTHRU Allocating renumbering table
    5225149 DBTHRU Allocating renumbering table
    5225201 DBTHRU Failed assumption theDb
    5225204 DBTHRU Failed assumption theDb
    5225207 DBTHRU Failed assumption theDb
    5225211 DBTHRU Failed assumption theDb
    5225214 DBTHRU Failed assumption theDb
    5225221 DBTHRU Failed assumption theDb
    5225227 DBTHRU Failed assumption theDb
    5225231 DBTHRU Failed assumption theDb
    5225234 DBTHRU Failed assumption theDb
    5225237 DBTHRU Failed assumption theDb
    5225241 DBTHRU Failed assumption theDb
    5225244 DBTHRU Failed assumption theDb
    5225247 DBTHRU Failed assumption theDb
    5225276 DBTHRU Failed assumption theDb
    5225277 DBTHRU "thruId" out of range (1, theDb->header.thruMax)
    5225279 DBTHRU Failed assumption theDb
    5225301 DBTHRU Failed assumption theDb
    5225302 DBTHRU Failed assumption theDb
    5225345 DBTHRU Rectangular via
    5225346 DBTHRU Illegal via
    5225471 DBTHRU "layer" out of range (1, LEV_ETCH_LIMIT)
    5225477 DBTHRU Failed assumption theDb
    5225479 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225657 DBTHRU Failed assumption theDb->thru.thruTable[index]
    5225658 DBTHRU Failed assumption theDb->thru.thruTable[index]
    5225670 DBTHRU "level" out of range (0, theDb->header.levMax)
    5225680 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225681 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225682 DBTHRU "level" out of range (0, theDb->header.levMax)
    5225683 DBTHRU "index" out of range (1, theDb->header.thruMax)
    5225684 DBTHRU "level" out of range (0, theDb->header.levMax)
    5226010 DBSYM Failed to allocate theDb->sym.symTable in SymInit
    5226012 DBSYM Failed to allocate theDb->sym.symTable in SymCreate!!!!
    5226015 DBSYM Too many Symbols during SymCreate
    5226020 DBSYM "index" out of range (1, theDb->header.symMax)
    5226021 DBSYM "index" out of range (1, theDb->header.symMax)
    5226022 DBSYM Failed assumption theDb->sym.symTable
    5226023 DBSYM "index" out of range (1, theDb->header.symMax)
    5226024 DBSYM "index" out of range (1, theDb->header.symMax)
    5226026 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226026 DBSYM "index" out of range (1, theDb->header.symMax)
    5226028 DBSYM "index" out of range (1, theDb->header.symMax)
    5226033 DBSYM Failed assumption theDb->sym.symTable
    5226034 DBSYM Failed assumption theDb->sym.symTable
    5226035 DBSYM Failed assumption theDb->sym.symTable
    5226036 DBSYM Failed assumption theDb->sym.symTable
    5226037 DBSYM Failed assumption theDb->sym.symTable
    5226037 DBSYM Failed assumption ptr
    5226038 DBSYM Failed assumption theDb->sym.symTable
    5226038 DBSYM "pinIndex" out of range (1, symHeader->pads)
    5226038 DBSYM "pin" out of range (1, symHeader->pads)
    5226040 DBSYM Failed assumption theDb->sym.symTable
    5226040 DBSYM "index" out of range (1, theDb->header.symMax)
    5226046 DBSYM "deletedIndex" out of range (1, theDb->header.symMax)
    5226047 DBSYM Failed assumption theDb->sym.symTable
    5226048 DBSYM Allocating renumbering table
    5226049 DBSYM Allocating renumbering table
    5226051 DBSYM "headerPtr->pads" out of range (0, SYM_PAD_LIMIT)
    5226052 DBSYM "viewPtr->header.pads" out of range (0, SYM_PAD_LIMIT)
    5226053 DBSYM "viewPtr->pad[pin].thru" out of range (1, theDb->header.thruMax)
    5226054 DBSYM Failed assumption viewPtr->pad[pin].nameId != 0
    5226055 DBSYM Failed assumption !(viewPtr->pad[pin].flags & ALT_SYMPAD_SELECTED)
    5226064 DBSYM Failed assumption theDb->sym.symTable
    5226065 DBSYM Failed assumption headerPtr->pads == theDb->sym.symTable[index].header.pads
    5226070 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226071 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226072 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226074 DBSYM "pinNum" out of range (1, theDb->sym.symTable[symIndex].header.pads)
    5226075 DBSYM "pinNum" out of range (1, theDb->sym.symTable[symIndex].header.pads)
    5226083 DBSYM Couldn't allocate new memory for pins
    5226091 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226093 DBSYM Failed assumption theDb->sym.symTable
    5226094 DBSYM "pinNum" out of range (1, theDb->sym.symTable[symIndex].header.pads)
    5226095 DBSYM "ptr->thru" out of range (1, theDb->header.thruMax)
    5226171 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226201 DBSYM Failed assumption theDb
    5226204 DBSYM Failed assumption theDb
    5226211 DBSYM Failed assumption theDb
    5226221 DBSYM Failed assumption theDb
    5226224 DBSYM Failed assumption theDb
    5226231 DBSYM Failed assumption theDb
    5226241 DBSYM Failed assumption theDb
    5226244 DBSYM Failed assumption theDb
    5226251 DBSYM Failed assumption theDb
    5226254 DBSYM Failed assumption theDb
    5226257 DBSYM Failed assumption theDb
    5226261 DBSYM Failed assumption theDb
    5226271 DBSYM Failed assumption theDb
    5226274 DBSYM Failed assumption theDb
    5226277 DBSYM Failed assumption theDb
    5226281 DBSYM Failed assumption theDb
    5226301 DBSYM Failed assumption theDb
    5226386 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226387 DBSYM Failed assumption theDb->sym.symTable
    5226554 DBSYM Failed assumption theDb
    5226571 DBSYM "symIndex" out of range (1, theDb->header.symMax)
    5226574 DBSYM "pinNum" out of range (1, symPtr->header.pads)
    5226724 DBSYM "index" out of range (1, theDb->header.symMax)
    5226736 DBSYM Failed assumption theDb->sym.symTable
    5226751 DBSYM Failed assumption theDb
    5227010 DBPACK Failed to allocate theDb->pack.packTable in PackInit
    5227012 DBPACK Failed to allocate theDb->pack.packTable in PackCreate
    5227015 DBPACK Too many Packages during PackCreate
    5227020 DBPACK "index" out of range (1, theDb->header.packMax)
    5227021 DBPACK "index" out of range (1, theDb->header.packMax)
    5227022 DBPACK Failed assumption theDb->pack.packTable
    5227023 DBPACK "index" out of range (1, theDb->header.packMax)
    5227024 DBPACK "index" out of range (1, theDb->header.packMax)
    5227028 DBPACK "packId" out of range (1, theDb->header.packMax)
    5227036 DBPACK Failed assumption theDb->pack.packTable
    5227047 DBPACK "id" out of range (1, theDb->header.packMax)
    5227048 DBPACK PackDelete is not implemented
    5227052 DBPACK "viewPtr->header.pads" out of range (0, SYM_PAD_LIMIT)
    5227054 DBPACK Failed assumption viewPtr->pad[pin].padId != 0
    5227055 DBPACK Failed assumption !(viewPtr->pad[pin].flags & ALT_PACKPAD_SELECTED)
    5227058 DBPACK Can't allocate storage for package's pins
    5227061 DBPACK "index" out of range (1, theDb->header.packMax)
    5227062 DBPACK "headerPtr->pads" out of range (0, SYM_PAD_LIMIT)
    5227063 DBPACK Failed assumption headerPtr->pads == theDb->pack.packTable[index].header.pads
    5227071 DBPACK "packId" out of range (1, theDb->header.packMax)
    5227072 DBPACK "pinNum" out of range (1, theDb->pack.packTable[packId].header.pads)
    5227081 DBPACK Comment needed: dbpack.c, line 509
    5227082 DBPACK Comment needed: dbpack.c, line 511
    5227088 DBPACK "compId" out of range (1, theDb->header.compMax)
    5227201 DBPACK Failed assumption theDb
    5227204 DBPACK Failed assumption theDb
    5227211 DBPACK Failed assumption theDb
    5227221 DBPACK Failed assumption theDb
    5227224 DBPACK Failed assumption theDb
    5227227 DBPACK Failed assumption theDb
    5227231 DBPACK Failed assumption theDb
    5227241 DBPACK Failed assumption theDb
    5227244 DBPACK Failed assumption theDb
    5227251 DBPACK Failed assumption theDb
    5227254 DBPACK Failed assumption theDb
    5227257 DBPACK Failed assumption theDb
    5227261 DBPACK Failed assumption theDb
    5227331 DBPACK Failed assumption theDb
    5228017 DBMIRROR "id" out of range (1, theDb->header.symMax)
    5228052 DBMIRROR "id" out of range (1, theDb->header.thruMax)
    5228058 DBMIRROR "thruId" out of range (1, theDb->header.thruMax)
    5230028 DBCOMP2 "compPtr->symIndex" out of range (1, theDb->header.symMax)
    5230030 DBCOMP2 Cannot allocate a heap
    5230031 DBCOMP2 Cannot allocate temporary table to compute cluster areas
    5230032 DBCOMP2 Cannot allocate oldRadius table
    5230033 DBCOMP2 Cannot allocate temporary table to save best master comp
    5230034 DBCOMP2 Cannot allocate temporary table to save best scores
    5230040 DBCOMP2 "compId" out of range (0, theDb->header.compMax)
    5230042 DBCOMP2 "lev" out of range (0, theDb->header.levMax)
    5230044 DBCOMP2 Cannot allocate a heap
    5230045 DBCOMP2 Cannot allocate temporary table
    5230054 DBCOMP2 "compIndex" out of range (1, theDb->header.compMax)
    5230057 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230058 DBCOMP2 "compView.cluster" out of range (0, theDb->header.compMax)
    5230073 DBCOMP2 Failed assumption newArea[compId] > 0.0
    5230077 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230078 DBFRVIA "connId" out of range (1, theDb->header.connMax + 1)
    5230079 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230097 DBCOMP2 Undefined shape in CompPadRot
    5230098 DBCOMP2 Bad shape in CompPadRot
    5230111 DBFRVIA2 "connIndex" out of range (1, theDb->header.connMax)
    5230111 DBFRVIA2 "inConnPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5230112 DBFRVIA2 "viaCount" out of range (0, inConnPtr->crns)
    5230112 DBFRVIA2 "viaCount" out of range (1, inConnPtr->crns)
    5230113 DBFRVIA2 "in1ConnPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5230114 DBFRVIA2 "in2ConnPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5230115 DBFRVIA2 "netIndex" out of range (1, theDb->header.netMax)
    5230115 DBFRVIA2 Failed assumption in1ConnPtr->comp[1] == frViaIndex
    5230116 MZFRVIA "netIndex" out of range (1, DbView.netMax)
    5230116 DBFRVIA2 "netIndex" out of range (1, theDb->header.netMax)
    5230116 DBFRVIA2 Failed assumption in2ConnPtr->comp[0] == frViaIndex
    5230117 DBFRVIA2 Failed assumption frViaPtr->flags2 & COMP_FREE_AND_TP
    5230117 DBFRVIA2 "connViaIndex" out of range (1, theDb->header.viaMax)
    5230118 DBFRVIA2 "frViaSymIndex" out of range (1, theDb->header.symMax)
    5230120 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230120 DBFRVIA "viaIndex" out of range (1, theDb->header.viaMax)
    5230126 DBFRVIA2 "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230130 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230131 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230132 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230133 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230134 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230135 DBFRVIA "symId" out of range (1, theDb->header.symMax)
    5230140 DBFRVIA "frViaPtr->symIndex" out of range (1, theDb->header.symMax)
    5230141 DBFRVIA Failed assumption symPtr->header.flags & SYM_TEST_POINT
    5230142 DBFRVIA Failed assumption frViaPtr->flags2 & COMP_TEST_POINT
    5230143 DBFRVIA Failed assumption frViaPtr->flags2 & COMP_FREE_VIA
    5230144 DBFRVIA Failed assumption symPtr->header.flags & SYM_FREE_VIA
    5230150 DBFRVIA "frViaIndex" out of range (1, theDb->header.frViaMax)
    5230200 DBFRVIA2 Failed assumption in2ConnPtr->pin[0] == 1
    5230200 DBFRVIA2 Failed assumption in1ConnPtr->pin[1] == 1
    5230201 DBCOMP2 Failed assumption theDb
    5230201 DBFRVIA2 Failed assumption in1ConnPtr->crn[in1ConnPtr->crns-1].x == in2ConnPtr->crn[0].x
    5230202 DBFRVIA2 Failed assumption in1ConnPtr->crn[in1ConnPtr->crns-1].y == in2ConnPtr->crn[0].y
    5230203 DBFRVIA2 Failed assumption in1ConnPtr->net == in2ConnPtr->net
    5230205 DBCOMP2 Failed assumption theDb
    5230211 DBCOMP2 Failed assumption theDb
    5230220 DBFRVIA2 Failed assumption conn1Ptr->comp[1] == frViaIndex
    5230221 DBFRVIA2 Failed assumption conn1Ptr->pin[1] == 1
    5230222 DBCOMP2 Failed assumption theDb
    5230222 DBFRVIA2 Failed assumption conn2Ptr->comp[0] == frViaIndex
    5230223 DBFRVIA2 Failed assumption conn2Ptr->pin[0] == 1
    5230230 DBFRVIA2 "in2ConnPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5230230 DBFRVIA2 "in1ConnPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5230231 DBCOMP2 Failed assumption theDb
    5230234 DBCOMP2 Failed assumption theDb
    5230234 DBFRVIA2 Failed assumption nextFrViaIndex > theDb->header.frViaMax
    5230235 DBFRVIA2 Failed assumption nextConnIndex > theDb->header.connMax
    5230237 DBCOMP2 Failed assumption theDb
    5230239 DBFRVIA2 Failed assumption nextConnIndex > theDb->header.connMax
    5230250 DBFRVIA2 Failed assumption conn1Ptr->comp[1] == frViaIndex
    5230251 DBFRVIA2 Failed assumption conn1Ptr->pin[1] == 1
    5230252 DBFRVIA2 Failed assumption conn2Ptr->comp[0] == frViaIndex
    5230253 DBFRVIA2 Failed assumption conn2Ptr->pin[0] == 1
    5230254 DBFRVIA Failed assumption theDb
    5230274 DBFRVIA Failed assumption theDb
    5230277 DBFRVIA Failed assumption theDb
    5230320 DBFRVIA Failed assumption viaListInitialized == YES
    5230320 DBFRVIA2 "frViaSymIndex" out of range (1, theDb->header.symMax)
    5230329 DBFRVIA2 Failed assumption crn2 == out2ConnPtr->crns
    5230329 DBFRVIA2 Failed assumption foundVia == YES
    5230340 DBFRVIA Failed assumption theDb->header.frViaMax == theDb->header.compMax
    5230374 DBFRVIA Failed assumption netTable != NULL
    5230375 DBFRVIA Failed assumption netTableMax == theDb->header.frViaMax
    5230654 DBFRVIA2 "netIndex" out of range (1, theDb->header.netMax)
    5230678 DBFRVIA2 "connIndex" out of range (1, theDb->header.connMax)
    5230876 MZFRVIA Connection endpoint [0] contains deleted free via
    5230877 MZFRVIA Connection endpoint [1] contains deleted free via
    5230948 DBFRVIA "netIndex" out of range (1, theDb->header.netMax)
    5230987 DBCOMP2 Failed assumption currentFP <= theDb->header.symMax
    5232010 DBCOLOR Failed to allocate table in DbColorInit
    5232031 DBCOLOR Too many Color assignments
    5232032 DBCOLOR Failed to reallocate colorTable in DbColorCreate
    5232037 DBCOLOR "index" out of range (1, theDb->header.colorMax)
    5232040 DBCOLOR "index" out of range (1, theDb->color.colorLimit)
    5232042 DBCOLOR "index" out of range (1, theDb->color.colorLimit)
    5232071 DBCOLOR Expected theDb->color.colorTable[index].lev ...
    5232101 DBCOLOR Failed assumption theDb
    5232108 DBCOLOR Failed assumption theDb
    5232115 DBCOLOR Failed assumption theDb
    5232118 DBCOLOR Failed assumption theDb
    5232121 DBCOLOR Failed assumption theDb
    5232123 DBCOLOR Failed assumption theDb
    5232126 DBCOLOR Failed assumption theDb
    5232204 DBCOLOR Failed assumption theDb
    5232214 DBCOLOR Failed assumption theDb
    5233020 DBNET Too many nets
    5233023 DBNET Failed to allocate clusterTable in NetCreate
    5233030 DBNET "netIndex" out of range (1, theDb->header.netMax)
    5233040 DBNET "netIndex" out of range (1, theDb->header.netMax)
    5233047 DBNET "netIndex" out of range (1, theDb->header.netMax)
    5233050 DBNET "netIndex" out of range (1, theDb->header.netMax)
    5233061 DBNET "i" out of range (1, theDb->header.netMax)
    5233062 DBNET "j" out of range (1, theDb->header.netMax)
    5233201 DBNET Failed assumption theDb
    5233203 DBNET Failed assumption theDb
    5233207 DBNET Failed assumption theDb
    5233211 DBNET Failed assumption theDb
    5233213 DBNET Failed assumption theDb
    5233221 DBNET Failed assumption theDb
    5233231 DBNET Failed assumption theDb
    5233241 DBNET Failed assumption theDb
    5233251 DBNET Failed assumption theDb
    5233254 DBNET Failed assumption theDb
    5233261 DBNET Failed assumption theDb
    5233264 DBNET Failed assumption theDb
    5233456 DBNET Failed assumption theDb->header.netMax < NET_LIMIT
    5233463 DBNET Can't allocate renumber table
    5234006 DBSEG Failed to reallocate net table
    5234016 DBSEG Failed to allocate net table
    5234017 DBSEG Failed assumption netTablePtr
    5234019 DBSEG "netId" out of range (1, NET_LIMIT)
    5234020 DBSEG Failed assumption checkNet (netId)
    5234022 DBSEG Failed assumption segPtr);       /* Too few segments active */ ...
    5234023 DBSEG Failed assumption segPtr == (SEG_RECORD MEM_PTR) activeTail->next); /* Too many segments active */ ...
    5234027 DBSEG Failed assumption segCount == segCount2
    5234028 DBSEG Failed assumption nodeCount-1 <= connCount
    5234030 DBSEG Failed to allocate heap for new segment
    5234034 DBSEG Failed to allocate new segment record
    5234035 DBSEG Failed to allocate new segment record
    5234036 DBSEG Failed to allocate new segment record
    5234037 DBSEG Failed to allocate heap for new segment
    5234042 DBSEG Failed assumption (segPtr->kind == SEG_KIND) || (segPtr->kind == VIA_KIND)
    5234049 DBSEG "net" out of range (0, NET_LIMIT)
    5234052 DBSEG Failed to allocate heap for new segment
    5234057 DBSEG Failed assumption netTablePtr
    5234062 DBSEG Failed to allocate heap for new segment
    5234069 DBSEGALT Failed assumption seg1Head->kind == PAD_KIND
    5234069 DBSEG Failed assumption seg1Head->kind == PAD_KIND
    5234071 DBSEG Failed to allocate heap for new segment
    5234073 DBSEG Failed to allocate segment record
    5234074 DBSEG Failed to allocate new segment record
    5234075 DBSEG Failed to allocate new segment record
    5234076 DBSEG Failed to allocate new segment record
    5234077 DBSEG Failed assumption netTablePtr
    5234080 DBSEG Failed to allocate new segment record
    5234086 DBSEG "netId" out of range (1, theDb->header.netMax)
    5234087 DBSEG Failed assumption netTablePtr
    5234201 DBSEG Failed assumption theDb
    5234204 DBSEG Failed assumption theDb
    5234231 DBSEG Failed assumption theDb
    5234261 DBSEG Failed assumption theDb
    5235001 DBSEGALG Failed to allocate segment record
    5235002 DBSEGALG Failed to allocate hash table
    5235003 DBSEGALG Failed to allocate segment record
    5235004 DBSEGALG Failed to allocate chain
    5235005 DBSEGALG Failed to allocate chain length table
    5235012 DBSEGALG Failed to allocate new hash record
    5235024 DBSEGALG "chain" out of range (0, CHAIN_LIMIT)
    5235025 DBSEGALG "chain" out of range (0, CHAIN_LIMIT)
    5235026 DBSEGALG "chain" out of range (0, CHAIN_LIMIT)
    5235042 DBSEGALG Failed to allocate segment record
    5235043 DBSEGALG Failed to allocate segment record
    5235072 DBSEGALG Failed to allocate segment record
    5235073 DBSEGALG Failed to allocate segment record
    5235077 DBSEGALG Failed to allocate new edge
    5235201 DBSEGALG Failed assumption theDb
    5236001 DBHASH Conn Heap
    5236002 DBHASH Failed to allocate hash table
    5236011 DBHASH Failed assumption hashTablePtr
    5236012 DBHASH Failed to allocate hash record
    5236038 DBHASH bad via shape found during buildChains
    5236053 DBHASH Failed to allocate new segment record
    5236083 DBHASH Failed assumption netTablePtr
    5236092 DBHASH Failed to allocate new segment record
    5237001 DBSEGECL Failed to allocate segment record
    5237003 DBSEGECL Failed to allocate segment record
    5237012 DBSEGECL Failed assumption outPtr->kind == PAD_KIND
    5237013 DBSEGECL Failed assumption outPtr->kind == PAD_KIND
    5237014 DBSEGECL Failed assumption segPtr1->kind == PAD_KIND
    5237015 DBSEGECL Failed assumption segPtr2->kind == PAD_KIND
    5237022 DBSEGECL Failed assumption netView.reconRule & NET_RECONN_ECL
    5237042 DBSEGECL Failed to allocate segment record
    5237043 DBSEGECL Failed to allocate segment record
    5237072 DBSEGECL Failed to allocate segment record
    5237073 DBSEGECL Failed to allocate segment record
    5238001 URSMTNET net Heap
    5238001 DBNET2 net Heap
    5238007 URSMTNET Failed to allocate pin table
    5238007 DBNET2 Failed to allocate pin table
    5238008 URSMTNET Failed to allocate visit table
    5238008 DBNET2 Failed to allocate visit table
    5238012 URSMTNET Failed to allocate adjList
    5238012 DBNET2 Failed to allocate adjList
    5238013 URSMTNET Failed to allocate adjList
    5238013 DBNET2 Failed to allocate adjList
    5238017 URSMTNET Failed to allocate Adjacency List Table
    5238017 DBNET2 Failed to allocate Adjacency List Table
    5238030 DBNET2 "netIndex" out of range (1, theDb->header.netMax)
    5238058 URSMTNET Failed assumption comp > 0
    5238058 DBNET2 Failed assumption comp > 0
    5238068 URSMTNET Failed assumption pinId1 > 0
    5238068 DBNET2 Failed assumption pinId1 > 0
    5238069 URSMTNET Failed assumption pinId2 > 0
    5238069 DBNET2 Failed assumption pinId2 > 0
    5238101 URSMTNET net Heap
    5238101 DBNET2 net Heap
    5238107 URSMTNET Failed to allocate pin SMT table
    5238107 DBNET2 Failed to allocate pin SMT table
    5238113 DBNET2 Failed assumption AttrNext (&attr)
    5238116 DBNET2 Failed assumption lev
    5238140 DBNET2 "netIndex" out of range (1, theDb->header.netMax)
    5238142 DBNET2 "comp" out of range (1, theDb->header.compMax)
    5238158 URSMTNET Failed assumption comp > 0
    5238158 DBNET2 Failed assumption comp > 0
    5238201 DBNET2 Failed assumption theDb
    5238204 DBNET2 Failed assumption theDb
    5238224 URSMTNET Failed assumption pinLimit < PIN_TABLE_LIMIT
    5238224 DBNET2 Failed assumption pinLimit < PIN_TABLE_LIMIT
    5238242 URSMTNET "pin" out of range (0, pinLimit)
    5238242 DBNET2 "pin" out of range (0, pinLimit)
    5238922 DBNODE2 Failed assumption theDb->node.nodeGlobals.Work->pin[0] != theDb->node.nodeGlobals.Work->pin[1]
    5239010 DBCONN Failed to allocate connTable1 in ConnInit
    5239010 DBNODE Failed to allocate connTable1 in ConnInit
    5239011 DBCONN Failed to allocate connTable2 in ConnInit
    5239012 DBCONN Failed to allocate connTable1 in ConnInit
    5239013 DBCONN Failed to allocate connTable2 in ConnInit
    5239014 DBCONN Failed to allocate freeList in ConnInit
    5239021 DBCONN "connPtr->crns" out of range (2, CONN_CRN_LIMIT)
    5239023 DBCONN "lev" out of range (0, theDb->header.levMax)
    5239025 DBCONN "viaIndex" out of range (0, theDb->header.viaMax)
    5239027 DBCONN Bad flag during in validateCrns
    5239030 DBCONN Failed assumption theDb->header.connMax < CONN_LIMIT
    5239032 DBCONN Failed to reallocate connTable in ConnCreate
    5239032 DBNODE Failed to reallocate nodeTable in NodeCreate
    5239033 DBCONN Failed to reallocate connTable1 in ConnCreate
    5239034 DBNODE Failed assumption listPtr->count == 0
    5239035 DBCONN Bad arc during in validateArcs
    5239051 DBCONN "connPtr->net" out of range (1, theDb->header.netMax)
    5239057 DBCONN "compId" out of range (0, theDb->header.compMax)
    5239063 DBCONN "netIndex" out of range (1, theDb->header.netMax)
    5239064 DBCONN "netIndex" out of range (1, theDb->header.netMax)
    5239065 DBCONN Failed to allocate netHeadTable in linkNet
    5239066 DBCONN Failed to reallocate netHeadTable in linkNet
    5239070 DBCONN "netIndex" out of range (1, theDb->conn.netLimit)
    5239072 DBCONN Failed assumption current > 0
    5239076 DBCONN "connIndex" out of range (1, theDb->header.connMax)
    5239078 DBCONN "connId" out of range (1, theDb->header.connMax+1)
    5239079 DBCONN "connIndex" out of range (1, theDb->header.connMax+1)
    5239080 DBCONN "index" out of range (1, theDb->header.connMax)
    5239081 DBCONN Failed to allocate new space in ConnStore
    5239082 DBCONN "index" out of range (1, theDb->header.connMax)
    5239082 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239083 DBCONN "index" out of range (1, theDb->header.connMax)
    5239084 DBCONN "index" out of range (1, theDb->header.connMax)
    5239085 DBCONN "index" out of range (1, theDb->header.connMax)
    5239086 DBCONN "index" out of range (1, theDb->header.connMax)
    5239091 DBCONN "oldPtr->crns" out of range (0, CONN_CRN_LIMIT)
    5239095 DBCONN Expected netView.stdWidth > 0
    5239201 DBCONN Failed assumption theDb
    5239201 DBNODE Failed assumption theDb
    5239211 DBCONN Failed assumption theDb
    5239211 DBNODE Failed assumption theDb
    5239221 DBCONN Failed assumption theDb
    5239221 DBNODE Failed assumption theDb
    5239222 DBCONN Failed assumption theDb
    5239222 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239223 DBCONN Failed assumption theDb->header.connMax >= listPtr->count
    5239223 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239224 DBNODE "nodeId" out of range (1, listPtr->count)
    5239224 DBNODE "nodeId" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239234 DBCONN Failed assumption theDb
    5239234 DBNODE Failed assumption theDb
    5239235 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239236 DBNODE "nodeId" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239236 DBNODE "nodeId" out of range (1, listPtr->count)
    5239237 DBCONN Failed assumption theDb
    5239241 DBCONN Failed assumption theDb
    5239243 DBNODE Failed assumption theDb
    5239244 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239245 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239246 DBCONN Failed assumption theDb
    5239246 DBNODE "nodeId" out of range (1, listPtr->count)
    5239247 DBNODE "view->startLev" out of range (1, theDb->header.levMax)
    5239248 DBNODE "view->endLev" out of range (1, theDb->header.levMax)
    5239251 DBCONN Failed assumption theDb
    5239251 DBNODE Failed assumption theDb
    5239252 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239254 DBNODE "startLev" out of range (1, theDb->header.levMax)
    5239255 DBCONN Failed assumption theDb
    5239255 DBNODE "endLev" out of range (1, theDb->header.levMax)
    5239261 DBCONN Failed assumption theDb
    5239264 DBCONN Failed assumption theDb
    5239271 DBCONN Failed assumption theDb
    5239274 DBCONN Failed assumption theDb
    5239277 DBCONN Failed assumption theDb
    5239281 DBCONN Failed assumption theDb
    5239284 DBCONN Failed assumption theDb
    5239294 DBCONN Failed assumption theDb
    5239295 DBCONN "connId" out of range (1, theDb->header.connMax)
    5239301 DBCONN Failed assumption theDb
    5239301 DBNODE Failed assumption theDb
    5239303 DBCONN Failed assumption theDb
    5239321 DBNODE Failed assumption theDb
    5239322 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239323 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239324 DBNODE "nodeId" out of range (1, listPtr->count)
    5239324 DBNODE "nodeId" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239331 DBNODE Failed assumption theDb
    5239332 DBNODE Failed assumption theDb->node.searchLink != NULL
    5239337 DBCONN Failed assumption theDb
    5239341 DBNODE Failed assumption theDb
    5239342 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239343 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239344 DBNODE "nodeId" out of range (1, listPtr->count)
    5239344 DBNODE "nodeId" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239345 DBCONN "theDb->conn.connTable1[connIndex]->netNext" out of range (0, theDb->header.connMax)
    5239346 DBCONN "theDb->conn.connTable2[connIndex-16000]->netNext" out of range (0, theDb->header.connMax)
    5239348 DBNODE Failed assumption idx == (freePtr->linkCount - 1)
    5239351 DBNODE Failed assumption theDb
    5239352 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239353 DBNODE Failed assumption theDb->node.tableLimit >= netId
    5239354 DBNODE "nodeId" out of range (1, listPtr->count)
    5239354 DBNODE "nodeId" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239358 DBNODE Failed assumption cnt == freePtr->linkCount
    5239361 DBNODE Failed assumption theDb
    5239362 DBNODE Failed assumption netId != WORKING_NET
    5239400 DBNODE Failed to allocate nodeTable in NodeRenumber
    5239431 DBNODE Failed assumption theDb
    5239432 DBNODE "netId" out of range (1, theDb->header.netMax)
    5239463 DBCONN Can't allocate renumber table
    5239470 DBNODE2 Failed assumption nextNew <= theDb->node.nodeGlobals.NewMax
    5239471 DBNODE2 Failed assumption newPtr != NULL
    5239472 DBNODE2 Failed assumption nodeRec->comp
    5239473 DBNODE2 Failed assumption nodeRec->comp
    5239564 DBCONN "netIndex" out of range (1, theDb->header.netMax)
    5239603 DBCONN Failed assumption theDb->conn.netHeadTable
    5239604 DBNODE2 Failed assumption nodeId != 0
    5239608 DBNODE2 Failed assumption MakeCommonAtSource (theDb->node.nodeGlobals.Work, tmpPtr2)
    5239645 DBNODE2 Failed assumption tmpPtr != NULL
    5239653 DBNODE2 Failed assumption tmpPtr->pin[0] == connPtr->pin[end]
    5239656 DBNODE2 Failed assumption nodeRec->connLinks
    5239657 DBNODE2 Failed assumption tmpPtr->pin[0] == connPtr->pin[1]
    5239673 DBNODE2 Failed assumption AltGetDepth ()
    5239712 DBNODE2 Failed assumption nodePtr != NULL
    5239713 DBNODE2 Failed assumption nodePtr != NULL
    5239720 DBNODE Failed assumption theDb->node.nodeGlobals.SpanHeap == 0
    5239741 DBSPAN Failed assumption theDb->node.nodeGlobals.NodeAdded[node->id] == child
    5239773 DBNODE2 Failed assumption nodeRec->connLinks == NULL
    5239776 DBNODE2 Failed assumption sLev != 0
    5239776 DBNODE2 Failed assumption connId > 0
    5239777 DBNODE2 Failed assumption eLev != 0
    5239777 DBNODE2 Failed assumption connId2 > 0
    5239778 DBNODE2 Failed assumption thruId != 0
    5239781 DBNODE2 "connPtr->pin[end]" out of range (1, theDb->node.nodeGlobals.WorkingNodeList.count)
    5239785 DBSPAN Failed assumption (chain1 != NULL) && (chain2 != NULL)
    5239795 DBSPAN Failed assumption (tmpPtr->comp[0] == 0) && (tmpPtr->comp[1] == 0)
    5240020 DBCONN2 "crn" out of range (0, connPtr->crns)
    5240022 DBCONN2 "delta" out of range (1, CONN_CRN_LIMIT - connPtr->crns - 1)
    5240025 DBCONN2 "crn" out of range (0, connPtr->crns - 1)
    5240027 DBCONN2 "delta" out of range (0, connPtr->crns - crn)
    5240201 DBCONN2 Failed assumption theDb
    5240221 DBCONN2 Failed assumption theDb
    5240224 DBCONN2 Failed assumption theDb
    5240910 DBCONN2 missing via in ConnReduce2
    5240987 DBCONN2 "crn" out of range (1, workPtr->crns - 2)
    5241032 DBARC Failed assumption segNumber > 0
    5242403 DBLOAD2 Failed assumption SymFind (name) == 1
    5242403 DBLOAD2 Failed assumption theDb
    5242406 DBLOAD2 Failed assumption thruId
    5242406 DBLOAD2 Failed assumption theDb
    5242503 DBLOAD2 Failed assumption theDb
    5242513 DBLOAD2 Failed assumption theDb
    5242964 DBCOPY Expected algorithm == USER_DIV
    5243501 DBLOAD2 Failed assumption size == sizeof (LEV_VIEW)
    5243502 DBLOAD2 Failed assumption size == sizeof (DB_VIEW)
    5243503 DBLOAD2 Failed assumption !dbFound
    5243504 DBLOAD2 Failed assumption ioBuff->db.levMax > 0
    5243505 DBLOAD2 Failed assumption ioBuff->db.levMax <= LEV_ETCH_LIMIT
    5243507 DBLOAD2 Failed assumption ioBuff->db.gridDiv >= 0
    5243508 DBLOAD2 Failed assumption ioBuff->db.viaGrid >= 0
    5243511 DBLOAD2 "size" out of range (0, NAME_STR_LIMIT+1)
    5243512 DBLOAD2 Failed assumption nameCount < NAME_COUNT_LIMIT
    5243521 DBLOAD2 Failed assumption size == sizeof (THRU_VIEW)
    5243522 DBLOAD2 Expected nameCount == 1
    5243524 DBLOAD2 Failed assumption nameCount == ioBuff->sym.header.pads + 1
    5243525 DBLOAD2 "nameCount" out of range (1, 3)
    5243527 DBLOAD2 Expected nameCount == 1
    5243528 DBLOAD2 Expected nameCount == 1
    5243532 DBLOAD2 Failed assumption size == sizeof (DB_VIEW)
    5243533 DBLOAD2 Failed assumption !dbFound
    5243534 DBLOAD2 Failed assumption ioBuff->db.levMax > 0
    5243535 DBLOAD2 Failed assumption ioBuff->db.levMax <= LEV_ETCH_LIMIT
    5243537 DBLOAD2 Failed assumption ioBuff->db.gridDiv >= 0
    5243538 DBLOAD2 Failed assumption ioBuff->db.viaGrid >= 0
    5244000 DBOBS2 Failed assumption netTablePtr
    5244009 DBOBS2 Failed to allocate heap for new segment
    5244028 DBOBS2 Failed to allocate heap for new segment
    5244029 DBOBS2 Failed to allocate heap for new segment
    5245012 DBOBS Failed to allocate theDb->obs.obsTable1 in ObsInit
    5245013 DBOBS Obstacle not found on correct list
    5245014 DBOBS Failed to allocate theDb->obs.symFirst in ObsInit
    5245015 DBOBS Failed to allocate compFirst in ObsInit
    5245020 DBOBS "crn" out of range (0, obsPtr->crns)
    5245022 DBOBS Failed assumption obsPtr->crn[crn+1].flags != 0
    5245024 DBOBS Failed assumption obsPtr->crns < OBS_CRN_LIMIT
    5245030 DBOBS Failed assumption obsPtr->crns == 3
    5245031 DBOBS Failed assumption obsPtr->crn[0].x == obsPtr->crn[2].x
    5245032 DBOBS Failed assumption obsPtr->crn[0].y == obsPtr->crn[2].y
    5245033 DBOBS Expected obsPtr->crn[1].flags != 0
    5245035 DBOBS Expected delta <= ACCURACY
    5245038 DBOBS Failed assumption theDb->obs.obsTable
    5245039 DBOBS Failed assumption theDb->obs.obsTable
    5245043 DBOBS "symId" out of range (0, theDb->header.symMax)
    5245045 DBOBS "compId" out of range (1, theDb->header.compMax)
    5245046 DBOBS "obsId" out of range (1, theDb->header.obsMax)
    5245048 DBOBS Failed to enlarge theDb->obs.obsTable in ObsCreate
    5245050 DBOBS "index" out of range (1, theDb->header.obsMax)
    5245051 DBOBS "index" out of range (1, theDb->header.obsMax)
    5245053 DBOBS "index" out of range (1, theDb->header.obsMax)
    5245061 DBOBS "i" out of range (1, theDb->header.obsMax)
    5245062 DBOBS "j" out of range (1, theDb->header.obsMax)
    5245063 DBOBS "view->crns" out of range (1, OBS_CRN_LIMIT)
    5245064 DBOBS "(short) view->lev" out of range (0, theDb->header.levMax)
    5245065 DBOBS Failed assumption view->width >= 0
    5245066 DBOBS "view->net" out of range (1, theDb->header.netMax)
    5245071 DBOBS "obsPtr->symId" out of range (0, theDb->header.symMax)
    5245072 DBOBS Failed to allocate theDb->obs.symFirst in addToLink
    5245075 DBOBS "-obsPtr->symId" out of range (0, theDb->header.compMax)
    5245076 DBOBS Failed to allocate theDb->obs.compFirst in addToLink
    5245080 DBOBS "index" out of range (1, theDb->obs.obsLimit)
    5245082 DBOBS Failed assumption --count > 0
    5245091 DBOBS Failed to allocate theDb->obs.obsTable in ObsPut for first time
    5245092 DBOBS Failed to allocate theDb->obs.obsTable in ObsPut, previous version exists
    5245121 DBOBS Arc on corner zero
    5245122 DBOBS Arc on corner zero
    5245123 DBOBS Arc on last corner
    5245124 DBOBS Arc on last corner
    5245151 DBOBS "index" out of range (1, theDb->header.obsMax)
    5245201 DBOBS Failed assumption theDb
    5245204 DBOBS Failed assumption theDb
    5245211 DBOBS Failed assumption theDb
    5245221 DBOBS Failed assumption theDb
    5245224 DBOBS Failed assumption theDb
    5245231 DBOBS Failed assumption theDb
    5245241 DBOBS Failed assumption theDb
    5245244 DBOBS Failed assumption theDb
    5245247 DBOBS Failed assumption theDb
    5245251 DBOBS Failed assumption theDb
    5245254 DBOBS Failed assumption theDb
    5245261 DBOBS Failed assumption theDb
    5245271 DBOBS Failed assumption theDb
    5245331 DBOBS Failed assumption theDb
    5245332 DBOBS Failed assumption theDb
    5245333 DBOBS Failed assumption theDb
    5245334 DBOBS Failed assumption theDb
    5245456 DBOBS Failed assumption newUid < theDb->header.lastUID
    5245463 DBOBS Can't allocate renumber table
    5245987 DBOBS Failed assumption theDb->header.obsMax < OBS_LIMIT
    5246010 DBNOTE "length" out of range (0, LSTR_LIMIT)
    5246040 DBNOTE "index" out of range (1, theDb->header.noteMax)
    5246050 DBNOTE NotePut not yet implemented
    5246073 DBNOTE Failed assumption theDb->note.currentNote
    5246081 DBNOTE Cannot allocate new NOTE
    5246201 DBNOTE Failed assumption theDb
    5246204 DBNOTE Failed assumption theDb
    5246211 DBNOTE Failed assumption theDb
    5246252 DBNOTE Failed assumption theDb
    5246253 DBNOTE Failed assumption theDb
    5247010 DBREPORT Failed to allocate table in DbReportInit
    5247037 DBREPORT "index" out of range (1, theDb->header.ppMax)
    5247040 DBREPORT "index" out of range (1, theDb->header.ppMax)
    5247042 DBREPORT "index" out of range (1, theDb->header.ppMax)
    5247045 DBREPORT Failed to allocate reportTable in ReportPut for first time
    5247182 DBREPORT Too many Reports
    5247183 DBREPORT Failed to allocate errTable in DbErrorCreate
    5247201 DBREPORT Failed assumption theDb
    5247211 DBREPORT Failed assumption theDb
    5247214 DBREPORT Failed assumption theDb
    5247223 DBREPORT Failed assumption theDb
    5247301 DBREPORT Failed assumption theDb
    5247302 DBREPORT Failed assumption theDb
    5247463 DBREPORT Can't allocate renumber table
    5248001 DBAPP Failed assumption theDb
    5248010 DBAPP Failed to allocate table in DbAppInit
    5248031 DBAPP Too many Apperture assignments
    5248032 DBAPP Failed to reallocate appTable in DbAppCreate
    5248033 DBAPP Failed assumption theDb
    5248037 DBAPP "index" out of range (1, theDb->header.appMax)
    5248040 DBAPP "index" out of range (1, theDb->app.appLimit)
    5248041 DBAPP Failed assumption theDb
    5248042 DBAPP "index" out of range (1, theDb->header.appMax)
    5248043 DBAPP "ptr->dCode" out of range (10, APP_LIMIT)
    5248044 DBAPP Failed assumption theDb
    5248061 DBAPP "i" out of range (1, theDb->header.appMax)
    5248062 DBAPP "j" out of range (1, theDb->header.appMax)
    5248067 DBAPP Failed assumption theDb
    5248182 DBAPP Failed to allocate table in DbAppCreate
    5248223 DBAPP Failed assumption theDb
    5248224 DBAPP Failed assumption theDb
    5248227 DBAPP Failed assumption theDb
    5248229 DBAPP Failed assumption theDb
    5248463 DBAPP Can't allocate renumber table
    5250031 DBSF "(short) theDb->header.batchIndex" out of range (0, SF_BATCH_LIMIT)
    5250032 DBSF "(short) theDb->header.batchIndex" out of range (0, SF_BATCH_LIMIT)
    5250044 DBSF "(short) ptr->viaCost[pass]" out of range (0, 100)
    5250046 DBSF "(short) ptr->routeLimit[pass]" out of range (0, 100)
    5250048 DBSF "(short) ptr->retryCost[pass]" out of range (0, 100)
    5250052 DBSF "(short) ptr->cellCost[lev]" out of range (0, 100)
    5250054 DBSF "(short) ptr->primaryDirect[lev]" out of range (0, 100)
    5250056 DBSF Failed assumption lstrLen (ptr->title) <= SF_TITLE_MAX
    5250106 DBCONN2 Failed assumption connPtr->crn[connPtr->crns-1].x == symPadView.x
    5250107 DBCONN2 Failed assumption connPtr->crn[connPtr->crns-1].y == symPadView.y
    5250110 DBCONN2 Failed assumption rotation[end]
    5250201 DBSF Failed assumption theDb
    5250211 DBSF Failed assumption theDb
    5255000 DBALT "theDb->alt.depth" out of range (0, DEPTH_LIMIT)
    5255002 DBALT Failed assumption listPtr->magicNumber == MAGIC_NUMBER
    5255004 DBALT Failed assumption shadowPtr->magicNumber == MAGIC_NUMBER
    5255006 DBALT Failed assumption listPtr->alt.id == shadowPtr->alt.id
    5255008 DBALT Failed assumption listPtr->alt.kind == shadowPtr->alt.kind
    5255009 DBALT Failed to allocate free list table in AltPush
    5255009 DBALT Failed assumption listPtr->alt.kind == kind
    5255010 DBALT Failed assumption theDb->alt.altMax == count
    5255011 DBALT Failed assumption theDb->alt.listSize[kind] == kindCount
    5255012 DBALT Failed assumption listPtr->alt.depth == 1
    5255013 DBALT Failed assumption unionPtr != NULL
    5255014 DBALT "size" out of range (0, sizeof (UNION_VIEW))
    5255017 DBALT Failed assumption theDb->alt.depth == 1
    5255018 DBALT Failed assumption theDb->alt.listSize[kind] == 0
    5255019 DBALT Failed assumption theDb->alt.listTail[kind]->next
    5255020 DBALT "size" out of range (0, sizeof (UNION_VIEW))
    5255021 DBALT Failed to allocate new memory in allocMem
    5255022 DBALT Failed assumption theDb->alt.listTail[kind]->next == NULL
    5255023 DBALT Failed assumption theDb->alt.listTail[kind]->magicNumber == MAGIC_NUMBER
    5255024 DBALT Failed assumption listPtr->magicNumber == MAGIC_NUMBER
    5255031 DBALT Failed assumption theDb->alt.lastAltPtr
    5255032 DBALT Failed assumption theDb->alt.lastAltPtr->linearNext
    5255033 DBALT Failed assumption theDb->alt.lastAltPtr
    5255034 DBALT Failed assumption theDb->alt.lastAltPtr->linearNext
    5255034 DBALT Failed assumption theDb->alt.altMax == 0
    5255035 DBALT Failed assumption theDb->alt.lastAltPtr
    5255036 DBALT Failed assumption theDb->alt.lastAltPtr->linearNext
    5255036 DBALT Failed assumption theDb->alt.linearTail->magicNumber == MAGIC_NUMBER
    5255037 DBALT Failed assumption theDb->alt.linearTail->linearNext == NULL
    5255038 DBALT Failed assumption theDb->alt.altMax == count
    5255042 DBALT Failed assumption theDb
    5255043 DBALT Failed assumption listPtr->alt.id == shadowPtr->alt.id
    5255045 DBALT Failed assumption theDb->alt.linearTail->linearNext
    5255048 DBALT Failed assumption theDb->alt.depth > 0
    5255053 DBALT Failed assumption listPtr->alt.kind == kind
    5255054 DBALT Failed assumption listPtr->magicNumber == MAGIC_NUMBER
    5255058 DBALT Expected listPtr->alt.objIndex == objIndex
    5255061 DBALT Deleting duplicates in ALT
    5255062 DBALT Duplicate in ALT
    5255067 DBALT Failed assumption theDb
    5255068 DBALT Expected AltGetDepth () == 0, 0
    5255068 DBALT Failed assumption listPtr->magicNumber == MAGIC_NUMBER
    5255070 DBALT Failed assumption theDb->alt.lastAltPtr
    5255071 DBALT Failed assumption listPtr->alt.kind == altPtr->kind
    5255072 DBALT Failed assumption listPtr->alt.id == altPtr->id
    5255073 DBALT Failed assumption listPtr->alt.altIndex == altPtr->altIndex
    5255074 DBALT Expected listPtr->alt.objIndex == altPtr->objIndex
    5255075 DBALT Failed assumption listPtr->alt.kind == NODE_KIND
    5255076 DBALT Failed to allocate oldRecordPtr in AltStore
    5255093 DBALT Failed assumption theDb->alt.listSize[NODE_KIND] == 0
    5255093 DBALT Failed assumption theDb->alt.listSize[kind] == 0
    5255094 DBALT Failed assumption theDb->alt.altMax == 0
    5255111 DBALT Failed assumption theDb->alt.altMax == count
    5255222 DBALT Failed assumption theDb
    5255241 DBALT Failed assumption theDb
    5255242 DBALT Failed assumption theDb
    5255244 DBALT Failed assumption theDb
    5255246 DBALT Failed assumption theDb
    5255248 DBALT Failed assumption theDb
    5255254 DBALT Failed assumption theDb
    5255255 DBALT Failed assumption kind != NODE_KIND
    5255263 DBALT Failed assumption theDb
    5255266 DBALT Failed assumption theDb
    5255268 DBALT Failed assumption theDb
    5255269 DBALT Failed assumption listPtr->alt.kind == kind
    5255272 DBALT Failed assumption theDb
    5255274 DBALT Failed assumption theDb
    5255275 DBALT Failed assumption listPtr->alt.kind == kind
    5255277 DBALT Failed assumption theDb
    5255282 DBALT Failed assumption theDb
    5255283 DBALT Failed assumption kind != NODE_KIND
    5255284 DBALT Failed assumption theDb
    5255284 DBALT Failed assumption listPtr->alt.kind == kind
    5255285 DBALT Failed assumption theDb
    5255286 DBALT Failed assumption theDb
    5255287 DBALT Failed assumption kind != NODE_KIND
    5255288 DBALT Failed assumption theDb
    5255288 DBALT Failed assumption listPtr->alt.kind == kind
    5255289 DBALT Failed assumption theDb
    5255289 DBALT Failed assumption kind != NODE_KIND
    5255291 DBALT Failed assumption theDb
    5255293 DBALT Failed assumption theDb
    5255297 DBALT Failed assumption theDb
    5255299 DBALT Failed assumption theDb
    5255301 DBALT Failed assumption theDb
    5255349 DBALT Failed assumption listPtr->oldData == NULL);  // Whoops, not always true ...
    5255389 DBALT Failed assumption theDb
    5255456 DBALT Expected theDb->alt.depth == 1, 1
    5255457 DBALT Failed assumption listPtr->magicNumber == MAGIC_NUMBER
    5255458 DBALT Failed assumption listPtr->alt.depth == 1
    5255648 DBALT Failed assumption theDb->alt.depth > 0
    5255654 DBALT Failed assumption theDb
    5255756 DBALT Tried to AltPush while altRevert flag set
    5255757 DBALT Failed assumption theDb->alt.altRevert == NO
    5255757 DBALT Failed assumption theDb->alt.depth == 0
    5259035 DBSHIFT Expected theDb->header.pragma == 0
    5259036 DBSHIFT Expected theDb->header.pragma == 0
    5259085 DBSHIFT Expected (theDb->header.boardXMin >= 0)
    5259086 DBSHIFT Expected (theDb->header.boardYMin >= 0)
    5259201 DBSHIFT Failed assumption theDb
    5259204 DBSHIFT Failed assumption theDb
    5259552 DBSHIFT Failed assumption theDb->header.valid
    5261018 DBDISTP Wrong shape in DistPntPad
    5261048 DBDISTP Wrong shape in DistSegPad
    5261049 DBDISTP Wrong shape in DistSegPad
    5261050 DBDISTP "compId" out of range (1, theDb->header.compMax)
    5261051 DBDISTP "compId" out of range (1, theDb->header.compMax)
    5261052 DBDISTP "compId" out of range (1, theDb->header.compMax)
    5261098 DBDISTP Wrong shape in DistPntPad
    5261201 DBDISTP Failed assumption theDb
    5261211 DBDISTP Failed assumption theDb
    5261231 DBDISTP Failed assumption theDb
    5261248 DBDISTP Wrong shape in DistRectPad
    5261249 DBDISTP Wrong shape in DistRectPad
    5262071 DBINTSEC IntSegDiag with non-diag
    5263014 DBDISTA Failed assumption order == 1
    5263015 DBDISTA Failed assumption order == 1
    5263016 DBDISTA Failed assumption intersectAngle2 == YES
    5263017 DBDISTA Failed assumption order == 1
    5263024 DBDISTA Failed assumption theDb->header.gridDiv > 0
    5263201 DBDISTA Failed assumption theDb
    5263211 DBDISTA Failed assumption theDb
    5264190 DBARC2 Failed assumption crn >= 0
    5264192 DBARC2 Failed assumption crn >= 0
    5265019 DBSEGALT "netId" out of range (1, NET_LIMIT)
    5265020 DBSEGALT Failed assumption checkNet (netId, altMax)
    5265022 DBSEGALT Failed assumption segPtr);       /* Too few segments active */ ...
    5265023 DBSEGALT Failed assumption segPtr == (SEG_RECORD MEM_PTR) activeTail->next); /* Too many segments active */ ...
    5265027 DBSEGALT Failed assumption segCount == segCount2
    5265028 DBSEGALT Expected (nodeCount - 1) <= connCount
    5265034 DBSEGALT Failed to allocate new segment record
    5265035 DBSEGALT Failed to allocate new segment record
    5265036 DBSEGALT Failed to allocate new segment record
    5265069 DBSEGALT Failed assumption linkPtr->kind == VIA_KIND
    5265073 DBSEGALT Failed to allocate segment record
    5265101 DBSEGALT Failed assumption (altView.flags & ALT_DELETE) == NO
    5265201 DBSEGALT Failed assumption theDb
    5265531 DBSEGALT altNet Heap
    5265534 DBSEGALT Failed to allocate altNetTable
    5265590 DBSEGALT Failed assumption altView.kind == CONN_KIND
    5265591 DBSEGALT Failed assumption ! (altView.flags & ALT_DELETE)
    5265592 DBSEGALT Failed assumption work->conn.net == netId
    5265596 DBSEGALT Failed assumption ! (altView.flags & ALT_DELETE)
    5265597 DBSEGALT Failed assumption (altView.flags & ALT_ADD)
    5265598 DBSEGALT Failed assumption work->conn.net == netId
    5265999 DBSEGALT Failed assumption newConnId > altView.id
    5266201 DBTEAR Failed assumption theDb
    5267011 DBPINMAP No RAM for pinmap hash table
    5267012 DBPINMAP No RAM for pinmap
    5267012 ECOMAIN No RAM for FRVIA_RECORD
    5267201 DBPINMAP Failed assumption theDb
    5267331 DBPINMAP Failed assumption theDb
    5267332 DBPINMAP Failed assumption theDb
    5269001 DBCOPY Failed assumption symId == 0
    5270123 DBSCAN Scan Heap
    5270150 DBSCAN Failed assumption libFileId > 0
    5270151 DBSCAN Failed assumption index > 0
    5270154 DBSCAN Failed assumption libFileId == libFileId
    5270174 DBSCAN Allocate a block for it
    5270198 DBSCAN Unexpected union kind
    5270201 DBSCAN Failed assumption theDb
    5270334 DBSCAN Allocate a record for it
    5270346 DBSCAN Object not found
    5270406 DBSCAN Bad kind in SCAN_RECORD
    5270702 DBSCAN Failed assumption dictHeap == 0
    5270704 DBSCAN Dictionary Heap
    5270967 DBSCAN Failed assumption currentLibId == libFileId
    5270995 DBSCAN Failed assumption currentLibId == libFileId
    5270996 DBSCAN Failed assumption currentLibId == libFileId
    5270997 DBSCAN Failed assumption currentLibId == libFileId
    5282201 DBMIRROR Failed assumption theDb
    5282203 DBMIRROR Failed assumption theDb
    5282206 DBMIRROR Failed assumption theDb
    5282303 DBMIRROR Failed assumption AltGetDepth ()
    5282305 DBMIRROR Failed assumption symPtr->header.derived != 0
    5352134 GEOOBS Failed assumption prevPtr->next == NULL
    5352135 GEOOBS Failed assumption prevPrevPtr->next == prevPtr
    5352136 GEOOBS outSegList: bad seg list
    5352137 GEOOBS outSegList: bad seg list
    5352138 GEOOBS Failed assumption count == listSize
    5352139 GEOOBS Failed assumption count == listSize
    5352177 GEOSPLIT Failed assumption segPtr != NULL
    5352177 GEOOBS Failed assumption segPtr != NULL
    6060126 COMINI Can't allocate line buffer
    6060128 COMINI "Error finding Layout.Ini file"
    6060129 COMINI "Error opening Layout.Ini file"
    6060241 COMINI Expected !bufferFull
    6060243 COMINI Failed assumption sectionIsActive == FALSE
    6060345 COMINI Expected iniFile == NULL
    6060346 COMINI Expected iniFile == NULL
    6070234 COMFILE stat function failed
    6070253 COMFILE stat function failed
    6070275 COMFILE Expected --saveDepth == 0
    6070277 COMFILE Failed assumption *drive >= 0
    6070278 COMFILE "drive" out of range (0, 26)
    6070334 COMFILE stat function failed
    6070534 COMFILE stat function failed
    6070800 COMFILE Expected ++saveDepth == 1
    6070802 COMFILE Expected ++saveDepth == 1
    6070900 COMFILE Expected --saveDepth == 0
