  3. How can I search specific trace line width using the find...
  • Subscribers 162
  • Views 18568
How can I search specific trace line width using the find option?
amose
amose over 13 years ago
I'm new to allegro tool.
I want to change the line width of a certain line, instead of slecting the Clines and change it. Is there a way that you can select that particular line width on the entire board and change it globally?
Thanks in advance.
  • Mstrghettorigg
    Mstrghettorigg over 13 years ago
    As Redwire mentioned, there is a skill file for this.  It's called CWIDTH.IL
     It should be available from sourcelink.
     Chapter 1 of algroskill.pdf in your install directory should help you figure out where to locate your files.
  • Mstrghettorigg
