  3. Differential pairs versus Void_Same_Net
  • Subscribers 163
  • Views 14479
jafan
jafan over 13 years ago
Hi guys,
   can you help me with the following problem? I tried to set Void_Same_Net property for the cline, which is a differential pair. But in the command line, I see warning message:
W- (SPMHGE-248): No instances of property VOID_SAME_NET found on the selected element(s).
 For the normal cline is all right.
Thank you in advance for your help
  • jafan
    Thank you for your reply. Our IT department installed on my PC hotfix 18, and it seems that works. We have version 16.5.
  • jafan
