  3. Multiple components with equal spacing
  • Subscribers 166
  • Views 17216
Mattias J
Mattias J over 13 years ago
I would like to know if there is a command for moving/distributing components so that the distance between them gets equal.
Example: Say that I make a rough placement of four resistances. I use the align tool so that they are aligned at the same line. Now I would like to make the distance between them the same. Are there a tool and/or command line command for that?
I’m using Allegro PCB Design XL 16.3.
  • steve
    steve over 13 years ago
    Not currently. There is a skill file called align (search the forum for it) written by Silver John which will do what you need.
  • redwire
    redwire over 13 years ago
     Or set your grid and origin and quickly snap the components to the new grid.  There are some useful SKILL files for doing this in Cadence downloads directory
  • edhickey
    edhickey over 13 years ago
    Component alignment will be enhanced in 16.6 to support equal spacing as well as compressing spacing to align with DFA constraints
    Ed
  • Mattias J
    Thank you all for your answers. I'll be changing my grid settings for now and wait for 16.6.
     /Mattias
