  3. Pspice problem - Remove DC offset from analysis
  • Views 3891
pppppp
pppppp over 13 years ago
 Hello!
I'm using OrCAD 16.5 lite student version for doing some BJT analysis for university.
How do I remove the DC portion of the signal I view on PSPICE? It is the collector voltage of a very simple
common emitter  amplifier. I want to compare the output with the input in order to graph them and determine
the gain.
I thought of doing it by adding a trace of OUTPUT-AVG(OUTPUT) but it is not as exact as it should because
of the first part of the signal, that little irregular transient.
Any ideas on how to do it? I have seen other programs have an AC probe  or AC-coupled probe..but none
of them had the Pspice signal math capabilities, or at least i did not foud them.
Thanks in advance.
  • Alok Tripathi
    Alok Tripathi over 13 years ago
     PSpice does not have AC coupled probe or AC mode as found is oscilloscopes. Output- AVG(OUTPUT) would not give the desired result. if DC value is constant and known, you may want to plot the waveform by subtracting that.
    Other alternative could be adding a appropriate value of capacitor in series and creating a dummy node in circuit. This node would be just for  observation purpose.
  • pppppp
     Thank you alokt.Then i should do everything manually :D
    Have a nice day.
