  3. Change the default thickness of wires
  • Subscribers 163
  • Views 18051
Abhimanyu1
Abhimanyu1 over 13 years ago
How to change the default thickness of wires in layout in ORCAD PCB editor,16.5, before using the atomatic routing. I can change the width, but as soon as I use the automatic routing option, the width changes back to 5 mil, which is the default setting.
  • oldmouldy
    oldmouldy over 13 years ago
    You can change the Min Line Width to "any" value you want, using an "empty" board as a staring point, the default setting is 5mil. Use the Constraint Manager to set the rules, Setup>Constraints>Physical, use Edit>Change, or right-click>Change Width, to change the width of any existing routing.
  • Abhimanyu1
    Thanks. It works.
