  3. REG:SAME NET VIA PARTIAL CONNECT
  • Views 2992
girish
girish over 13 years ago
Good Day to All
How to avoid below circumstance  while doing copper pouring ? .Via’s  not connecting fully /Not fully voiding ?
One option is to enable same net DRC & manually void in the error area ,its tedious when similar via counts are more .
Is there any property I can attach to the shape , via ,net , So that like this connections are avoided .
Please suggest
Girish Kumar
  • Robert Finley
    Robert Finley over 13 years ago
     Usually, in microwave designs, that situation with the vias sticking out tells me that I need to slide thos vias back under the fill boundaries.
     I'm not sure why your clearance between the pour and other nets is so wide.  Parasitic capacitance?
     In the end, many fabricators solve acid-traps with an automatic fillet in CAM.   I don't believe fixing that is necessary.
  • Robert Finley
