  3. Cannot select and hence edit the electrical connections...
  • Subscribers 166
  • Views 20240
Cannot select and hence edit the electrical connections and wires
Abhimanyu1
Abhimanyu1 over 13 years ago
I can select the symbols, edit, move them. But i cannot do the same with the electrical connections, wires etc. Why is it so? I need to edit them. PCB Editor 16.5
  • Ron Scott
    Ron Scott over 13 years ago
    It sounds like you don't have those attributes selected. Select your desired attribute in the "Find" filter. Hope this helps
  • Abhimanyu1
    Uh Uh....I tried to select them in "Find" options on the right side of the screen. But most of them are just dead...I cant select them, I cant deselct them. They are not responding and they are deselected, I dont know how.  I have control over "symobls", "pins", "drc zerrors" in "Find" option but I cant select "Lines", "shapes" etc...and many other of them. Hence not able to modify or edit them.
  • joma
    joma over 13 years ago
    It looks like you may be in Placement Mode. If so, try Setup >Application Mode >General Edit Or Etch Edit.
    Hope this helps,
    Jim O'Mahony
  • Abhimanyu1
    Thanks a lot. That was it. But I never changed any  settings. So had no clue  whats going on. Thank you.
