  3. Embedded Component
  • Subscribers 163
  • Views 14648
Embedded Component
Bala R
Bala R over 13 years ago
Hi All,
I am using Allegro 16.5 xl. license.
 I need to place few components on internal layers. how should i use the embedded componenet placement .
Also, pls let me know how can it be done in PCB itself (without schematics changes)
thanks
Bala R
  • Boma
    Boma over 13 years ago
    Sorry for the late responce, just going over 0 responce items. In 16.5 there are 2 basic steps.
    1.) Setup the embedded layer/s under the Setup pulldown under "Embedded Layer Setup..."  Probably use Body Up with Direct Attach.
    2.) Make sure all the embedded components have the  Embedded Placement property and a value of Required.
    You will need to be in pre-select placement mode to see the command to move the part to the inner layer.
    By the way,  this also works well for rigidflex designs where parts are not on the top layer.
    Boma
