  3. Modelling_Photovoltaic_Systems_Using_PSpice
  • Subscribers 163
  • Views 13966
Erion
Erion over 13 years ago
I want to simulate a simple photovoltaic system using PSpice for my Diploma. It's my first time using PSpice so I don't know where to put my sripts (PSpice files),at which window inside PSpice. I'm creating a circuit with dot commands not with icons. I'm using PSpice 9.1 student version, is it correct or I need another version.
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    It is recommended to use latest version, which is 16.5. You can download the latest version from http://www.cadence.com/products/orcad/pages/downloads.aspx#pspice
    This is free and offers additional/better capabilities than 9.1
    To create and simulate a new circuit, you should launch PSpice from start menu. Do File>New>text File. Type or paste your circuit file there. Save this with ".CIR" extension.
    Do File>Open Simulation and select this new cir file.
    Now your are ready to simulate and analyze the results. Do Simulation>Run for analysis, followed by View>Simulation result to load the simulation result. You need to Select Trace>Add trace and select appropriate node from list to see the waveform for corresponding node/net in circuit. It's just like using oscilloscope probe and connecting to specific point in circuit.
  • Erion
    Hi! Thank you for answering to me and your help. But again I need your help.
    After I save the text file as a ‘.CIR’ type, now I am not able to open this simulation. This because: at the directory where I saved it, the ‘.CIR’ file doesn’t exist. (It exist there, but as  file-type).
    I think: the problem is that the text-file isn’t saved correctly as a file that the compjuter can know and open it for simulation. The file I have saved, exist as a file-type although I have saved it with .CIR extension as you told. This kind of ‘type’, the computer doesn’t know. What kind of type should be the file, in order to be opened by the computer?
    I had done some photos(print-screen) to show you more exactly what I had done but I didn't know how to upload them here.
