  3. In need of urgent assistance.
  • Subscribers 166
  • Views 14079
Saternal
Saternal over 13 years ago
Hey everyone so to make it short I have been making a schemathic for school and it appears there is no T805 in the library (its a simple chip with In (leg number 1) out (leg number 2) and com (leg number 3)
 So how can i fix this I tried adding every library with no luck please help me!
  • steve
    steve over 13 years ago
    It does but the pin is invisible. Select the part then RMB - Edit Part to see the pin or change it to a visible one. It would automatcially connect to a net called GND if you keep it as invisible.
    All the basics for Capture are available from Help - Learning OrCAD Capture - then click on the OrCAD Capture Tutorial, this explains most of the basics...
  • steve
