  3. Creating multiple PDF files in Allegro with Script
  • Subscribers 166
  • Views 15023
Mstrghettorigg
Mstrghettorigg over 12 years ago
Hello all,
I am trying to find a way to create multiple PDF files with single script. (Separate files)
I would like to select few of the required layers I have setup to be printed through Allegro and use PDF writer to create these files.
For now, I have made a script so that Acrobat would open up ready to print, but I cannot get it to name it and proceed to the next film.
setwindow pcb
trapsize 1104
generaledit
setwindow form.vf_vis
FORM vf_vis colorview_list Film: RENAME_BOT
setwindow pcb
plot setup
setwindow form.fpfileplotsetup
FORM fpfileplotsetup done
setwindow pcb
generaledit
plot setup
setwindow pcb
generaledit
plotwint initialize "Adobe PDF"
plotwint orientation 2
plotwint papername "Tabloid"
plotwint scale 100
plotwint copies 1
plotwint defaultsource 15
plotwint printquality 1200
plotwint color 2
plotwint execute
I would like to name it the same file name as RENAME_BOT since "RENAME" will be the part number and I plan on switching it on the script file by find/replace before running the script.
I have added other layer name such as RENAME_TOP with same information on the file.  Everything seems to work except I have to rename these files manually which I would like to automate.
Please let me know if anyone can help.
Thank you in advance
  • Boma
    Boma over 12 years ago
    The easy way is to purchase a PDF Publishing license from Cadence.  It works off the artwork control form and has the option for seperate files or all in the same PDF file.
    Boma
  • Mstrghettorigg
    Hello Boma,
    Thank you for the feedback. I wasn't aware of the license, but I don't think I will be able to get them to purchase the license for us either way.
  • Boma
    I don't think the license is that expensive and it supports schematics in Concept HDL as well.  Has support for searchable text, net names and properties as well on the physical side.  1 license should support both EE's and designers at your company.  Works very good.....
  • lifemore
    lifemore over 12 years ago
    once you bough the license, you can download its softeware and create multiple files freely. you can also choose to install some free online PDF creator c#, most of them need licenst. but you can make use of its free trial to create multiple pdf files in batch. google around and you can find a lot. more info on the pdf processing function can be found here.
