  3. Interlinking Allegro with CAM350
  • Views 17014
KavitaG
KavitaG over 13 years ago
 I am trying to interlinkCAM350 with Allegro PCB editor.
While enabling Cross Probe Allegro in CAM350 its giving message as "start Allegro and the DstCAM350() script. "
can anybody tell me about this script file and the procedure to interlink these tools?
  • steve
    steve over 13 years ago
    Part of the CAM350 has a skill file dstcxi.il which is a skill file to enable the link. Normally when you insatll CAM350 a line is written to your allegro.ilinit file that enables this when you start Allegro. Check to make sure that you have the following as part of your $HOME\pcbenv\allegro.ilinit file.
    ; DstCAM350() is the CAM350 Cross Probe Startup
    load( "C:/DownStreamTech/CAM350 10.7/DstCxi.il")
  • KavitaG
    Thanks steve..that ws really helpful.
    I have chcked with my $HOME\pcbenv\allegro.ilinit file but i was not able to find it.
    nd is compatible with CAM350 10.0 ?
  • steve
    a sample allegro.ilinit file is attached.
    The path for the skill file just needs to match where it is stored on your PC.
    ilinit file.zip
  • dharmendhra
    dharmendhra over 12 years ago
    hi steve,
    while im trying to Interlinking Allegro with CAM350 im getting this kind of error "*Error* strcat: argument #1 should be either a string or a symbol (type template = "S") - nil"
    can you please help me on this
