  3. ODB export fails, "brd2odb.log does not exist."
  • Views 9765
jfockler
jfockler over 13 years ago
 I am new to Allegro. I made a simple change to a board silkscreen. I can successfully export the placement and the IPC but when I export the ODB data I get the error message:
"Allegro PCB Design XL"
'C;/USERDATA/.../ brd2odb.log' does not exist
How can I resolve this error?
Do I need to put my .brd file in a directory in the root ('C:\') directory?
  • tesgopi
    tesgopi over 13 years ago
    you need to download the ODB++ for windows (depending on your OS) from Valor.com
    (file name :cadif2odb_setup_v820.exe_)
    install it and try sure you can export ODB++ from CAD tool
    Best Regards,
    GopinathKannan
  • jfockler
    Thank you, Gopinath.
    I have installed the Windows version but I believe there is some problem with the PATH configuration.
    I have uninstalled and reinstalled ODB++ then rebooted my system, and still get the same error.
    Best Regards,
    Joe
  • tesgopi
    Hi Joe,
     you need to map the path in "environmental variables" of your PC (my computer -->properties-->advanced-->environment variables)
    For ex: It needs to add an environment variable ALLEGRO_BRD2ODB = C:\valor\ODB++Inside and a path of %ALLEGRO_BRD2ODB%/nv/bin
    Best Regards,
    Gopinath Kannan
  • jfockler
    Thank you, Gopinanth.
    From my ODB++  installation I have the following environment variable:
    ALLEGRO_BRD2ODB = C:\MentorGraphics\Allegro Export ODB++
    Path  C:\MentorGraphics\Allegro Export ODB++\nv\bin;%ALLEGRO_BRD2ODB%\nv\bin
    Maybe I need to install to a folder called C:\valor.
    Best Regards,
    Joe
  • tesgopi
    Hi Joe,
    Specific path is not required, the environmental variable only required the file path. Then use \ and / indication correctly, as I mentioned in my previous post. Even if u change the slash symbol as tool wont be active.I think u better understand, what i am trying to say. Better try this sure you can export the ODB++.
    Best & Regards,
    Gopinath Kannan
