  3. Fanout via get mirrored in allegro 16.2
  • Subscribers 166
  • Views 13006
tesgopi
tesgopi over 13 years ago
While create the fanout via in a package library, if we copy the fanout via with cline and if we mirror geomentry the fanout via the via alone get mirrored. This happens only in allegro 16.2. Can anyone suggestion on this....
 Best regards,
Gopinath Kannan
  • Tanveer
    Tanveer over 13 years ago
     I didn't understand clearly but I feel that you need to copy with "user pick" in the option tab and then choose mirror geometry will solve your problem
  • tesgopi
    Hi Tanveer,
      For  2-Pin components, If we fanout the via for pin1 and if we copy the cline and via w.rto pin1 and we mirror geomentry the cline and via then if we place in pin 2.In package library, Cline retains in pin 2 same as pin 1 but via alone get mirrored.This via get mirrored in allegro 16-2 only and in other version this problem doesnt occur.
     Best Regards,
    Gopinath Kannan
