  3. Windows 7 64 bit database problem
  • Subscribers 163
  • Views 5685
FormerMember
FormerMember over 13 years ago
Hi .
I have Windows 7 64 bit , Office 2010 32 bit and Capture CIS 16.3 .
Problem is that it is impossible to connect to Part database .
Have you any solution ?
  • oldmouldy
    oldmouldy over 13 years ago
    For a 64-bit OS, the Control Panel add-ins control only the 64-bit resources, you need to run the 32-bit ODBC admin from the Windows installation directory, then SysWOW64, locate the odbcad32.exe and use that to administer 32-bit data sources.
  • FormerMember
    It not work .
    I was set 32 bit ODBC access for Windows but Capture CIS configuration NOT see database !
    The message :" Data source not found... .To create data source ... go to Control panel and click the ODBC icon ..."
  • oldmouldy
    Which exact version are you using? (Help>About)
    Which datasources, if any, are listed when you use the Setup button in Configuration, or use the New to run through the DBC wizard?
    As a safety check, ensure that the Datasource name contains ony the regular ANSI characters, A-Z, a-z, 0-9, space, minus, underscore.
    Try a "Run As Administrator" right-click option from the Capture CIS shortcut / exe, this will ensure that the CIS components are correctly registered - this only needs to be a "one time" process.
