  3. Locate a component by its reference on PCB - possible ?
  • Replies 13
  • Subscribers 166
  • Views 17717
pyohayo
pyohayo over 13 years ago
Locate a component on PCB (with zoom on it) by its refernce on is very useful function, especially on complex PCBs with thousands nets/components. But it seems that this feature is missed in OrCAD Allegro (or it's hiden by some sophisticated interface).
When I specify the component reference in the Find by Name entry (please, see the picture in attachment), nothing happens !
Moreover, when I move cursor out, the entered text disappears !!!
Is it bug, or I missed something ?
Thanks in advance.
Pavel.
  • oldmouldy
    oldmouldy over 13 years ago
    see this discussion on the topic:
    /forums/T/23167.aspx
  • KEN13
    KEN13 over 13 years ago
    Pavel,
        Due to lack of power I cannot verify this exactly but...One thing you can do is toggle your shadow mode.  I cannot recall whether you have to disable custom colors or not??  Then when you use the find feature it will highlight the part.  I agre,e to have it zoom in on the part would be nice.
  • Carvey
    Carvey over 13 years ago
    Using 16.5 revision.
    When I select find, symbols, find by name, r111 (example).
    It zooms into the area and highlights the symbol and reference desiginator.
  • pyohayo
    Hello Ken, Carvey,
    I tried your suggestions. Unfortunately don't work. When I specify the reference of component (J60 as an example, please,see the picture) and then click OK, nothing happens - the component isn't highlighted/zoomed. And this for 2 filter options - Component/Symbols.
    Regards.
    Pavel.
  • pyohayo
    Works !!!
    I erroneously used Design Object Find Filter instead of Find by Name feature. This last works fine with 2 options - Comp (or Pin) and Symbol (or Pin). Proceeding in this way the tool finds specified component by its reference and zoom on it.
    Regards.
    Pavel.
