  3. changing the line end' shape
  • Replies 9
  • Subscribers 166
  • Views 9752
moayed
moayed over 12 years ago
Hello every one
how can i change the shape of the line from pending curve to straight shape in order to dealing with smd chips in orcad layout 10.3
from this shape --------) to this shape --------|
Best regards
  • moayed
  • Robert Finley
    Robert Finley over 12 years ago
     Oh.  That problem.
     Have you discovered the "Neck Mode" option that shows up while you are editing clines?
    You'll have to set the width of the trace you want to use in this "neck mode" in Constraint manager.  But, it works really well.
  • moayed
    So in this case i need to upgrade to cadence orcad 16.5
    because this option doesn't appear in my version orcad 16
    thank you very much for this
    Best regards
  • Robert Finley
    Sorry about that.  I'm not familiar with Orcad features as I own an Allegro seat.
    You could choose a thinner trace and add polygon fills to beef it up.
     I feel your pain on the feature problem.  With PADS LS, net class isn't available.  Have to upgrade to the ES flow.
    I have to ask.  What does the ground fill between the pads do?  Can you suppress that?
