  3. changing the line end' shape
  • Replies 9
  • Views 11270
moayed
moayed over 13 years ago
Hello every one
how can i change the shape of the line from pending curve to straight shape in order to dealing with smd chips in orcad layout 10.3
from this shape --------) to this shape --------|
Best regards
  • Robert Finley
    Robert Finley over 13 years ago
     square polygon copper pours over the trace ends?
    Are you doing this for SMD solder yield?  Or, is this a multi-gigahertz routing practice I just found out about a month ago?
  • moayed
    hello
    Actually i am am designer for lighting Boards for smd LED,s
    i solved this problem by that., but i wonder if there is a dierct option in orcad to change the end line shape attached a picture
    please send me youemail in order to send a picture to discribe the problem if it is not appear
  • moayed
    hello
    yes. i do it before but you need to change the line width at the ending side, really it take alot tıme from me
    please send me yours email in order to send a picture to descrıbe the problem more clearly
  • budnoel
    budnoel over 13 years ago
    Try selecting and deselecting "Connect line endcaps" under the Setup-Design Parameters-Display menu.  See if that does the trick for you.
  • Robert Finley
     I was wondering why other Microwave/RF designers didn't suggest this, then I realized...
     That option doesn't appear to give us the option to plot artwork with a square draw.  It does speed up display redraws.
