  3. brd2odb Error translating input.
  • Views 13583
abcdef123
abcdef123 over 13 years ago
I looked for this error and everyone seems to address the issue by changing the artwork type to RS274Xand decimal places to 5.I also run dbdoctor and have 0 errors but when I try to translate I get:
*********** ERROR  12Nov2012.141047.467  5924  91.1 Update 1(38) Windows XPCadence Interface - File geoms_28381155.out has wrong header*********** ERROR INTERNAL 12Nov2012.141047.467  5924  91.1 Update 1(38) Windows XP(ind_list != ((void *)0) && ind_list->magic == 12121212) at D:\vSureSRC\s911\gen\gen_sort.c 1236
Why is trying to read something from my D drive? Could this be the cause of it? I´m running the translator from within Allegro menu (file>export>odb++ inside)I´m on Allegro PCB Editor 15.5
  • clarkage
    clarkage over 12 years ago
    I'm having a similar problem when attempting to export ODB++ from .brd file.  It seems to break at some point and starts spitting out the error messages referring to D:\vSureSRC\ like the OP.  The last few lines of the log_brd2odb_x.txt are included below.  The fifth line is where this log diverges from other successful gererations of ODB++ files for our other boards.
    Done - 0 seconds
    Create step profile ...
    Complete step ...
    write file - G:/XXxxxxx/XXXxxxx/hw/XXXXxxxxx/hw/rXvX/allegro/odbjob/steps/pcb/eda/data.Z
    *********** ERROR INTERNAL 26Feb2013.093354.892  4676  9.1(1) Windows Vista
    (hIn != ((HANDLE)(LONG_PTR)-1)) at D:\vSureSRC\s91\gen\gen_fs.c 1930
    *********** ERROR INTERNAL 26Feb2013.093355.766  4676  9.1(1) Windows Vista
    System open call error : No such file or directory at D:\vSureSRC\s91\gen\gen_fs.c 1930
    file/dir causing error : C:/MentorGraphics/Allegro Export ODB++/tmp/brd_2/comps-genesis186ad.XXxxxx-Xxxx.4676
    *********** ERROR  26Feb2013.093355.766  4676  9.1(1) Windows Vista
    Object id = 1151, type = 3
    *********** ERROR  26Feb2013.093409.846  4676  9.1(1) Windows Vista
    colors file does not exist - C:/MentorGraphics/Allegro Export ODB++/.genesis/colors
    ***********  COMMAND 26Feb2013.093409.906  4676  9.1(1) Windows Vista
    units,type=inch (0)
    display_comp_outline_mode,mode=Body (0)
    Something happened to my board file when my computer crashed due to a graphics card failure.  After DB doctoring after the crash everything appeared to work fine; constraint manager was fine, all components imported worked fine, and gerber generation went off without a problem.  However, now that I try to export an ODB++ file(s) the symbols folder within the ODB++ archive is empty and this is something our contract manufacturer needs.  I tried the suggestion of changing the artwork to RS274X and decimal places but to no avail ( we use this format so I actually moved it away and back to the RS274X settings)
    Did anyone ever get resolution on this?  Right now I'm attempting to place-replicate an entire board design from the newer failing brd file to an older file that still generates ODB++ correctly but it's not fast or perfect and we've already lost some time due to this.
    Thanks for any help
