  3. manual switch in pspice capture
  • Views 22816
mrkira
mrkira over 13 years ago
As the title suggests, I'm looking for manual switch in CIS capture and all what i found was sw_tClose and sw_tOpen
thanks
  • oldmouldy
    oldmouldy over 13 years ago
    You need to have a switch where Open / Close is simulated. The sw_tClose / Open are normally Closed or Open until a specified time, when they switch with a transition time specified. You can use the "S", which is a voltage controlled switch if you want to control the switch state from a voltage source.
