  3. About Schematic and layout...
  • Subscribers 163
  • Views 14060
Wonderman
Wonderman over 13 years ago
 Thank you for quick reply, but since i am new to orcad I had put the wrong question. So once again I have put the question with the correction, Please reply....
I am designing a PCB using orcad. I put all the components in the schematic and make the connections and I create a netlist and hence the layout.
The questions are,
1) If I change any connection or component in the layout then it should show the error indicating that it is not in schematic.
2) Some times i may forget some connections in the schematic. In such case if I add any new connection in the layout then it should be applied to the schematic.
  • oldmouldy
    oldmouldy over 13 years ago
    Since you cannot change the connectivity, or the footprint component in PCB Editor, there is nothing to show in the schematic. If you make an invalid connection you will get a DRC in PCB Editor. The connectivity and footprints are determined from the netlist and this gets generated from the schematic data.
    The exact same thing applies, you cannot add, or remove connections in PCB Editor so, again, there is nothing to show in the schematic.
    This question seems to be "pretty much" like the previous question and, strangely, the answer remains "pretty much" the same!
  • oldmouldy
