  3. Z axis clearance constraint for High voltage nets
  • Subscribers 163
  • Views 17045
Robyd
Robyd over 13 years ago
Hello
Is there any way to insert a clearance constraint to avoid high voltage clearance violation  between different layers.
As i see it must take into acount the layer stackup dielectric thicknesses and make angular geometric clearance calculation between different objects in different layers ?
Maybe any body uses a custom SKILL for that ?
Thank you
  • TH Designs
    TH Designs over 13 years ago
    What kind of voltages are we talking about? You may just have to find out what the dielectric withstand voltage of the pcb/prepreg material your are using is and adjust your board thickness / stackup accordingly.
    STD FR4 is rated at 20kV/mm. Other pcb material maufacturers may have higher rated products. (Rogers comes to mind).
    I know of no z-axis constraint other then identifying specific layers to route the high voltages on. Possibly alternate inner layers to increase the z-axis spacing.
    Tom
  • Robyd
    Tom
    For PCB layout we follow IPC 2221A Table 6-1, which provides  recommended minimum spacing between conductors - The clearances needed are much smaller .
    please see http://www.smpspowersupply.com/ipc2221pcbclearance.html
    In very Dense PCB's we have layer to layer separation of down to 3 mil.
    According to IPC table voltage difference higher than 50V in internal layers requires 4 mil clearance ( in adjacent layer)
    When we design with higher voltages we need to keep clearance from objects in different layers ( in any angle - in Z axis)  of the PCB.
     There are also other clearance requirments such as IPC9592 and UL60950
    See also additional info at http://www.smps.us/pcbtracespacing.html
     There a real need for Z axis clearance control for PCB that comply to IPC Requirments or UL .
     Roby
  • redwire
    redwire over 13 years ago
     You really need to control z-axis by your stackup.  Also, the IPC table does not apply to Z-axis spacing.  See the earlier post.
    UL 60950 latest edition will show you what the z-axis rules are.  They have *recently* changed.  If you run 3 cloths of pre-preg you can squeeze down.  There are also tests that can be done as proof of compliance that will supercede any printed "rules"
     50V spacing can *easily* be met by 2 mil spacing in z axis.  Talk to your fabricator about what they can test to.
  • Robyd
    redwire - thabk you for the reply
    in IPC-2221 paragraph 6.3   you can find requirment for Z Axis i Quote
    "6.3 Electrical Clearance : Spacing between conductors on individual layers should be maximized whenever possible. The minimum spacing between conductors....... layer to layer conductive spaces (z=axis), and between conductive materials ... and conductors shall be in accordance with table 6-1,....."
     redwire :can you kindly share some examples of UL60950 clearance requirments fro PCB layout for Z axis ?
    I understand that Allegro does not support Z axis clearance constraints .
    About the 2 mil clearance being enough for 50V - this was only an example
    BUT sometimes i have up to 1500 v and higher
    roby
