  3. Footprint shapes not showing solid copper
  • Views 15089
TH Designs
TH Designs over 13 years ago
I made this connector footprint which requires solder pads around the perimeter to hold the connector to the board. They are on shapes on the etch layer with solid fill, but they always show as outlines with dots inside. Even when doing the artwork preview.
Will they come out as solid copper pads in the gerbers?
Tom
[IMG]i21.photobucket.com/.../IMG]
  • steve
    steve over 13 years ago
    Tom - In Setup - User Preferences click on the Info button and you get a list of the settings plus a description to what they do. Whenever you set one it gets written to the %HOME%\pcbenv\env file so you can see what you have set.
  • steve
