  3. Voids areas on plane that won't go away
  • Subscribers 166
  • Views 2991
TH Designs
TH Designs over 12 years ago
In the attcahed picture I have some void areas in the gnd plane that I can not get rid of. I have tried turning all colors on to see if there was somthing hiding there, but nothing shows up. Screen redraws and closing / re-opening board file have no effect.
What are these mysterious areas and how do I get rid of them?
Tom
  • TH Designs
    Answering my own question. Found put that these shapes are "voids" and going to Shape - Manaul Void/Cavity - Delete allows me to select and delete each one.
    This was an area where we changed the connector type. I suppose these voids were left overs from something. I surely didn't put them in...........
    Hopefully this is the last problem for the day............
     Tom
  • oldmouldy
    oldmouldy over 12 years ago
    You may have had some isolated (unassigned) copper shapes with the previous connector type and used Shape>Delete Islands to get rid of them. Shape>Delete Islands draws manual voids for the isolated shapes to remove them.
  • TH Designs
    Once again OM, you are right on target. I didn't think of that. The previous part had 2mm lead spacing and there were islands between the pins that I deleted.  This must have been left over artifacts from that island removal.
    I have to say though, you'd think the software would take care of them. For that matter, you'd think it wouldn't leave islands in the first place.
    Have a great weekend!
    Tom
  • jemarods
    jemarods over 12 years ago
     You can also try this:
     close all layers
    open only "boundary" for that layer
    then delete the shape
    then update your plane
    then those voids would be gone for sure,
