  3. OrCad CIS on mySQL server
  • Views 20661
AxelLboro
AxelLboro over 13 years ago
I am using OrCad CIS 16.5 and I would like to use my company server to host the CIS database. We are using mySQL. I have set up a database with the properties as described in the help and created a new odbm data source. However, if I want to create a new data source in OrCad CIS preferences it doesn't appear in the options. I was wondering if OrCAD accepts mySQL as data base? Does anyone have a document how to set up the database on mysql and integrate it into OrCad CIS?
Many thanks in advance.
  • oldmouldy
    oldmouldy over 13 years ago
    You need to use the 32-bit ODBC drivers, if there is any alternative. The MySQL connector has versions for ODBC 3.51 and 5.x, you might want to try both of these to see which gives best results since these can vary a bit. On a 64-bit OS, use the odbcad32.exe to configure the Datasource in the Control Panel stage. Create a System DSN for the database, any other option won't work (properly or at all). Ensure that you have at least the 4 required CIS fields in the database table(s) Fundamentally, this will all work just fine.
    (Basically, the CIS application connects to the ODBC datasource, that is the "universal" bit, what is "at the other end" of the ODBC connection is irrelevant since the ODBC driver maps between the "universal" bit that the application sees and the bit that is specific to the actual database, whatever that might be.)
  • AxelLboro
    Thank you very much for your quick response. The problem was that I added the data source as user DNS and not in System DNS. I can select now my data source, when I set the database configuration.
    However, if I press the next button, then I receive the error message "ERROR(ORCIS-6245): Database Operation Failed Please Check Session For More Details". I am not totally sure what this means. The user should have read and write access to the database.
     Many thanks
  • stanzani
    stanzani over 12 years ago
    hello all
    I am struggling to make the CIS communicating with and SQL server running on a Linux OS. I am pretty unexperienced with all of this .NET, Microsoft SQL server etc. but still the instalaltion manual cannot help me :( (I mean Component Information Portal™ (CIP) Installation Guide Version 4.3  ).
    First I cannot figure out vey well the architecture (Fig. 1). I see a file server, a web server and a CIP-E/CIS database (SQL)
    Since I want to make a number of designers sharing the component DB I am thinking that the  CIP-E/CIS database (SQL) is a machine (Linux in my case) running an SQL server (my SQL, I'd like). or may be it is the FIle Server?
     @AXelBoro: where is the help file showing / describing how to create teh database?
    the whole thing is so confusing and I cannot find too much help in the docs (maybe they are written for experienced system adiministrator which I am not)
    plz help: possibly address some guide to do this
  • oldmouldy
    oldmouldy over 12 years ago
    Capture CIS uses a technology called ODBC to work with "any" database that supports an ODBC driver.
    CIP is specifically design to use Microsoft technologies, Internet Information Services and SQL Server, these technologies are NOT available to Linux platforms, you must use a Windows platform to be able to install and use the CIP. See the Minimum Requirements for Installing CIP on page 8 of the Installation Guide you mentioned.
  • stanzani
    ... AxelBoro is using mySQL which is NOT a Microsoft technology. Also the sales reprentative told us that a mySQL platform could have been used for this. Installing ODBC driver for Red Hat should make the connection unaware of the database engine (mySQL, Oracle, Access etc.) underneath
    ODBC drivers are available for Linux http://www.microsoft.com/en-us/download/details.aspx?id=36437 i.e. supposedly the system can communciate with a Linux based database server
    BTW I opened a ticket with tech support
    thanks
