  3. acid traps and silkscreen check-166
  • Subscribers 166
  • Views 14080
MAAC
MAAC over 13 years ago
hi,
 is thr any methods to "check" the acid trap on pcb and to know the "silkscreen over pads" using allegro pcb tool
 not looking into adding the fillets/gloss
thnx
  • steve
    steve over 13 years ago
    Acid traps - you need to set the same net spacing rules up for pad to line etc, make sure they are enabled to DRC in two places, Setup - Constraints - Modes - same net spacing spacing and also in Constraint Manager - same net spacing - Options, turn to True.
    For the silkscreen over pads there's a skill file called silk utils (Dave Elder one) available on the skill forum.
  • comet
    comet over 12 years ago
    Hey Guys,
    I'm also interested on this silkscreen check over pads. However, I think the 'silkutils' skill available would only check if the pad or via has soldermask on it. What if mask is not present? Any other checking method or skill on this case?...
    Thanks!
  • comet
    0oops! the latest skill autosilkUtils_public.il  by eDave resolved this issue. Thanks!
